[mapserver-commits] r13250 - trunk/mapserver
Wed Mar 14 09:21:36 EDT 2012
Author: tbonfort
Date: 2012-03-14 06:21:36 -0700 (Wed, 14 Mar 2012)
New Revision: 13250
   trunk/mapserver/mapcairo.c
   trunk/mapserver/mapdummyrenderer.c
   trunk/mapserver/mapgd.c
   trunk/mapserver/maplabel.c
   trunk/mapserver/maprendering.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapsymbol.c
Only do baseline adjustment on text, not on truetype symbols
Modified: trunk/mapserver/mapcairo.c
--- trunk/mapserver/mapcairo.c	2012-03-14 13:20:48 UTC (rev 13249)
+++ trunk/mapserver/mapcairo.c	2012-03-14 13:21:36 UTC (rev 13250)
@@ -456,7 +456,8 @@
 #define CAIROLINESPACE 1.33
-int getTruetypeTextBBoxCairo(rendererVTableObj *renderer, char **fonts, int numfonts, double size, char *text, rectObj *rect, double **advances) {
+int getTruetypeTextBBoxCairo(rendererVTableObj *renderer, char **fonts, int numfonts, double size,
+        char *text, rectObj *rect, double **advances, int bAdjustBaseline) {
     cairoCacheData *cache = MS_RENDERER_CACHE(renderer);
     faceCacheObj* face = getFontFace(cache,fonts[0]);
@@ -524,11 +525,11 @@
             rect->minx = px+extents.x_bearing;
             rect->miny = py+extents.y_bearing;
             rect->maxx = px+extents.x_bearing+extents.width;
-            rect->maxy = py+1;
+            rect->maxy = py+(bAdjustBaseline?1:(extents.y_bearing+extents.height));
         } else {
             rect->minx = MS_MIN(rect->minx,px+extents.x_bearing);
             rect->miny = MS_MIN(rect->miny,py+extents.y_bearing);
-            rect->maxy = MS_MAX(rect->maxy,py+1);
+            rect->maxy = MS_MAX(rect->maxy,py+(bAdjustBaseline?1:(extents.y_bearing+extents.height)));
             rect->maxx = MS_MAX(rect->maxx,px+extents.x_bearing+extents.width);
         if(advances!=NULL)
@@ -537,12 +538,6 @@
         previdx=glyph.index;
 	     prevface = face;
-    rect->minx = 0;
-    rect->miny = 0;
-    rect->maxx = 1;
-    rect->maxy = 1;
     return MS_SUCCESS;
Modified: trunk/mapserver/mapdummyrenderer.c
--- trunk/mapserver/mapdummyrenderer.c	2012-03-14 13:20:48 UTC (rev 13249)
+++ trunk/mapserver/mapdummyrenderer.c	2012-03-14 13:21:36 UTC (rev 13250)
@@ -166,7 +166,8 @@
 /* helper functions */
-int getTruetypeTextBBoxDummy(rendererVTableObj *renderer, char **fonts, int numfonts, double size, char *string,rectObj *rect, double **advances) {
+int getTruetypeTextBBoxDummy(rendererVTableObj *renderer, char **fonts, int numfonts, double size,
+        char *string,rectObj *rect, double **advances, int bAdjustBaseline) {
     msSetError(MS_RENDERERERR,"getTruetypeTextBBox not implemented","getTruetypeTextBBox()");
     return MS_FAILURE;
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c	2012-03-14 13:20:48 UTC (rev 13249)
+++ trunk/mapserver/mapgd.c	2012-03-14 13:21:36 UTC (rev 13250)
@@ -833,7 +833,7 @@
 	return MS_SUCCESS;
-int getTruetypeTextBBoxGD(rendererVTableObj *renderer, char **fonts, int numfonts, double size, char *string, rectObj *rect, double **advances) {
+int getTruetypeTextBBoxGD(rendererVTableObj *renderer, char **fonts, int numfonts, double size, char *string, rectObj *rect, double **advances, int bAdjustBaseline) {
 #ifdef USE_GD_FT
    int bbox[8];
    char *error;
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c	2012-03-14 13:20:48 UTC (rev 13249)
+++ trunk/mapserver/maplabel.c	2012-03-14 13:21:36 UTC (rev 13250)
@@ -965,13 +965,14 @@
 #endif
-int msGetTruetypeTextBBox(rendererVTableObj *renderer, char* fontstring, fontSetObj *fontset, double size, char *string, rectObj *rect, double **advances) {
+int msGetTruetypeTextBBox(rendererVTableObj *renderer, char* fontstring, fontSetObj *fontset,
+        double size, char *string, rectObj *rect, double **advances, int bAdjustbaseline) {
    char *lookedUpFonts[MS_MAX_LABEL_FONTS];
    int numfonts;
    if(MS_FAILURE == msFontsetLookupFonts(fontstring, &numfonts, fontset, lookedUpFonts))
       return MS_FAILURE;
    if(renderer) {
-      return renderer->getTruetypeTextBBox(renderer,lookedUpFonts,numfonts,size,string,rect,advances);
+      return renderer->getTruetypeTextBBox(renderer,lookedUpFonts,numfonts,size,string,rect,advances,bAdjustbaseline);
 #ifdef USE_GD_FT
 	else {
@@ -1140,7 +1141,7 @@
         msSetError(MS_MISCERR, "label has no true type font", "msGetLabelSize()");
         return MS_FAILURE;
-     return msGetTruetypeTextBBox(renderer,label->font,&(map->fontset),size,string,rect,advances);
+     return msGetTruetypeTextBBox(renderer,label->font,&(map->fontset),size,string,rect,advances,1);
   } else if(label->type == MS_BITMAP){
 	  if(renderer->supports_bitmap_fonts)
 		  return msGetRasterTextBBox(renderer,MS_NINT(label->size),string,rect);
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2012-03-14 13:20:48 UTC (rev 13249)
+++ trunk/mapserver/maprendering.c	2012-03-14 13:21:36 UTC (rev 13250)
@@ -326,7 +326,7 @@
    } else {
       rectObj rect;
       if(MS_SUCCESS != renderer->getTruetypeTextBBox(renderer,&symbol->full_font_path,1,style->scale,
-            symbol->character,&rect,NULL))
+            symbol->character,&rect,NULL,0))
          return MS_FAILURE;
       symbol_width=rect.maxx-rect.minx;
       symbol_height=rect.maxy-rect.miny;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2012-03-14 13:20:48 UTC (rev 13249)
+++ trunk/mapserver/mapserver.h	2012-03-14 13:21:36 UTC (rev 13250)
@@ -2028,7 +2028,7 @@
 MS_DLL_EXPORT int msFontsetLookupFonts(char* fontstring, int *numfonts, fontSetObj *fontset, char **lookedUpFonts);
 MS_DLL_EXPORT char *msTransformLabelText(mapObj *map, labelObj *label, char *text);
-MS_DLL_EXPORT int msGetTruetypeTextBBox(rendererVTableObj *renderer, char* fontstring, fontSetObj *fontset, double size, char *string, rectObj *rect, double **advances);
+MS_DLL_EXPORT int msGetTruetypeTextBBox(rendererVTableObj *renderer, char* fontstring, fontSetObj *fontset, double size, char *string, rectObj *rect, double **advances, int bAdjustBaseline);
 MS_DLL_EXPORT int msGetLabelSize(mapObj *map, labelObj *label, char *string, double size, rectObj *rect, double **advances);
@@ -2789,7 +2789,7 @@
-	int (*getTruetypeTextBBox)(rendererVTableObj *renderer, char **fonts, int numfonts, double size, char *string, rectObj *rect, double **advances);
+	int (*getTruetypeTextBBox)(rendererVTableObj *renderer, char **fonts, int numfonts, double size, char *string, rectObj *rect, double **advances, int bAdjustBaseline);
 	int (*startLayer)(imageObj *img, mapObj *map, layerObj *layer);
 	int (*endLayer)(imageObj *img, mapObj *map, layerObj *layer);
Modified: trunk/mapserver/mapsymbol.c
--- trunk/mapserver/mapsymbol.c	2012-03-14 13:20:48 UTC (rev 13249)
+++ trunk/mapserver/mapsymbol.c	2012-03-14 13:21:36 UTC (rev 13250)
@@ -675,7 +675,7 @@
 #ifdef USE_GD_FT
   case(MS_SYMBOL_TRUETYPE):
-    if(msGetTruetypeTextBBox(MS_MAP_RENDERER(symbolset->map),symbol->font,symbolset->fontset,size,symbol->character,&rect,NULL) != MS_SUCCESS)
+    if(msGetTruetypeTextBBox(MS_MAP_RENDERER(symbolset->map),symbol->font,symbolset->fontset,size,symbol->character,&rect,NULL,0) != MS_SUCCESS)
       return(MS_FAILURE);
     *width = MS_MAX(*width, rect.maxx - rect.minx);
