[mapserver-commits] r13284 - trunk/docs/en/ogc
Mon Mar 19 13:21:41 EDT 2012
Author: schpidi
Date: 2012-03-19 10:21:41 -0700 (Mon, 19 Mar 2012)
New Revision: 13284
   trunk/docs/en/ogc/wms_server.txt
Adding documentation for #4151.
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt	2012-03-19 17:02:58 UTC (rev 13283)
+++ trunk/docs/en/ogc/wms_server.txt	2012-03-19 17:21:41 UTC (rev 13284)
@@ -1204,6 +1204,24 @@
   controlled vocabulary has been defined.
 .. index::
+   triple: WMS; METADATA; wms_keywordlist_vocabulary
+**wms_keywordlist_vocabulary**
+- *WMS Attribute Name:* vocabulary of KeywordList -> Keyword
+- *Description:* (Optional) Name of vocabulary used in
+  **wms_keywordlist_[vocabulary's name]_items** as described below.
+.. index::
+   triple: WMS; METADATA; wms_keywordlist_[vocabulary's name]_items
+**wms_keywordlist_[vocabulary's name]_items**
+- *WMS TAG Name:* KeywordList -> Keyword
+- *Description:* (Optional) A comma-separated list of keywords or
+  keyword phrases to help catalog searching for given vocabulary.
+.. index::
    triple: WMS; METADATA; wms_layerlimit
 **wms_layerlimit**
@@ -1684,9 +1702,23 @@
 **wms_keywordlist**
-- Same as wms_keywordlist in the Web Object .
+- Same as wms_keywordlist in the Web Object.
 .. index::
+- Same as wms_keywordlist_vocabulary in the Web Object.
+.. index::
+- Same as wms_keywordlist_[vocabulary's name]_items in the Web Object.
+.. index::
    triple: WMS; METADATA; wms_layer_group
 **wms_layer_group**
@@ -1905,7 +1937,7 @@
   legend was returned using the layer classes. To preserve that
   behavior, a GetLegendGraphic request will be cascaded only **if**:
-  1. The GetLegendGraphic request is enabled via the *_enable_request
+  1. The GetLegendGraphic request is enabled via the *_enable_request*
      metadata.
   2. The layer does not contain any class with the name property
