[mapserver-commits] r13197 - trunk/mapserver/mapcache/lib
Fri Mar 2 09:58:14 EST 2012
Author: hobu
Date: 2012-03-02 06:58:14 -0800 (Fri, 02 Mar 2012)
New Revision: 13197
   trunk/mapserver/mapcache/lib/source_mapserver.c
clean up patch for #4219 -- no need to copy strings around
Modified: trunk/mapserver/mapcache/lib/source_mapserver.c
--- trunk/mapserver/mapcache/lib/source_mapserver.c	2012-03-02 14:53:23 UTC (rev 13196)
+++ trunk/mapserver/mapcache/lib/source_mapserver.c	2012-03-02 14:58:14 UTC (rev 13197)
@@ -52,22 +52,14 @@
    if(!origmap) {
       msWriteError(stderr);
       errors = msGetErrorObj();
-      char* msg = (char*) msSmallMalloc(MESSAGELENGTH+1);
-      msg = msStrdup(errors->message);
-      ctx->set_error(ctx,500,"Failed to load mapfile '%s'. Mapserver reports: ",mapserver->mapfile, msg);
-      msFree(msg);
+      ctx->set_error(ctx,500,"Failed to load mapfile '%s'. Mapserver reports: ",mapserver->mapfile, errors->message);
       return;
    mapObj *omap = msNewMapObj();
    msCopyMap(omap,origmap);
    if (msLoadProjectionString(&(omap->projection), map->grid_link->grid->srs) != 0) {
-      ctx->set_error(ctx,500, "Unable to set projection on mapObj. MapServer reports: %s", msg);
-      msFree(msg);
+      ctx->set_error(ctx,500, "Unable to set projection on mapObj. MapServer reports: %s", errors->message);
       return;
    switch(map->grid_link->grid->unit) {
@@ -101,11 +93,7 @@
    imageObj *image = msDrawMap(omap, MS_FALSE);
    if(!image) {
-      ctx->set_error(ctx,500, "MapServer failed to create image. MapServer reports: %s", msg);
-      msFree(msg);
+      ctx->set_error(ctx,500, "MapServer failed to create image. MapServer reports: %s", errors->message);
       msFreeMap(omap);
       return;
