[mapserver-commits] r13204 - sandbox/tb-labels
Tue Mar 6 06:20:38 EST 2012
Author: tbonfort
Date: 2012-03-06 03:20:38 -0800 (Tue, 06 Mar 2012)
New Revision: 13204
   sandbox/tb-labels/mapdraw.c
   sandbox/tb-labels/maprendering.c
   sandbox/tb-labels/mapsymbol.c
fix usage of msGetMarkerSize from labelcache (#4225)
Modified: sandbox/tb-labels/mapdraw.c
--- sandbox/tb-labels/mapdraw.c	2012-03-06 10:57:46 UTC (rev 13203)
+++ sandbox/tb-labels/mapdraw.c	2012-03-06 11:20:38 UTC (rev 13204)
@@ -2649,19 +2649,6 @@
             style->symbol < map->symbolset.numsymbols && style->symbol > 0) {
          double sx,sy;
          symbolObj *symbol = map->symbolset.symbol[style->symbol];
-         if (symbol->type == MS_SYMBOL_PIXMAP) {
-            if (MS_SUCCESS != msPreloadImageSymbol(MS_MAP_RENDERER(map), symbol))
-               return MS_FAILURE;
-         } else if (symbol->type == MS_SYMBOL_SVG) {
-#ifdef USE_SVG_CAIRO
-            if (MS_SUCCESS != msPreloadSVGSymbol(symbol))
-#else
-            msSetError(MS_SYMERR, "SVG symbol support is not enabled.", "msDrawShape()");
-#endif
          if(msGetMarkerSize(&map->symbolset, style, &sx, &sy, layerPtr->scalefactor) != MS_SUCCESS)
             return MS_FAILURE;
          pointObj *point = markerPoly->line[0].point;
Modified: sandbox/tb-labels/maprendering.c
--- sandbox/tb-labels/maprendering.c	2012-03-06 10:57:46 UTC (rev 13203)
+++ sandbox/tb-labels/maprendering.c	2012-03-06 11:20:38 UTC (rev 13204)
@@ -812,39 +812,41 @@
          symbolObj *symbol = symbolset->symbol[style->symbol];
          /* store a reference to the renderer to be used for freeing */
          symbol->renderer = renderer;
-         switch (symbol->type)
-	   case (MS_SYMBOL_TRUETYPE): {
-	     if(!symbol->full_font_path)
-               symbol->full_font_path =  msStrdup(msLookupHashTable(&(symbolset->fontset->fonts),
-								    symbol->font));
-	     if(!symbol->full_font_path) {
-               msSetError(MS_MEMERR,"allocation error", "msDrawMarkerSymbol()");
-	     break;
-	   case (MS_SYMBOL_PIXMAP): {
-	     if(!symbol->pixmap_buffer) {
-               if(MS_SUCCESS != msPreloadImageSymbol(renderer,symbol))
-	     break;
-	   case (MS_SYMBOL_SVG): {
+         switch (symbol->type) {
+	         case (MS_SYMBOL_TRUETYPE):
+               if (!symbol->full_font_path)
+                  symbol->full_font_path = msStrdup(msLookupHashTable(&(symbolset->fontset->fonts),
+                       symbol->font));
+               if (!symbol->full_font_path) {
+                  msSetError(MS_MEMERR, "allocation error", "msDrawMarkerSymbol()");
+                  return MS_FAILURE;
+            break;
+            case (MS_SYMBOL_PIXMAP):
+               if (!symbol->pixmap_buffer) {
+                  if (MS_SUCCESS != msPreloadImageSymbol(renderer, symbol))
+            break;
+            case (MS_SYMBOL_SVG):
-	     if(!symbol->svg_cairo_surface) {
-	       if(MS_SUCCESS != msPreloadSVGSymbol(symbol))
+               if (!symbol->svg_cairo_surface) {
+                  if (MS_SUCCESS != msPreloadSVGSymbol(symbol))
 #else
-	     msSetError(MS_SYMERR, "SVG symbol support is not enabled.", "msDrawMarkerSymbol()");
+               msSetError(MS_SYMERR, "SVG symbol support is not enabled.", "msDrawMarkerSymbol()");
 #endif
-	   break;
+            break;
          s.style = style;
          computeSymbolStyle(&s,style,symbol,scalefactor);
Modified: sandbox/tb-labels/mapsymbol.c
--- sandbox/tb-labels/mapsymbol.c	2012-03-06 10:57:46 UTC (rev 13203)
+++ sandbox/tb-labels/mapsymbol.c	2012-03-06 11:20:38 UTC (rev 13204)
@@ -681,9 +681,9 @@
 #endif
   case(MS_SYMBOL_PIXMAP):
-        msSetError(MS_MISCERR,"msGetMarkerSize() called on unloaded pixmap symbol, this is a bug in mapserver itself","msGetMArkerSize()");
+       if (MS_SUCCESS != msPreloadImageSymbol(MS_MAP_RENDERER(symbolset->map), symbol))
     if(size == 1) {
       *width = MS_MAX(*width, symbol->pixmap_buffer->width);
