[mapserver-commits] r13235 - branches/branch-6-0/docs/en/ogc trunk/docs/en/ogc
Tue Mar 13 07:50:21 EDT 2012
Author: havatv
Date: 2012-03-13 04:50:21 -0700 (Tue, 13 Mar 2012)
New Revision: 13235
   branches/branch-6-0/docs/en/ogc/sos_server.txt
   trunk/docs/en/ogc/sos_server.txt
Arranged metadata terms in alphabetical order - sos server document
Modified: branches/branch-6-0/docs/en/ogc/sos_server.txt
--- branches/branch-6-0/docs/en/ogc/sos_server.txt	2012-03-13 11:32:54 UTC (rev 13234)
+++ branches/branch-6-0/docs/en/ogc/sos_server.txt	2012-03-13 11:50:21 UTC (rev 13235)
@@ -441,16 +441,6 @@
 .. index::
-   triple: SOS; METADATA; ows_updatesequence
-**ows_updatesequence**
-- *Description:* (Optional) The updateSequence parameter can be used for
-  maintaining the consistency of a client cache of the contents of a service
-  metadata document. The parameter value can be an integer, a timestamp in
-  [ISO 8601:2000] format, or any other number or string.
-.. index::
    triple: SOS; METADATA; ows_language
 **ows_language**
@@ -475,6 +465,16 @@
   example of a valid schema tree.
 .. index::
+   triple: SOS; METADATA; ows_updatesequence
+**ows_updatesequence**
+- *Description:* (Optional) The updateSequence parameter can be used for
+  maintaining the consistency of a client cache of the contents of a service
+  metadata document. The parameter value can be an integer, a timestamp in
+  [ISO 8601:2000] format, or any other number or string.
+.. index::
    triple: SOS; METADATA; sos_abstract
 **sos_abstract**
@@ -483,14 +483,6 @@
   the server.
 .. index::
-   triple: SOS; METADATA; sos_keywordlist
-**sos_keywordlist**
-- *Description:* (Optional) A comma-separated list of keywords or keyword
-  phrases to help catalog searching.
-.. index::
    triple: SOS; METADATA; sos_accessconstraints
 **sos_accessconstraints**
@@ -529,6 +521,21 @@
 - *Description:* Optional contact Email address.
 .. index::
+   triple: SOS; METADATA; sos_contactfacsimiletelephone
+**sos_contactfacsimiletelephone**
+- *Description:* Optional contact facsimile telephone number.
+.. index::
+   triple: SOS; METADATA; sos_contactinstructions
+**sos_contactinstructions**
+- *Description:* (Optional) Supplemental instructions on how or when
+  to contact the individual or organization.
+.. index::
    triple: SOS; METADATA; sos_contactorganization
 .. index::
@@ -550,13 +557,6 @@
 - *Description:* Optional contact voice telephone number.
 .. index::
-   triple: SOS; METADATA; sos_contactfacsimiletelephone
-**sos_contactfacsimiletelephone**
-- *Description:* Optional contact facsimile telephone number.
-.. index::
    triple: SOS; METADATA; sos_enable_request
 **sos_enable_request** (or **ows_enable_request**)
@@ -583,63 +583,63 @@
     "sos_enable_request" "* !GetCapabilities"
 .. index::
-   triple: SOS; METADATA; sos_fees
+   triple: SOS; METADATA; sos_encoding_blockSeparator
-**sos_fees**
+**sos_encoding_blockSeparator**
-- *Description:* (Optional) Fees information. Use the reserved word
-  "none" if there are no fees.
+- *Description:* (Optional) For GetObservation requests using
+  resultModel=om:Observation (SWE DataBlock encoding).  Record
+  separator to be used.  Default is '\\n'
 .. index::
-   triple: SOS; METADATA; sos_onlineresource
+   triple: SOS; METADATA; sos_encoding_tokenSeparator
-**sos_onlineresource**
+**sos_encoding_tokenSeparator**
-- *Description:* (Required) The URL that will be used to access this
-  OGC server.  This value is used in the GetCapabilities response.
-- See the section "Onlineresource URL" above for more information.
+  resultModel=om:Observation (SWE DataBlock encoding).  Token (field)
+  separator to be used.  Default is ','
 .. index::
-   triple: SOS; METADATA; sos_service_onlineresource
+   triple: SOS; METADATA; sos_fees
-**sos_service_onlineresource**
+**sos_fees**
-- *Description:* (Optional) Top-level onlineresource URL.
+- *Description:* (Optional) Fees information. Use the reserved word
+  "none" if there are no fees.
 .. index::
-   triple: SOS; METADATA; sos_srs
+   triple: SOS; METADATA; sos_hoursofservice
-**sos_srs**
+**sos_hoursofservice**
-- *Description:* (Required) Contains a list of EPSG projection codes
-  that should be advertized as being available for all layers in this
-  server. The value can contain one or more EPSG:<code> pairs
-  separated by spaces (e.g. "EPSG:4269 EPSG:4326") This value should
-  be upper case (EPSG:42304.....not epsg:42304) to avoid problems with
-  case sensitive platforms.
+- *Description:* (Optional) Time period (including time zone) when
+  individuals can contact the organization or individual.
-.. index::
-   triple: SOS; METADATA; sos_title
+.. index::
+   triple: SOS; METADATA; sos_keywordlist
-**sos_title**
+**sos_keywordlist**
-- *Description:* (Recommended) A human-readable name for this Layer.
+- *Description:* (Optional) A comma-separated list of keywords or keyword
+  phrases to help catalog searching.
 .. index::
-   triple: SOS; METADATA; sos_hoursofservice
+   triple: SOS; METADATA; sos_maxfeatures
-**sos_hoursofservice**
+**sos_maxfeatures**
-- *Description:* (Optional) Time period (including time zone) when
-  individuals can contact the organization or individual.
+- *Description:* (Optional) The number of elements to be returned by
+  the SOS server. If the not set all observations are returned
 .. index::
-   triple: SOS; METADATA; sos_contactinstructions
+   triple: SOS; METADATA; sos_onlineresource
-**sos_contactinstructions**
+**sos_onlineresource**
-- *Description:* (Optional) Supplemental instructions on how or when
-  to contact the individual or organization.
+- *Description:* (Required) The URL that will be used to access this
+  OGC server.  This value is used in the GetCapabilities response.
+- See the section "Onlineresource URL" above for more information.
 .. index::
    triple: SOS; METADATA; sos_role
@@ -651,30 +651,30 @@
   meanings listed in Subclause B.5.5 of ISO 19115:2003.
 .. index::
-   triple: SOS; METADATA; sos_maxfeatures
+   triple: SOS; METADATA; sos_service_onlineresource
-**sos_maxfeatures**
+**sos_service_onlineresource**
-- *Description:* (Optional) The number of elements to be returned by
-  the SOS server. If the not set all observations are returned
+- *Description:* (Optional) Top-level onlineresource URL.
 .. index::
-   triple: SOS; METADATA; sos_encoding_blockSeparator
+   triple: SOS; METADATA; sos_srs
-**sos_encoding_blockSeparator**
+**sos_srs**
-- *Description:* (Optional) For GetObservation requests using
-  resultModel=om:Observation (SWE DataBlock encoding).  Record
-  separator to be used.  Default is '\\n'
+- *Description:* (Required) Contains a list of EPSG projection codes
+  that should be advertized as being available for all layers in this
+  server. The value can contain one or more EPSG:<code> pairs
+  separated by spaces (e.g. "EPSG:4269 EPSG:4326") This value should
+  be upper case (EPSG:42304.....not epsg:42304) to avoid problems with
+  case sensitive platforms.
 .. index::
-   triple: SOS; METADATA; sos_encoding_tokenSeparator
+   triple: SOS; METADATA; sos_title
-**sos_encoding_tokenSeparator**
+**sos_title**
-  resultModel=om:Observation (SWE DataBlock encoding).  Token (field)
-  separator to be used.  Default is ','
+- *Description:* (Recommended) A human-readable name for this Layer.
 .. index::
    triple: SOS; LAYER; METADATA
@@ -701,7 +701,33 @@
     "sos_describesensor_url" "http://some/url/NS01EE0014.xml"
+.. index::
+   triple: SOS; METADATA; sos_enable_request
+**sos_enable_request** (or **ows_enable_request**)
+- *Description:* Space separated list of requests to enable.
+  The default is none.
+  The following requests can be enabled:
+  `GetCapabilities`, `GetObservation` and `DescribeSensor`.
+  A "!" in front of a request will disable the request.
+  "*" enables all requests.
+- *Examples:*
+  To enable only `GetCapabilities` and `GetObservation`:
+    "sos_enable_request" "GetCapabilities GetObservation"
+  To enable all requests except `GetCapabilities`
+    "sos_enable_request" "* !GetCapabilities"
 .. index::
    triple: SOS; METADATA; sos_[item name]_alias
@@ -727,33 +753,15 @@
 - *Description:* (Optional) An associated unit of measure URN) for a
   component, that will be returned when executing a GetObservation
   request.  Default is \"\urn:ogc:object:uom\"\
 .. index::
-   triple: SOS; METADATA; sos_enable_request
+   triple: SOS; METADATA; sos_observedproperty_authority
-**sos_enable_request** (or **ows_enable_request**)
+**sos_observedproperty_authority**
-- *Description:* Space separated list of requests to enable.
-  The default is none.
-  The following requests can be enabled:
-  `GetCapabilities`, `GetObservation` and `DescribeSensor`.
-  A "!" in front of a request will disable the request.
-  "*" enables all requests.
+- *Description:* (Optional) An associated authority for a given
+  component of an observed property
-- *Examples:*
-  To enable only `GetCapabilities` and `GetObservation`:
-    "sos_enable_request" "GetCapabilities GetObservation"
-  To enable all requests except `GetCapabilities`
-    "sos_enable_request" "* !GetCapabilities"
 .. index::
    triple: SOS; METADATA; sos_observedproperty_id
@@ -770,14 +778,6 @@
   string format.
 .. index::
-   triple: SOS; METADATA; sos_observedproperty_authority
-**sos_observedproperty_authority**
-- *Description:* (Optional) An associated authority for a given
-  component of an observed property
-.. index::
    triple: SOS; METADATA; sos_observedproperty_version
 **sos_observedproperty_version**
Modified: trunk/docs/en/ogc/sos_server.txt
--- trunk/docs/en/ogc/sos_server.txt	2012-03-13 11:32:54 UTC (rev 13234)
+++ trunk/docs/en/ogc/sos_server.txt	2012-03-13 11:50:21 UTC (rev 13235)
 .. index::
-.. index::
 **ows_language**
 .. index::
+.. index::
 **sos_abstract**
   the server.
 .. index::
-.. index::
 .. index::
+.. index::
+.. index::
 .. index::
 .. index::
-.. index::
 .. index::
-**sos_fees**
 .. index::
 .. index::
+**sos_fees**
 .. index::
-**sos_srs**
-.. index::
+.. index::
-**sos_title**
 .. index::
 .. index::
 .. index::
 .. index::
 .. index::
+**sos_srs**
 .. index::
+**sos_title**
 .. index::
+.. index::
+- *Examples:*
 .. index::
 .. index::
-- *Examples:*
 .. index::
   string format.
 .. index::
-.. index::
