[mapserver-commits] r13190 - sandbox/tb-labels
Thu Mar 1 12:25:48 EST 2012
Author: tbonfort
Date: 2012-03-01 09:25:48 -0800 (Thu, 01 Mar 2012)
New Revision: 13190
   sandbox/tb-labels/mapdraw.c
leaner and faster labelcache
Modified: sandbox/tb-labels/mapdraw.c
--- sandbox/tb-labels/mapdraw.c	2012-03-01 10:27:49 UTC (rev 13189)
+++ sandbox/tb-labels/mapdraw.c	2012-03-01 17:25:48 UTC (rev 13190)
@@ -2592,67 +2592,39 @@
    return retval;
-/* add "to"'s geometry to "from", without unnecessary allocations.
- * the ownership of "from"'s geometry is transfered to "to"
-static void transferLabelShape(shapeObj *from, shapeObj *to) {
-  int i,copybounds=0;
-  if(!from || !to) return;
-  if( to->numlines <= 0 ) {
-     copybounds=1;
-     to->line = (lineObj *) msSmallMalloc(from->numlines * sizeof(lineObj));
-     to->numlines = 0;
-  else {
-      to->line = (lineObj *) msSmallRealloc(to->line, (to->numlines+from->numlines)*sizeof(lineObj));
-  for(i=0; i<from->numlines; i++) {
-     to->line[to->numlines].point = from->line[i].point;
-     to->line[to->numlines].numpoints = from->line[i].numpoints;
-     to->numlines++;
-     from->line[i].point = NULL;
-     from->line[i].numpoints = 0;
-  if(copybounds) {
-     to->bounds.minx = from->bounds.minx;
-     to->bounds.miny = from->bounds.miny;
-     to->bounds.maxx = from->bounds.maxx;
-     to->bounds.maxy = from->bounds.maxy;
-  } else {
-     to->bounds.minx = MS_MIN(to->bounds.minx,from->bounds.minx);
-     to->bounds.miny = MS_MIN(to->bounds.miny,from->bounds.miny);
-     to->bounds.maxx = MS_MAX(to->bounds.maxx,from->bounds.maxx);
-     to->bounds.maxy = MS_MAX(to->bounds.maxy,from->bounds.maxy);
-  msFree(from->line);
-  from->line = NULL;
-  from->numlines = 0;
-  from->bounds.minx=from->bounds.miny=from->bounds.maxx=from->bounds.maxy=-1;
 int computeOldStyleMarkerPoly(mapObj *map, imageObj *image, labelCacheMemberObj *cachePtr,
       labelCacheSlotObj *cacheslot, shapeObj *markerPoly) {
    layerObj *layerPtr = (GET_LAYER(map, cachePtr->layerindex));
+   markerPoly->numlines = 0;
+   pointObj *point = markerPoly->line[0].point;
    if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0) {
       /* TODO: at the moment only checks the bottom (first) marker style since it *should* be the
          largest, perhaps we should check all of them and build a composite size */
       double marker_width,marker_height;
-      rectObj marker_rect;
       if(msGetMarkerSize(&map->symbolset, &(cachePtr->styles[0]), &marker_width, &marker_height, layerPtr->scalefactor) != MS_SUCCESS)
          return MS_FAILURE;
-      marker_rect.minx = cachePtr->point.x - .5 * marker_width;
-      marker_rect.miny = cachePtr->point.y - .5 * marker_height;
-      marker_rect.maxx = marker_rect.minx + (marker_width-1);
-      marker_rect.maxy = marker_rect.miny + (marker_height-1);
-      msRectToPolygon(marker_rect, markerPoly);
+      markerPoly->numlines = 1;
+      markerPoly->bounds.minx = cachePtr->point.x - .5 * marker_width;
+      markerPoly->bounds.miny = cachePtr->point.y - .5 * marker_height;
+      markerPoly->bounds.maxx = markerPoly->bounds.minx + (marker_width-1);
+      markerPoly->bounds.maxy = markerPoly->bounds.miny + (marker_height-1);
    } else if (layerPtr->type == MS_LAYER_POINT && cachePtr->markerid!=-1) { /* there is a marker already in the image that we need to account for */
       markerCacheMemberObj *markerPtr = &(cacheslot->markers[cachePtr->markerid]); /* point to the right sport in the marker cache (if available) */
-      msRectToPolygon(markerPtr->poly->bounds, markerPoly);
+      markerPoly->bounds = markerPtr->poly->bounds;
+   if(markerPoly->numlines) {
+      point[0].x = markerPoly->bounds.minx;
+      point[0].y = markerPoly->bounds.miny;
+      point[1].x = markerPoly->bounds.minx;
+      point[1].y = markerPoly->bounds.maxy;
+      point[2].x = markerPoly->bounds.maxx;
+      point[2].y = markerPoly->bounds.maxy;
+      point[3].x = markerPoly->bounds.maxx;
+      point[3].y = markerPoly->bounds.miny;
+      point[4].x = markerPoly->bounds.minx;
+      point[5].y = markerPoly->bounds.miny;
    return MS_SUCCESS;
@@ -2660,6 +2632,7 @@
       labelObj *label, shapeObj *markerPoly) {
    int i;
    for (i=0; i<label->numstyles; i++) {
       styleObj *style = label->styles[i];
       if(style->_geomtransform.type == MS_GEOMTRANSFORM_LABELPOINT &&
@@ -2668,27 +2641,25 @@
          symbolObj *symbol = map->symbolset.symbol[style->symbol];
          if(msGetMarkerSize(&map->symbolset, style, &sx, &sy, layerPtr->scalefactor) != MS_SUCCESS)
             return MS_FAILURE;
-         lineObj line;
-         line.point = msSmallMalloc(5*sizeof(pointObj));
-         line.numpoints = 5;
-         line.point[0].x = sx / 2.0;
-         line.point[0].y = sy / 2.0;
-         line.point[1].x =  line.point[0].x;
-         line.point[1].y = -line.point[0].y;
-         line.point[2].x = -line.point[0].x;
-         line.point[2].y = -line.point[0].y;
-         line.point[3].x = -line.point[0].x;
-         line.point[3].y =  line.point[0].y;
-         line.point[4].x =  line.point[0].x;
-         line.point[4].y =  line.point[0].y;
+         point[0].x = sx / 2.0;
+         point[0].y = sy / 2.0;
+         point[1].x =  point[0].x;
+         point[1].y = -point[0].y;
+         point[2].x = -point[0].x;
+         point[2].y = -point[0].y;
+         point[3].x = -point[0].x;
+         point[3].y =  point[0].y;
+         point[4].x =  point[0].x;
+         point[4].y =  point[0].y;
          int p;
          double aox,aoy;
          if(symbol->anchorpoint_x != 0.5 || symbol->anchorpoint_y != 0.5) {
             aox = (0.5 - symbol->anchorpoint_x) * sx;
             aoy = (0.5 - symbol->anchorpoint_y) * sy;
             for(p=0;p<5;p++) {
-               line.point[p].x += aox;
-               line.point[p].y += aoy;
+               point[p].x += aox;
+               point[p].y += aoy;
          if(style->angle) {
@@ -2696,25 +2667,42 @@
             double sina = sin(rot);
             double cosa = cos(rot);
             for(p=0;p<5;p++) {
-               double tmpx = line.point[p].x;
-               line.point[p].x = line.point[p].x * cosa - line.point[p].y * sina;
-               line.point[p].y = tmpx * sina + line.point[p].y * cosa;
+               double tmpx = point[p].x;
+               point[p].x = point[p].x * cosa - point[p].y * sina;
+               point[p].y = tmpx * sina + point[p].y * cosa;
          aox = cachePtr->point.x + style->offsetx * layerPtr->scalefactor;
          aoy = cachePtr->point.y + style->offsety * layerPtr->scalefactor;
          for(p=0;p<5;p++) {
-         msAddLineDirectly(markerPoly,&line);
-         msComputeBounds(markerPoly);
+         fastComputeBounds(markerPoly);
          break;
    return MS_SUCCESS;
+void fastComputeBounds(shapeObj *shape)
+   int i,j;
+   shape->bounds.minx = shape->bounds.maxx = shape->line[0].point[0].x;
+   shape->bounds.miny = shape->bounds.maxy = shape->line[0].point[0].y;
+  for( i=0; i<shape->numlines; i++ ) {
+    for( j=0; j<shape->line[i].numpoints; j++ ) {
+      shape->bounds.minx = MS_MIN(shape->bounds.minx, shape->line[i].point[j].x);
+      shape->bounds.maxx = MS_MAX(shape->bounds.maxx, shape->line[i].point[j].x);
+      shape->bounds.miny = MS_MIN(shape->bounds.miny, shape->line[i].point[j].y);
+      shape->bounds.maxy = MS_MAX(shape->bounds.maxy, shape->line[i].point[j].y);
 int msDrawLabelCache(imageObj *image, mapObj *map)
   int nReturnVal = MS_SUCCESS;
@@ -2724,16 +2712,30 @@
       int i, l, ll, priority;
       rectObj r;
-      shapeObj poly; /* hold label polygon for one label, cachePtr->poly holds label polygon for the whole group */
-      msInitShape(&poly);
       labelCacheMemberObj *cachePtr=NULL;
       layerObj *layerPtr=NULL;
       classObj *classPtr=NULL;
       labelObj *labelPtr=NULL;
       /* holds the contour of the label styles that correspond to markers */
-      shapeObj markerPoly;
-      msInitShape(&markerPoly);
+      shapeObj marker_poly;
+      lineObj  marker_line;
+      pointObj marker_points[5];
+      marker_line.point = marker_points;
+      marker_line.numpoints = 5;
+      msInitShape(&marker_poly);
+      marker_poly.line = &marker_line;
+      marker_poly.numlines = 1;
+      shapeObj metrics_poly;
+      lineObj metrics_line;
+      pointObj metrics_points[5];
+      metrics_line.point = metrics_points;
+      metrics_line.numpoints = 5;
+      msInitShape(&metrics_poly);
+      metrics_poly.line = &metrics_line;
+      metrics_poly.numlines = 1;
       double marker_offset_x, marker_offset_y;
@@ -2763,6 +2765,11 @@
           layerPtr = (GET_LAYER(map, cachePtr->layerindex)); /* set a couple of other pointers, avoids nasty references */
           classPtr = (GET_CLASS(map, cachePtr->layerindex, cachePtr->classindex));
+          if (layerPtr->type == MS_LAYER_ANNOTATION && (cachePtr->numlabels > 1 || classPtr->leader.maxdistance)) {
+             msSetError(MS_MISCERR, "Multiple Labels and/or LEADERs are not supported with annotation layers", "msDrawLabelCache()");
+             return MS_FAILURE;
           /* TODO: classes with a labelpath do not respect multi label rendering */
           if(cachePtr->labelpath) { /* path-based label */
@@ -2781,7 +2788,7 @@
             label_mindistance = (labelPtr->mindistance*image->resolutionfactor);
             /* copy the bounds into the cache's polygon */
-            transferLabelShape(&(cachePtr->labelpath->bounds), cachePtr->poly);
+            msCopyShape(&(cachePtr->labelpath->bounds), cachePtr->poly);
             /* compare against image bounds, rendered labels and markers (sets cachePtr->status), if FORCE=TRUE then skip it */
             cachePtr->status = MS_TRUE;
@@ -2800,22 +2807,36 @@
             marker_offset_x = marker_offset_y = 0; /* assume no marker */
             /* compute label bbox of a marker used in an annotation layer or a point layer with markerPtr */
-            computeOldStyleMarkerPoly(map,image,cachePtr,cacheslot,&markerPoly);
-            if(markerPoly.numlines) {
-               marker_offset_x = (markerPoly.bounds.maxx-markerPoly.bounds.minx)/2.0;
-               marker_offset_y = (markerPoly.bounds.maxy-markerPoly.bounds.miny)/2.0;
-               /* add marker to cachePtr->poly */
-               transferLabelShape(&markerPoly, &poly);
+            computeOldStyleMarkerPoly(map,image,cachePtr,cacheslot,&marker_poly);
+            if(marker_poly.numlines) {
+               marker_offset_x = (marker_poly.bounds.maxx-marker_poly.bounds.minx)/2.0;
+               marker_offset_y = (marker_poly.bounds.maxy-marker_poly.bounds.miny)/2.0;
+               /* if this is an annotation layer, transfer the markerPoly */
+               if(layerPtr->type == MS_LAYER_ANNOTATION) {
+                  if(cachePtr->numlabels > 1 || classPtr->leader.maxdistance) {
+                     msSetError(MS_MISCERR,"Multiple Labels and/or LEADERs are not supported with annotation layers","msDrawLabelCache()");
+                  tmppoly = cachePtr->poly;
+                  cachePtr->poly = &marker_poly;
+                  if( MS_OFF == msTestLabelCacheCollisions(map, cachePtr, 0,priority, l)) {
+                     continue; /* the marker collided, no point continuing */
+                  cachePtr->poly = tmppoly;
+                  msAddLine(cachePtr->poly,marker_poly.line);
+                  msComputeBounds(cachePtr->poly);
             ** all other cases *could* have multiple labels defined
             cachePtr->status = MS_OFF; /* assume this cache element *can't* be placed */
             for(ll=0; ll<cachePtr->numlabels; ll++) { /* RFC 77 TODO: Still may want to step through backwards... */
-              msFreeShape(&poly);
               labelPtr = &(cachePtr->labels[ll]);
               labelPtr->status = MS_OFF;
+              int label_marker_status = MS_ON;
               /* first check if there's anything to do with this label */
               if(!labelPtr->annotext) {
@@ -2832,18 +2853,26 @@
               /* compute the poly of the label styles */
-              computeLabelMarkerPoly(map,image,cachePtr,labelPtr,&markerPoly);
+              computeLabelMarkerPoly(map,image,cachePtr,labelPtr,&marker_poly);
                  if(cachePtr->numlabels > 1) {
                  } else {
                     /* we might be using an old style behavior with a markerPtr */
-                    marker_offset_x = MS_MAX(marker_offset_x,(markerPoly.bounds.maxx-markerPoly.bounds.minx)/2.0);
-                    marker_offset_y = MS_MAX(marker_offset_y,(markerPoly.bounds.maxy-markerPoly.bounds.miny)/2.0);
+                    marker_offset_x = MS_MAX(marker_offset_x,(marker_poly.bounds.maxx-marker_poly.bounds.minx)/2.0);
+                    marker_offset_y = MS_MAX(marker_offset_y,(marker_poly.bounds.maxy-marker_poly.bounds.miny)/2.0);
+                 if(labelPtr->force != MS_TRUE)
+                    label_marker_status = msTestLabelCacheCollisions(map, cachePtr, 0,priority, l);
+                 if(label_marker_status == MS_OFF &&
+                         !(labelPtr->force || classPtr->leader.maxdistance))
+                    break; /* the marker collided, break from multi-label loop */
@@ -2903,8 +2932,10 @@
+              /* TODO: no point in using auto positionning if the marker cannot be placed? */
               if(labelPtr->annotext && labelPtr->position == MS_AUTO) {
+                 /* no point in using auto positionning if the marker cannot be placed */
                 int positions[MS_POSITIONS_LENGTH], npositions=0;
@@ -2924,92 +2955,96 @@
                 for(i=0; i<npositions; i++) {
                   // RFC 77 TODO: take label_marker_offset_x/y into account
-                  labelPtr->annopoint = get_metrics(&(cachePtr->point), positions[i], r,
+                  labelPtr->annopoint = get_metrics_line(&(cachePtr->point), positions[i], r,
                         marker_offset_x + label_offset_x, marker_offset_y + label_offset_y,
-                        labelPtr->angle, label_buffer, &poly);
+                        labelPtr->angle, label_buffer, &metrics_line);
+                  fastComputeBounds(&metrics_poly);
                   if(labelPtr->force == MS_OFF) {
                      /* check for collisions inside the label group */
-                     /* if cachePtr->status we're still working on the first valid label with a valid status value */
-                     /* was: if((ll != 0) && intersectLabelPolygons(poly, cachePtr->poly) == MS_TRUE) */
-                     if(ll && intersectLabelPolygons(&poly, cachePtr->poly) == MS_TRUE) {
-                        /* there was a self intersection, remove the label bbox added by get_metrics ? */
-                        msShapeDeleteLine(&poly, poly.numlines-1);
-                        msComputeBounds(&poly);
+                     if(cachePtr->poly->numlines && intersectLabelPolygons(&metrics_poly, cachePtr->poly) == MS_TRUE) {
+                        /* there was a self intersection */
                         continue; /* next position, labelPtr->status is left to MS_OFF */
-                  cachePtr->poly = &poly;
+                  cachePtr->poly = &metrics_poly;
                   labelPtr->status = msTestLabelCacheCollisions(map, cachePtr, label_mindistance,priority, l);
                   /* found a suitable place for this label */
-                  if(labelPtr->status || (i==(npositions-1) && labelPtr->force == MS_TRUE)) {
+                  if(labelPtr->status == MS_TRUE || (i==(npositions-1) && labelPtr->force == MS_ON)) {
                     labelPtr->status = MS_TRUE; /* set to true in case we are forcing it */
                     if(labelPtr->annopoly) get_metrics_line(&(cachePtr->point), positions[i], r,
                           labelPtr->angle, 1, labelPtr->annopoly->line);
                     break; /* ...out of position loop */
-                  } else {
-                     /* remove the poly added by get_metrics for this label position, unless this is the last tested
-                      * position and we have label->force, as in that case it will be kept regardlesss of collisions */
                 } /* next position */
+                /* if position auto didn't manage to find a position, but we have leader configured
+                 * for the class, then we want to compute the label poly anyways */
                 if(classPtr->leader.maxdistance && labelPtr->status == MS_FALSE) {
-                  labelPtr->annopoint = get_metrics(&(cachePtr->point), MS_CC, r,
+                  labelPtr->annopoint = get_metrics_line(&(cachePtr->point), MS_CC, r,
               } else { /* explicit position */
                 if(labelPtr->annotext) {
                    if(labelPtr->position == MS_CC) { /* don't need the marker_offset */
-                      labelPtr->annopoint = get_metrics(&(cachePtr->point), labelPtr->position, r,
-                            label_offset_x, label_offset_y, labelPtr->angle, label_buffer, &poly);
+                      labelPtr->annopoint = get_metrics_line(&(cachePtr->point), labelPtr->position, r,
+                            label_offset_x, label_offset_y, labelPtr->angle, label_buffer, &metrics_line);
                       if(labelPtr->annopoly) get_metrics_line(&(cachePtr->point), labelPtr->position, r,
                             label_offset_x, label_offset_y, labelPtr->angle, 1, labelPtr->annopoly->line);
                    } else {
-                if(labelPtr->force == MS_TRUE) {
-                  transferLabelShape(&poly, cachePtr->poly);
-                  labelPtr->status = MS_TRUE;
+                   if(labelPtr->force == MS_ON) {
+                     labelPtr->status = MS_ON;
+                   } else {
+                     if(labelPtr->force == MS_OFF) {
+                        /* check for collisions inside the label group unless the label is FORCE GROUP */
+                           break; /* collision within the group */
+                     /* TODO: in case we have leader lines and multiple labels, there's no use in testing for labelcache collisions
+                     * once a first collision has been found. we only need to know that the label group has collided, and the
+                     * poly of the whole label group: if(label_group) testLabelCacheCollisions */
+                     labelPtr->status = msTestLabelCacheCollisions(map, cachePtr, label_mindistance, priority, l);
                 } else {
-                  if(labelPtr->force == MS_OFF) {
-                    /* check for collisions inside the label group unless the label is FORCE GROUP */
-                      break; /* collision within the group */
-                  tmppoly = cachePtr->poly;
-                  /* TODO: in case we have leader lines and multiple labels, there's no use in testing for labelcache collisions
-                   * once a first collision has been found. we only need to know that the label group has collided, and the
-                   * poly of the whole label group: if(label_group) testLabelCacheCollisions */
-                  labelPtr->status = msTestLabelCacheCollisions(map, cachePtr, label_mindistance, priority, l);
-                  cachePtr->poly = tmppoly;
               } /* end POSITION AUTO vs Fixed POSITION */
-              if(!labelPtr->status && classPtr->leader.maxdistance == 0) {
+              if((!labelPtr->status || !label_marker_status) && classPtr->leader.maxdistance == 0) {
                 break; /* no point looking at more labels, unless their is a leader defined, in which
                 case we still want to compute the full cachePtr->poly to be used for offset tests */
+                labelPtr->status = MS_OFF;
               } else {
+                 if(labelPtr->annotext) {
+                    msAddLine(cachePtr->poly, metrics_poly.line);
+                    msAddLine(cachePtr->poly, marker_poly.line);
+                 if(!label_marker_status)
+                 fastComputeBounds(cachePtr->poly);
             } /* next label in the group */
@@ -3052,7 +3087,7 @@
                msDrawText(image, labelPtr->annopoint, labelPtr->annotext, labelPtr, &(map->fontset), layerPtr->scalefactor); /* actually draw the label */
             styleObj tstyle;
             static int foo =0;
             if(!foo) {
@@ -3067,10 +3102,10 @@
             tstyle.color.blue =random()%255;
             msDrawLineSymbol(&map->symbolset, image, cachePtr->poly, &tstyle, layerPtr->scalefactor);
           } /* end else */
         } /* next label(group) from cacheslot */
-        msFreeShape(&poly); /* clean up label polygon */
         msDrawOffsettedLabels(image, map, priority);
       } /* next priority */
