[mapserver-commits] r13282 - trunk/docs/en/ogc
Mon Mar 19 12:39:23 EDT 2012
Author: schpidi
Date: 2012-03-19 09:39:23 -0700 (Mon, 19 Mar 2012)
New Revision: 13282
Added:
   trunk/docs/en/ogc/inspire.txt
   trunk/docs/en/ogc/index.txt
Adding documentation for INSPIRE View Service.
Modified: trunk/docs/en/ogc/index.txt
--- trunk/docs/en/ogc/index.txt	2012-03-19 13:07:00 UTC (rev 13281)
+++ trunk/docs/en/ogc/index.txt	2012-03-19 16:39:23 UTC (rev 13282)
@@ -16,6 +16,7 @@
    ogc_support
    wms_server
+   inspire
    wms_client
    wms_time
    wms_dimension
Added: trunk/docs/en/ogc/inspire.txt
--- trunk/docs/en/ogc/inspire.txt	                        (rev 0)
+++ trunk/docs/en/ogc/inspire.txt	2012-03-19 16:39:23 UTC (rev 13282)
@@ -0,0 +1,352 @@
+.. index::
+   single: INSPIRE
+   single: INSPIRE View Service
+.. _inspire_view_service:
+ INSPIRE View Service
+:Author:       Stephan Meissl
+:Contact:      stephan.meissl at eox.at
+:Last Updated: 2012-03-19
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+INSPIRE is the name of an `European directive`_, establishing an infrastructure
+for spatial information in Europe to support Community environmental policies,
+and policies or activities which may have an impact on the environment.
+The INSPIRE View Service is an implementation of the `INSPIRE Technical
+Guidance document`_ on top of the :ref:`WCS_server` implementation explained in
+the previous chapter.
+In order to achieve INSPIRE View Service compliance, the following enhancements
+have been implemented in MapServer:
+- Activation of INSPIRE support (two scenarios)
+- Multi-language support for certain capabilities fields
+- Provision of INSPIRE specific metadata
+- Named group layers
+- Style section for root layer and possibly existing group layers
+Activation of INSPIRE support
+INSPIRE specific metadata can either be referenced in an external INSPIRE
+service metadata document (scenario 1) or can be directly embedded in the
+capabilities document (scenario 2). MapServer supports both scenarios.
+Activation of the corresponding scenario for INSPIRE support takes place in
+the ``WEB.METADATA`` section of the mapfile through
+``wms_inspire_capabilities``. If activated, the corresponding INSPIRE
+namespace as well as appropriate validation warnings are generated in the
+capabilities document.
+Scenario 1 - activate INSPIRE support using a reference to external service
+metadata::
+  WEB
+   METADATA
+    "wms_inspire_capabilities" "url"
+   END
+  END
+Scenario 2 - activate INSPIRE support using embedded service metadata::
+  WEB
+   METADATA
+    "wms_inspire_capabilities" "embed"
+   END
+  END
+Multi-language support for certain capabilities fields
+INSPIRE requires multi-language support and requests a list of all supported
+languages as well as the default language in the capabilities document. Based
+on the language parameter in the GetCapabilites request, certain specific
+metadata values, namely
+- ``wms_title``
+- ``wms_abstract``
+- ``wms_rootlayer_title``
+- ``wms_rootlayer_abstract``
+- ``wms_group_title``
+- ``wms_group_abstract``
+- ``wms_style_title``
+- ``wms_style_<name>_title``
+as well as language dependent reference data like
+- ``DATA "road_eng"``
+- ``CONNECTION "db_ger"``
+need to be provided in the requested language. If the language is not supported
+(or no language parameter is present), the default language has to be used.
+All supported languages have to be specified as comma separated list (first
+language is default) through ``wms_languages`` in the ``WEB.METADATA``
+section of the mapfile. This language parameter is also added to the
+``OnlineResource`` in the GetCapabilites output::
+  WEB
+   METADATA
+    "wms_languages" "eng,ger"       #first default, values according ISO 639-2/B
+   END
+  END
+For language specific metadata values, a key extension method is applied::
+  WEB
+   METADATA
+    "wms_title.eng" "myservicetitle"
+    "wms_title.ger" "myservicetitleger"
+    "wms_abstract" "mylayerabstract"        #fallback
+    "wms_abstract.ger" "mylayerabstractger"
+   END
+  END
+For language dependent reference data, a similar approach like the
+:ref:`run-time substitution <runsub>` feature of MapServer has been followed
+(only ``DATA`` and ``CONNECTION`` values with %language% are substituted)::
+    LAYER
+     NAME TN.RoadTransportNetwork.RoadLink
+     DATA "road_%language%"
+    END
+If the language is not supported (or no language parameter is present), the
+default language is substituted.
+Provision of INSPIRE specific metadata
+Depending on the scenario, additional metadata information is required to
+support the specification. The INSPIRE related fields are provided below.
+Scenario 1 - INSPIRE related fields using referenced external service metadata::
+  WEB
+   METADATA
+    "wms_inspire_metadataurl_href" "http://INSPIRE.service/metadata"
+    "wms_inspire_metadataurl_format" "application/vnd.ogc.csw.capabilities.response_xml"
+    "wms_keywordlist_ISO_items" "infoMapAccessService" #value according "classification of spatial data services"
+    "wms_keywordlist_vocabulary" "ISO"
+    "wms_title" "myservicetitle"
+    "wms_abstract" "myabstract"
+    "wms_fees" "conditions unknown"         #value either "no conditions apply"|default "conditions unknown"|<specific conditions>
+    "wms_accessconstraints" "None"          #value according ISO 19115 (MD_RestrictionCode codelist) or default "None"
+    "wms_contactorganization" "MapServer"   #responsible organization
+    "wms_contactposition" "owner"           #responsible organization, value according "INSPIRE Metadata Regulation" (part D6)
+   END
+  END
+Scenario 2 - INSPIRE related fields using embedded service metadata::
+  WEB
+   METADATA
+    "wms_inspire_temporal_reference" "2011-09-19" #date of last revision, value according YYYY-MM-DD
+    "wms_inspire_mpoc_name" "mympocname"    #point of contact
+    "wms_inspire_mpoc_email" "mympoc at e.mail" #point of contact
+    "wms_inspire_metadatadate" "2011-09-19" #value according YYYY-MM-DD
+    "wms_inspire_resourcelocator" "http://myinspireresource" #URL for ResourceLocator
+    "wms_inspire_keyword" "infoMapAccessService" #value according "classification of spatial data services"
+   END
+  END
+Notes:
+- several fields require certain values, these values are not validated by
+  MapServer itself, instead a manual validation against the `INSPIRE schemas`_
+  and the `WMS INSPIRE tester`_ is recommended
+- as suggested in this document_ regarding scenario 2,
+  ``<inspire_common:ResourceType>`` is always set to service and
+  ``<inspire_common:SpatialDataServiceType>`` is always set to view, both
+  values can't be altered through the mapfile
+- conformity is always set to not evaluated, based on the latest
+  `INSPIRE Metadata Implementing Rules`_ (page 7), a specification document,
+  the specification date and a specification URI or URL need to be provided for
+  degree conformant/not conformant, which is currently not implemented
+Named group layers
+INSPIRE mandates usage of named group layers. Thus the functionality of
+``wms_layer_group`` is extended to support named group layers. If a layer with
+the same name as used in ``wms_layer_group`` is found it is treated as named
+group and if no layer with this name is found as unnamed group as before.
+Provided that ability, a hierarchy of any level can be achieved. See for
+example the grouping used in the `wms_inspire.map`_ mapfile in msautotest::
+  TN
+  +--- TN.CommonTransportElements
+       +--- TN.CommonTransportElements.TransportArea
+       +--- TN.CommonTransportElements.TransportLink
+       +--- TN.CommonTransportElements.TransportNode
+  +--- TN.RoadTransportNetwork
+       +--- TN.RoadTransportNetwork.VehicleTrafficArea
+       +--- TN.RoadTransportNetwork.RoadServiceArea
+       +--- TN.RoadTransportNetwork.RoadArea
+  +--- TN.RailTransportNetwork
+       +--- TN.RailTransportNetwork.RailwayLink
+       +--- TN.RailTransportNetwork.RailwayStationArea
+       +--- TN.RailTransportNetwork.RailwayYardArea
+       +--- TN.RailTransportNetwork.RailwayArea
+Style section for root layer and possibly existing group layers
+For regular layers, the concept of GROUP and CLASSGROUP can be used to set
+the layer style name to the according value. Additionally the layer style
+titles can be overwritten through ``wms_style_<stylename>_title`` and the
+layer style legendURLs through ``wms_style_<stylename>_legendurl_*`` (width,
+height, format, and href need to be provided)::
+    LAYER
+     DATA "road"
+     METADATA
+      "wms_title.eng" "Transport networks: Road Link"
+      "wms_title.ger" "Verkehrsnetze: Strassensegment"
+      "wms_style_inspire_common:DEFAULT_title" "mylayerstyletitle"     #style title
+      "wms_style_inspire_common:DEFAULT_legendurl_width" "85"          #override style legendurl (mandatory: width, height, format, href)
+      "wms_style_inspire_common:DEFAULT_legendurl_height" "40"
+      "wms_style_inspire_common:DEFAULT_legendurl_format" "image/png"
+      "wms_style_inspire_common:DEFAULT_legendurl_href" "http://path/to/onlineresource...roadlink"
+     END
+    END
+    CLASSGROUP "inspire_common:DEFAULT"
+    CLASSITEM "NAME_E"
+    CLASS
+     NAME "myclass1"
+     GROUP "inspire_common:DEFAULT"
+     EXPRESSION "Trans-Canada Highway"
+     COLOR 255 0 0
+    END
+    CLASS
+     NAME "myclass2"
+     COLOR 0 255 0
+    END
+The following method is implemented to support (customizable) style sections
+in the root layer:
+- use ``wms_style_name`` in the ``WEB.METADATA`` section to add a style section
+  to the root layer
+- use ``wms_style_title`` to override the style title (optional)
+- use ``wms_style_legendurl_*`` to override width, heigth, format and href of
+  the legendURL (optional)
+and possibly existing group layers:
+- use ``wms_group_style_name`` in the first corresponding ``LAYER.METADATA``
+  section to add a style section to the group layer
+- use ``wms_group_style_title`` to override the style title (optional)
+- use ``wms_group_style_legendurl_*`` to override width, heigth, format and
+  href of the legendURL (optional)
+    WEB
+     METADATA
+      "wms_style_name" "inspire_common:DEFAULT"      #style name
+      "wms_style_title" "myroadarealayerstyletitle"  #style title
+      "wms_style_legendurl_width" "85"               #override style legendurl (mandatory: width, height, format, href)
+      "wms_style_legendurl_height" "40"
+      "wms_style_legendurl_format" "image/png"
+      "wms_style_legendurl_href" "http://path/to/onlineresource...roadarea"
+     END
+    END
+    LAYER
+     NAME TN.RailTransportNetwork.RailwayLink
+     GROUP TN.CommonTransportElements.TransportLink
+      DATA "road"
+      METADATA
+       "wms_group_title.eng" "Transport networks: Generic Transport Link"
+       "wms_group_title.ger" "Verkehrsnetze: Generisches Verkehrssegment"
+       "wms_group_abstract" "mygenerictransportlinklayerabstract" #fallback
+       "wms_group_abstract.ger" "mygenerictransportlinklayerabstract"
+       "wms_group_style_name" "inspire_common:DEFAULT" #style name
+       "wms_group_style_title" "mygenerictransportlinklayerstyletitle" #style title
+       "wms_group_style_legendurl_width" "85"        #override style legendurl (mandatory: width, height, format, href)
+       "wms_group_style_legendurl_height" "40"
+       "wms_group_style_legendurl_format" "image/png"
+       "wms_group_style_legendurl_href" "http://path/to/onlineresource...generictransportlink"
+       "wms_title.eng" "Transport networks: Railway Link"
+       "wms_title.ger" "Verkehrsnetze: Eisenbahnverbindung"
+       "wms_abstract" "myrailwaylinklayerabstract"   #fallback
+       "wms_abstract.ger" "myrailwaylinklayerabstractger"
+      END
+    END
+Provided that ability, 3 levels of hierarchy can be achieved as done in the
+example mapfiles `wms_inspire_scenario1.map`_ and `wms_inspire_scenario2.map`_
+in msautotest::
+  TN.RoadTransportNetwork.RoadArea
+  +--- TN.RoadTransportNetwork.RoadLink
+       +--- TN.AirTransportNetwork.AirLink
+.. #### rST Link Section ####
+.. _`European directive`: http://inspire.jrc.ec.europa.eu/
+.. _`INSPIRE Technical Guidance document`: http://INSPIRE.jrc.ec.europa.eu/documents/Network_Services/TechnicalGuidance_ViewServices_v3.0.pdf
+.. _`INSPIRE schemas`: http://inspire.ec.europa.eu/schemas/inspire_vs/1.0/inspire_vs.xsd
+.. _`WMS INSPIRE tester`: http://inspire_tester.neogeo-online.net/
+.. _document: http://www.neogeo-online.net/blog/wp-content/uploads/2011/04/MAPSERVER_INSPIRE.pdf
+.. _`INSPIRE Metadata Implementing Rules`: http://inspire.jrc.ec.europa.eu/documents/Metadata/Changes_to_MD_Guidelines_from_v1-1_to_v1-2_20100616-1.pdf
+.. _wms_inspire.map: https://svn.osgeo.org/mapserver/sandbox/inspire_soc2011/msautotest/wxs/wms_inspire.map
+.. _wms_inspire_scenario1.map: https://svn.osgeo.org/mapserver/sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
+.. _wms_inspire_scenario2.map: https://svn.osgeo.org/mapserver/sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
Property changes on: trunk/docs/en/ogc/inspire.txt
___________________________________________________________________
Added: svn:keywords
   + Author Date Id Rev URL
Added: svn:eol-style
   + native
