[mapserver-commits] r13200 - in trunk/mapserver/mapcache: . apache lib
Mon Mar 5 08:40:52 EST 2012
Author: tbonfort
Date: 2012-03-05 05:40:51 -0800 (Mon, 05 Mar 2012)
New Revision: 13200
   trunk/mapserver/mapcache/apache/mod_mapcache.c
   trunk/mapserver/mapcache/lib/cache_sqlite.c
   trunk/mapserver/mapcache/mapcache.xml
don't fork an apache process with runtime user rights as this is non-portable. Instead make sure that the different caches do not need an initialization step before being functional (#4215)
Modified: trunk/mapserver/mapcache/apache/mod_mapcache.c
--- trunk/mapserver/mapcache/apache/mod_mapcache.c	2012-03-04 20:30:24 UTC (rev 13199)
+++ trunk/mapserver/mapcache/apache/mod_mapcache.c	2012-03-05 13:40:51 UTC (rev 13200)
@@ -317,9 +317,6 @@
    mapcache_server_cfg* cfg = ap_get_module_config(s->module_config, &mapcache_module);
    server_rec *sconf;
    apr_status_t rv;
-#if APR_HAS_FORK
-   apr_proc_t proc;
-#endif
    mapcache_context *ctx = (mapcache_context*)apache_server_context_create(s,p);
    if(!cfg) {
@@ -331,77 +328,6 @@
    ap_add_version_component(p, MAPCACHE_USERAGENT);
 #endif
-#if APR_HAS_FORK
-   /* fork a child process to let it accomplish post-configuration tasks with the uid of the runtime user */
-   rv = apr_proc_fork(&proc, ptemp);
-   if (rv == APR_INCHILD) {
-#define ap_unixd_setup_child unixd_setup_child
-      ap_unixd_setup_child();
-      mapcache_context *ctx = (mapcache_context*)apache_server_context_create(s,p);
-      for (sconf = s; sconf; sconf = sconf->next) {
-         mapcache_server_cfg* config = ap_get_module_config(sconf->module_config, &mapcache_module);
-         if(config->aliases) {
-            apr_hash_index_t *entry = apr_hash_first(ptemp,config->aliases);
-            /* loop through the configured configurations */
-            while (entry) {
-               const char *alias;
-               apr_ssize_t aliaslen;
-               mapcache_cfg *c;
-               apr_hash_this(entry,(const void**)&alias,&aliaslen,(void**)&c);
-               mapcache_configuration_post_config(ctx, c);
-               if(GC_HAS_ERROR(ctx)) {
-                  ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "post config for %s failed: %s", alias,
-                        ctx->get_error_message(ctx));
-                  exit(APR_EGENERAL);
-               entry = apr_hash_next(entry);
-      exit(0);
-   } else if (rv == APR_INPARENT) {
-      apr_exit_why_e exitwhy;
-      int exitcode;
-      apr_proc_wait(&proc,&exitcode,&exitwhy,APR_WAIT);
-      if(exitwhy != APR_PROC_EXIT) {
-         ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "mapcache post-config child terminated abnormally");
-         return APR_EGENERAL;
-      } else {
-         if(exitcode != 0) {
-      return OK;
-   } else {
-      ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "failed to fork mapcache post-config child");
-#else /* APR_HAS_FORK */
-         while (entry) {
-            mapcache_cfg *c;
-   return OK;
-#endif
    rv = ap_mpm_query(AP_MPMQ_IS_THREADED,&is_threaded);
@@ -530,6 +456,10 @@
       return ctx->get_error_message(ctx);
+   mapcache_configuration_post_config(ctx, config);
+   if(GC_HAS_ERROR(ctx)) {
+      return ctx->get_error_message(ctx);
    ap_log_error(APLOG_MARK, APLOG_INFO, 0, cmd->server, "loaded mapcache configuration file from %s on alias %s", config->configFile, alias);
    if(!sconfig->aliases) {
       sconfig->aliases = apr_hash_make(cmd->pool);
Modified: trunk/mapserver/mapcache/lib/cache_sqlite.c
--- trunk/mapserver/mapcache/lib/cache_sqlite.c	2012-03-04 20:30:24 UTC (rev 13199)
+++ trunk/mapserver/mapcache/lib/cache_sqlite.c	2012-03-05 13:40:51 UTC (rev 13200)
@@ -83,13 +83,36 @@
    if(readonly) {
       flags = SQLITE_OPEN_READONLY;
    } else {
-      flags = SQLITE_OPEN_READWRITE|SQLITE_OPEN_CREATE;
+      flags = SQLITE_OPEN_READWRITE;
    dbfile = _get_dbname(ctx,tile->tileset, tile->grid_link->grid);
    ret = sqlite3_open_v2(dbfile,&handle,flags,NULL);
    if(ret != SQLITE_OK) {
-      ctx->set_error(ctx,500,"failed to connect to sqlite db %s: %s",dbfile,sqlite3_errmsg(handle));
-      return NULL;
+      /* maybe the database file doesn't exist yet. so we create it and setup the schema */
+      mapcache_cache_sqlite *cache = (mapcache_cache_sqlite*)tile->tileset->cache;
+      ret = sqlite3_open_v2(dbfile, &handle,SQLITE_OPEN_READWRITE|SQLITE_OPEN_CREATE,NULL);
+      if (ret != SQLITE_OK) {
+         ctx->set_error(ctx, 500, "sqlite backend failed to open db %s: %s", dbfile, sqlite3_errmsg(handle));
+         sqlite3_close(handle);
+         return NULL;
+      ret = sqlite3_exec(handle, cache->create_stmt.sql, 0, 0, NULL);
+      if(ret != SQLITE_OK) {
+         ctx->set_error(ctx, 500, "sqlite backend failed to create db schema on %s: %s",dbfile, sqlite3_errmsg(handle));
+         return NULL;
+      /* re-open the db read-only if that's what we were asked for */
+      if(readonly) {
+         ret = sqlite3_open_v2(dbfile,&handle,flags,NULL);
+            ctx->set_error(ctx, 500, "sqlite backend failed to re-open freshly created db %s readonly: %s",dbfile, sqlite3_errmsg(handle));
+            return NULL;
    sqlite3_busy_timeout(handle,300000);
    return handle;
@@ -294,40 +317,6 @@
 static void _mapcache_cache_sqlite_configuration_post_config(mapcache_context *ctx,
       mapcache_cache *cache, mapcache_cfg *cfg) {
-   mapcache_cache_sqlite *dcache = (mapcache_cache_sqlite*)cache;
-   sqlite3 *db;
-   char *errmsg;
-   int ret;
-   apr_hash_index_t *tileindex_index = apr_hash_first(ctx->pool,cfg->tilesets);
-   while(tileindex_index) {
-      mapcache_tileset *tileset;
-      const void *key; apr_ssize_t keylen;
-      apr_hash_this(tileindex_index,&key,&keylen,(void**)&tileset);
-      if(!strcmp(tileset->cache->name,cache->name)) {
-         int i;
-         for(i=0;i<tileset->grid_links->nelts;i++) {
-            mapcache_grid_link *gridlink = APR_ARRAY_IDX(tileset->grid_links,i,mapcache_grid_link*);
-            mapcache_grid *grid = gridlink->grid;
-            char *dbname = _get_dbname(ctx,tileset,grid);
-            ret = sqlite3_open(dbname, &db);
-            if(ret != SQLITE_OK) {
-               ctx->set_error(ctx,500,"sqlite backend failed to open db %s: %s",dbname,sqlite3_errmsg(db));
-               sqlite3_close(db);
-               return;
-            ret = sqlite3_exec(db, dcache->create_stmt.sql, 0, 0, &errmsg);
-               ctx->set_error(ctx,500,"sqlite backend failed to create tiles table: %s",sqlite3_errmsg(db));
-               return;
-      tileindex_index = apr_hash_next(tileindex_index);
Modified: trunk/mapserver/mapcache/mapcache.xml
--- trunk/mapserver/mapcache/mapcache.xml	2012-03-04 20:30:24 UTC (rev 13199)
+++ trunk/mapserver/mapcache/mapcache.xml	2012-03-05 13:40:51 UTC (rev 13200)
@@ -7,6 +7,9 @@
       <base>/tmp</base>
       <symlink_blank/>
    </cache>
+   <cache name="sqlite" type="sqlite3">
+      <base>/tmp</base>
+   </cache>
    <source name="vmap0" type="wms">
       <getmap>
@@ -26,7 +29,7 @@
    <tileset name="test">
       <source>vmap0</source>
-      <cache>disk</cache>
+      <cache>sqlite</cache>
       <grid>WGS84</grid>
       <grid>g</grid>
       <format>PNG</format>
