[mapserver-commits] [mapserver/mapserver] 607b72: fix uninitialized text outline width in error imag...
GitHub noreply at github.com
Mon Jul 30 09:36:49 PDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: 607b7290244400cc85c5e79f416f968bf804394f
      https://github.com/mapserver/mapserver/commit/607b7290244400cc85c5e79f416f968bf804394f
  Author: Thomas Bonfort <thomas.bonfort at gmail.com>
  Date:   2012-07-18 (Wed, 18 Jul 2012)
  Changed paths:
    M maperror.c
  Log Message:
  fix uninitialized text outline width in error image
  Commit: d8763a781ec82e464122a81675223cd6c475d610
      https://github.com/mapserver/mapserver/commit/d8763a781ec82e464122a81675223cd6c475d610
  Changed paths:
    M mapgd.c
  Log Message:
  fix gd transparent background (#4013)
the proposed fix broke transparent layers, and mask implementation. It
also does not correct the artifact I see around text (which went from
purple to white), btw.
  Commit: 67f27843c9b4c89fe7ce05abbd1e982821818723
      https://github.com/mapserver/mapserver/commit/67f27843c9b4c89fe7ce05abbd1e982821818723
  Date:   2012-07-19 (Thu, 19 Jul 2012)
  Changed paths:
    M mapdraw.c
  Log Message:
  fix bug with uncached/cached shapes (#4371)
  Commit: bcd0449ecee697931bc4ca54bb4f159df9a688c8
      https://github.com/mapserver/mapserver/commit/bcd0449ecee697931bc4ca54bb4f159df9a688c8
  Date:   2012-07-23 (Mon, 23 Jul 2012)
  Changed paths:
    M configure
    M configure.in
  Log Message:
  add -ldl to linker flags (#4342)
closes #4342
  Commit: 73761fd82bcac605b47a693af93a299c3eecbd72
      https://github.com/mapserver/mapserver/commit/73761fd82bcac605b47a693af93a299c3eecbd72
  Author: szekerest <szekerest at gmail.com>
  Date:   2012-07-30 (Mon, 30 Jul 2012)
  Changed paths:
    M mapdraw.c
    M maputil.c
  Log Message:
  Fix build problems related to mixed code and variable declarations
  Commit: 3128a3c71c1cffbbfcd3bb3fdfd7f0ff4e94c012
      https://github.com/mapserver/mapserver/commit/3128a3c71c1cffbbfcd3bb3fdfd7f0ff4e94c012
  Author: Even Rouault <even.rouault at mines-paris.org>
  Changed paths:
    M configure
    M configure.in
    A m4/ax_cflags_warn_all.m4
  Log Message:
  Unix configure: add -Wdeclaration-after-statement by default in CFLAGS to issue 'warning: ISO C90 forbids mixed declarations and code' with GCC, which means that compilation will fails with MSVC, so something that *MUST* be fixed
  Commit: 42cc8829de3dd06ed71b5837c7b897991bc1f905
      https://github.com/mapserver/mapserver/commit/42cc8829de3dd06ed71b5837c7b897991bc1f905
  Changed paths:
    M mapproject.c
  Log Message:
  add call to msComputeBounds after fastpath reprojection
  Commit: 677ff4540fd461df7a6a7f8d19a7d2ae881f48bb
      https://github.com/mapserver/mapserver/commit/677ff4540fd461df7a6a7f8d19a7d2ae881f48bb
  Changed paths:
    M mapproject.c
  Log Message:
  avoid going through internal resampling for degenerate rects (#4039)
when passed an unitialized rectObj, msProjectRect() will try to sample
the rect by going through msProjectRectGrid() which is non needed. This
commit reprojects (minx,miny) and updates the rectObj accordingly. Might
solve #4039 as the failure is happening somewhere inside the
rect reprojection code.
  Commit: 02e56f79c706cdf4fceec0003a7442b3790c1763
      https://github.com/mapserver/mapserver/commit/02e56f79c706cdf4fceec0003a7442b3790c1763
  Changed paths:
    M mapows.c
  Log Message:
  avoid memory corruption in inspire capabilities (#4387)
  Commit: 204b68b4e37cf2a327c48a14a0f9c6b73e3b517b
      https://github.com/mapserver/mapserver/commit/204b68b4e37cf2a327c48a14a0f9c6b73e3b517b
  Changed paths:
    M mapdraw.c
    M mapdrawgdal.c
    M mapgml.c
    M mapimageio.c
    M maplabel.c
    M mapogcfilter.c
    M mapogcsld.c
    M mapogcsos.c
    M mapogr.cpp
    M mapowscommon.c
    M mapproject.c
    M mapresample.c
    M mapservutil.c
    M mapshape.c
    M maptemplate.c
    M maptile.c
    M maputil.c
    M mapuvraster.c
    M mapwcs11.c
    M mapwcs20.c
    M mapwfs.c
    M mapwfs11.c
    M mapwmslayer.c
    M mapxbase.c
    M shptreetst.c
    M shptreevis.c
  Log Message:
  fix various compiler warnings
  Commit: 95f13cdfe56baa3f01024d66d9a72015e92fd006
      https://github.com/mapserver/mapserver/commit/95f13cdfe56baa3f01024d66d9a72015e92fd006
  Changed paths:
    M configure
    M configure.in
    M mapdraw.c
    M mapdrawgdal.c
    M maperror.c
    M mapgd.c
    M mapgml.c
    M mapimageio.c
    M maplabel.c
    M mapogcfilter.c
    M mapogcsld.c
    M mapogcsos.c
    M mapogr.cpp
    M mapows.c
    M mapowscommon.c
    M mapproject.c
    M mapresample.c
    M mapservutil.c
    M mapshape.c
    M maptemplate.c
    M maptile.c
    M maputil.c
    M mapuvraster.c
    M mapwcs11.c
    M mapwcs20.c
    M mapwfs.c
    M mapwfs11.c
    M mapwmslayer.c
    M mapxbase.c
    M shptreetst.c
    M shptreevis.c
  Log Message:
  Merge branch 'branch-6-2'
Compare: https://github.com/mapserver/mapserver/compare/a4894578dbe2...95f13cdfe56b
