[mapserver-commits] r13242 - branches/branch-6-0/docs/en/installation trunk/docs/en/installation
Tue Mar 13 17:23:00 EDT 2012
Author: havatv
Date: 2012-03-13 14:22:59 -0700 (Tue, 13 Mar 2012)
New Revision: 13242
   branches/branch-6-0/docs/en/installation/dotnet.txt
   trunk/docs/en/installation/dotnet.txt
Fixed some too long lines in the generated PDF file - dotnet (#3947).
Modified: branches/branch-6-0/docs/en/installation/dotnet.txt
--- branches/branch-6-0/docs/en/installation/dotnet.txt	2012-03-13 20:08:12 UTC (rev 13241)
+++ branches/branch-6-0/docs/en/installation/dotnet.txt	2012-03-13 21:22:59 UTC (rev 13242)
@@ -34,12 +34,10 @@
 Command Prompt and step into the /mapscript/csharp directory. Edit makefile.vc
 and set the SWIG variable to the location of your swig.exe
-Use
+Use::
+  nmake -f makefile.vc
-    nmake -f makefile.vc
 to compile mapscript.dll and mapscript_csharp.dll.
@@ -51,11 +49,9 @@
 Prompt and step into the /mapscript/csharp directory Edit makefile.vc and set
 the SWIG variable to the location of your swig.exe.
-Use
+Use::
@@ -64,63 +60,51 @@
 Before the compilation you should download and install the recent mono
 Win32 setup package (eg. mono-1.1.13.2-gtksharp-2.8.1-win32-1.exe) Edit makefile.vc
 and set the CSC variable to the location of your mcs.exe. Alternatively
-you can define
+you can define::
+  MONO = YES
-    MONO = YES
 in your nmake.opt file.
 You should use the same compiler for compiling MapScript as the compiler has
 been used for the MapServer compilation. To compile MapScript open the Command
-Prompt supplied with your compiler and use
+Prompt supplied with your compiler and use::
 Alternative compilation methods on Windows
 Beginning from MapServer 4.8.3 you can invoke the C# compilation from the
-MapServer directory by uncommenting DOT_NET in nmake.opt
+MapServer directory by uncommenting DOT_NET in nmake.opt::
+  # .NET/C# MapScript
+  # .NET will of course only work with MSVC 7.0 and 7.1.  Also note that
+  # you will definitely want USE_THREAD defined.
+  #DOT_NET = YES
-# .NET/C# MapScript
-# .NET will of course only work with MSVC 7.0 and 7.1.  Also note that
-# you will definitely want USE_THREAD defined.
-#DOT_NET = YES
+and invoking the compilation by::
-and invoking the compilation by
+  nmake -f makefile.vc csharp
+You can also use::
-    nmake -f makefile.vc csharp
+  nmake -f makefile.vc install
-You can also use
-    nmake -f makefile.vc install
 for making the compilation an copying the targets into a common output
 directory.
 Testing the compilation
-For testing the compilation and the runtime environment you can use
+For testing the compilation and the runtime environment you can use::
+  nmake -f makefile.vc test
-      nmake -f makefile.vc test
 within the csharp directory for starting the sample applications compiled
 previously. Before making the test the location of the corresponding libraries
 should be included in the system PATH.
@@ -139,20 +123,16 @@
 mapscript/csharp/Makefile will be created according to the configuration
 options. Edit this file and set the SWIG and CSC for the corresponding
 executable pathes if the files could not be accessed by default. To
-compile at a console step into the /mapscript/csharp directory use.
+compile at a console step into the /mapscript/csharp directory use::
-      make
+  make
 to compile libmapscript.so and mapscript_csharp.dll.
+  make test
-      make test
 for starting the sample applications compiled previously.
 OSX compilation targeting the MONO framework
@@ -166,20 +146,16 @@
 executable pathes if the files could not be accessed by default. To compile
-at a console step into the /mapscript/csharp directory use
+at a console step into the /mapscript/csharp directory use::
-      make
+  make
 to compile libmapscript.dylib and mapscript_csharp.dll.
+  make test
-      make test
 To run the applications mapscript_csharp.dll.config is needed along with the
@@ -199,27 +175,34 @@
 If you have compiled MapServer for using the CRT libraries and you are using
 the MS.NET framework 2.0 as the execution runtime you should supply a proper
-manifest file along with your executable, like:
+manifest file along with your executable, like::
+  <?xml version="1.0" encoding="utf-8"?>
+  <assembly xsi:schemaLocation="urn:schemas-microsoft-com:asm.v1
+   assembly.adaptive.xsd" manifestVersion="1.0"
+   xmlns:asmv1="urn:schemas-microsoft-com:asm.v1"
+   xmlns:asmv2="urn:schemas-microsoft-com:asm.v2"
+   xmlns:dsig="http://www.w3.org/2000/09/xmldsig#"
+   xmlns="urn:schemas-microsoft-com:asm.v1"
+   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
+  <assemblyIdentity name="drawmap.exe" version="1.0.0.0" type="win32" />
+  <dependency>
+  <dependentAssembly asmv2:dependencyType="install"
+   asmv2:codebase="Microsoft.VC80.CRT.manifest" asmv2:size="522">
+  <assemblyIdentity name="Microsoft.VC80.CRT" version="8.0.50608.0"
+   publicKeyToken="1fc8b3b9a1e18e3b" processorArchitecture="x86"
+   type="win32" />
+  <hash xmlns="urn:schemas-microsoft-com:asm.v2">
+  <dsig:Transforms>
+  <dsig:Transform Algorithm="urn:schemas-microsoft-com:HashTransforms.Identity" />
+  </dsig:Transforms>
+  <dsig:DigestMethod Algorithm="http://www.w3.org/2000/09/xmldsig#sha1" />
+  <dsig:DigestValue>UMOlhUBGeKRrrg9DaaPNgyhRjyM=</dsig:DigestValue>
+  </hash>
+  </dependentAssembly>
+  </dependency>
+  </assembly>
-<?xml version="1.0" encoding="utf-8"?>
-<assembly xsi:schemaLocation="urn:schemas-microsoft-com:asm.v1 assembly.adaptive.xsd" manifestVersion="1.0" xmlns:asmv1="urn:schemas-microsoft-com:asm.v1" xmlns:asmv2="urn:schemas-microsoft-com:asm.v2" xmlns:dsig="http://www.w3.org/2000/09/xmldsig#" xmlns="urn:schemas-microsoft-com:asm.v1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
-<assemblyIdentity name="drawmap.exe" version="1.0.0.0" type="win32" />
-<dependency>
-<dependentAssembly asmv2:dependencyType="install" asmv2:codebase="Microsoft.VC80.CRT.manifest" asmv2:size="522">
-<assemblyIdentity name="Microsoft.VC80.CRT" version="8.0.50608.0" publicKeyToken="1fc8b3b9a1e18e3b" processorArchitecture="x86" type="win32" />
-<hash xmlns="urn:schemas-microsoft-com:asm.v2">
-<dsig:Transforms>
-<dsig:Transform Algorithm="urn:schemas-microsoft-com:HashTransforms.Identity" />
-</dsig:Transforms>
-<dsig:DigestMethod Algorithm="http://www.w3.org/2000/09/xmldsig#sha1" />
-<dsig:DigestValue>UMOlhUBGeKRrrg9DaaPNgyhRjyM=</dsig:DigestValue>
-</hash>
-</dependentAssembly>
-</dependency>
-</assembly>
 This will inform the CLR that your exe depends on the CRT and the proper
 assembly wrapper is to be used. If you are using the IDE the manifest file
 could be pregenerated by adding a reference to Microsoft.VC80.CRT.manifest
@@ -232,37 +215,37 @@
 According to the windows makefile the MapScript compilation target
 (mapscript.dll) is linked with the /MD option. In this case the VS2005
 linker will generate a manifest file containing the unmanaged assembly
-dependency. The sample contents of the manifest file are:
+dependency. The sample contents of the manifest file are::
+  <?xml version='1.0' encoding='UTF-8' standalone='yes'?>
+  <assembly xmlns='urn:schemas-microsoft-com:asm.v1' manifestVersion='1.0'>
+  <dependency>
+  <dependentAssembly>
+  <assemblyIdentity type='win32' name='Microsoft.VC80.CRT'
+   version='8.0.50608.0' processorArchitecture='x86'
+   publicKeyToken='1fc8b3b9a1e18e3b' />
+  </dependency>
+  </assembly>
-<?xml version='1.0' encoding='UTF-8' standalone='yes'?>
-<assembly xmlns='urn:schemas-microsoft-com:asm.v1' manifestVersion='1.0'>
-<dependency>
-<dependentAssembly>
-<assemblyIdentity type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b' />
-</dependency>
-</assembly>
+Like previously mentioned if you are creating a windows application
+the common language runtime will search for a manifest file for the
+application.  The name of the manifest file should be the same as the
+executable append and end with the .manifest extension. However if the
+host process is not controlled by you (like web mapping applications
+using aspnet_wp.exe as the host process) you will not be certain if
+the host process (.exe) will have a manifest containing a reference to
+the CRT wrapper. In this case you may have to embed the manifest into
+the dll as a resource using the mt tool like::
-Like previously mentioned if you are creating a windows application the
-common language runtime will search for a manifest file for the application.
-The name of the manifest file should be the same as the executable append
-and end with the .manifest extension. However if the host process is not
-controlled by you (like web mapping applications using aspnet_wp.exe as
-the host process) you will not be certain if the host process (.exe) will
-have a manifest containing a reference to the CRT wrapper. In this case you
-may have to embed the manifest into the dll as a resource using the mt tool like:
+  mt /manifest mapscript.dll.manifest /outputresource:mapscript.dll;#2
- mt /manifest mapscript.dll.manifest /outputresource:mapscript.dll;#2
 the common language runtime will search for the embedded resource and load
 the CRT assembly properly.
-Normally it is enough to load the CRT with the root dll (mapscript.dll),
-but it is not harmful embedding the manifest into the dependent libraries as well.
+Normally it is enough to load the CRT with the root dll
+(mapscript.dll), but it is not harmful embedding the manifest into the
+dependent libraries as well.
 Issue with regex and Visual Studio 2005
@@ -279,13 +262,11 @@
 Using the MapScript interface created by the SWIG interface generator the
 communication between the C# wrapper classes (mapscript_csharp.dll) and the
-C code (mapscript.dll) takes place using platform invoke like:
+C code (mapscript.dll) takes place using platform invoke like::
+  [DllImport("mapscript", EntryPoint="CSharp_new_mapObj")]
+  public static extern IntPtr new_mapObj(string jarg1);
- [DllImport("mapscript", EntryPoint="CSharp_new_mapObj")]
- public static extern IntPtr new_mapObj(string jarg1);
 The DllImport declaration contains the library name, however to transform
 the library name into a file name is platform dependent. On Windows the library
 name is simply appended with the .dll extension (mapscript.dll). On the Unix
@@ -295,21 +276,17 @@
 Mapping of the library name may be manually controlled using a dll.config
 file. This simply maps the library file the DllImport is looking for to its
 unix equivalent. The file normally contains the following information
-(mapscript_csharp.dll.config):
+(mapscript_csharp.dll.config)::
+  <configuration>
+    <dllmap dll="mapscript" target="libmapscript.so" />
+  </configuration>
-<configuration>
-<dllmap dll="mapscript" target="libmapscript.so" />
-</configuration>
+and with the OSX builds::
-and with the OSX builds:
-<configuration>
-<dllmap dll="mapscript" target="libmapscript.dylib" />
-</configuration>
+  <configuration>
+    <dllmap dll="mapscript" target="libmapscript.dylib" />
+  </configuration>
 The file should be placed along with the corresponding mapscript_csharp.dll
 file, and created by default during the make process. For more information see:
@@ -325,12 +302,10 @@
 decimal separator is other than "." inside the locale of the process may cause
 parse errors when the mapfile contains float numbers. Since the MONO process
 takes over the locale settings of the environment it is worth considering to
-set the default locale to "C" of the host process, like:
+set the default locale to "C" of the host process, like::
+  LC_ALL=C mono ./drawmap.exe ../../tests/test.map test_csharp.png
- LC_ALL=C mono ./drawmap.exe ../../tests/test.map test_csharp.png
 Most frequent errors
@@ -340,16 +315,18 @@
 Unable to load dll (MapScript)
-You can get this problem on Windows and in most cases it can be dedicated to a
-missing or an unloadable shared library. The error message talks about
-mapscript.dll but surely one or more of the dll-s are missing that libmap.dll
-depends on. So firstly you might want to check for the dependencies of your
-libmap.dll in your application directory. You can use the Visual Studio
-Dependency Walker to accomplish this task. You can also use a file monitoring
-tool (like SysInternal's filemon) to detect the dll-s that could not be loaded.
-I propose to store all of the dll-s required by your application in the
-application folder. If you can run the drawmap C# sample application with
-your mapfile your compilation might be correct and all of the dlls are available.
+You can get this problem on Windows and in most cases it can be
+dedicated to a missing or an unloadable shared library. The error
+message talks about mapscript.dll but surely one or more of the dll-s
+are missing that libmap.dll depends on. So firstly you might want to
+check for the dependencies of your libmap.dll in your application
+directory. You can use the Visual Studio Dependency Walker to
+accomplish this task. You can also use a file monitoring tool (like
+SysInternal's filemon) to detect the dll-s that could not be loaded.
+I propose to store all of the dll-s required by your application in
+the application folder. If you can run the drawmap C# sample
+application with your mapfile your compilation might be correct and
+all of the dlls are available.
 You may find that the MapScript C# interface behaves differently for the
 desktop and the ASP.NET applications. Although you can run the drawmap sample
Modified: trunk/docs/en/installation/dotnet.txt
--- trunk/docs/en/installation/dotnet.txt	2012-03-13 20:08:12 UTC (rev 13241)
+++ trunk/docs/en/installation/dotnet.txt	2012-03-13 21:22:59 UTC (rev 13242)
@@ -34,12 +34,10 @@
-Use
+Use::
@@ -51,11 +49,9 @@
-Use
+Use::
@@ -64,63 +60,51 @@
-you can define
+you can define::
+  MONO = YES
-    MONO = YES
+  #DOT_NET = YES
-#DOT_NET = YES
+You can also use::
-You can also use
 directory.
-      make
+  make
+  make test
-      make test
-      make
+  make
+  make test
-      make test
+  <dependency>
+   type="win32" />
+  <dsig:Transforms>
+  </hash>
+  </dependency>
+  </assembly>
-<dependency>
-<dsig:Transforms>
-</dsig:Transforms>
-</hash>
-</dependency>
-</assembly>
+  <dependency>
+  </dependency>
+  </assembly>
-<dependency>
-</dependency>
-</assembly>
+  <configuration>
+  </configuration>
-<configuration>
-</configuration>
-<configuration>
-</configuration>
+  <configuration>
+  </configuration>
