[mapserver-commits] r13240 - trunk/docs/en/mapfile/symbology
Tue Mar 13 15:48:22 EDT 2012
Author: havatv
Date: 2012-03-13 12:48:22 -0700 (Tue, 13 Mar 2012)
New Revision: 13240
   trunk/docs/en/mapfile/symbology/construction.txt
Small fix to the symbol construction document (mixing of SIZE and WIDTH)
Modified: trunk/docs/en/mapfile/symbology/construction.txt
--- trunk/docs/en/mapfile/symbology/construction.txt	2012-03-13 13:03:40 UTC (rev 13239)
+++ trunk/docs/en/mapfile/symbology/construction.txt	2012-03-13 19:48:22 UTC (rev 13240)
@@ -1,4 +1,4 @@
-.. index::
+MACS .. index::
    single: Symbol construction
 .. _sym_construction:
@@ -1385,67 +1385,67 @@
 .. table:: Hatches
-   | :ref:`class` definitions       |
-   |.. code-block:: mapfile         |
-   |  LAYER # hatch                 |
-   |   CLASS                        |
-   |    STYLE                       |
-   |      SYMBOL "hatchsymbol"      |
-   |      COLOR 0 0 0               |
-   |      SIZE 10                   |
-   |    END # STYLE                 |
-   |   END # CLASS                  |
-   |  END # LAYER                   |
-   |  LAYER # hatch with angle      |
-   |   CLASS                        |
-   |    STYLE                       |
-   |      COLOR 0 0 0               |
-   |      WIDTH 10                  |
-   |      SIZE 3                    |
-   |      ANGLE 45                  |
-   |      PATTERN 20 10 10 10 END   |
-   |    END # STYLE                 |
-   |   END # CLASS                  |
-   |  END # LAYER                   |
-   |  LAYER # hatch with wide lines |
-   |   CLASS                        |
-   |    STYLE                       |
-   |      COLOR 0 0 0               |
-   |      SIZE 10                   |
-   |      WIDTH 5                   |
-   |    END # STYLE                 |
-   |   END # CLASS                  |
-   |  END # LAYER                   |
-   |  LAYER # cross hatch           |
-   |   CLASS                        |
-   |    STYLE                       |
-   |      COLOR 255 153 0           |
-   |      SIZE 10                   |
-   |      WIDTH 4                   |
-   |    END # STYLE                 |
-   |    STYLE                       |
-   |      COLOR 0 0 255             |
-   |      SIZE 20                   |
-   |      ANGLE 90                  |
-   |    END # STYLE                 |
-   |   END # CLASS                  |
-   |  END # LAYER                   |
+   | :ref:`class` definitions              |
+   |.. code-block:: mapfile                |
+   |  LAYER # hatch                        |
+   |   CLASS                               |
+   |    STYLE                              |
+   |      SYMBOL "hatchsymbol"             |
+   |      COLOR 0 0 0                      |
+   |      SIZE 10                          |
+   |    END # STYLE                        |
+   |   END # CLASS                         |
+   |  END # LAYER                          |
+   |  LAYER # hatch with angle and pattern |
+   |   CLASS                               |
+   |    STYLE                              |
+   |      COLOR 0 0 0                      |
+   |      SIZE 10                          |
+   |      WIDTH 3                          |
+   |      ANGLE 45                         |
+   |      PATTERN 20 10 10 10 END          |
+   |    END # STYLE                        |
+   |   END # CLASS                         |
+   |  END # LAYER                          |
+   |  LAYER # hatch with wide lines        |
+   |   CLASS                               |
+   |    STYLE                              |
+   |      COLOR 0 0 0                      |
+   |      SIZE 10                          |
+   |      WIDTH 5                          |
+   |    END # STYLE                        |
+   |   END # CLASS                         |
+   |  END # LAYER                          |
+   |  LAYER # cross hatch                  |
+   |   CLASS                               |
+   |    STYLE                              |
+   |      COLOR 255 153 0                  |
+   |      SIZE 10                          |
+   |      WIDTH 4                          |
+   |    END # STYLE                        |
+   |    STYLE                              |
+   |      COLOR 0 0 255                    |
+   |      SIZE 20                          |
+   |      ANGLE 90                         |
+   |    END # STYLE                        |
+   |   END # CLASS                         |
+   |  END # LAYER                          |
 .. index::
