[mapserver-commits] r13301 - branches/branch-6-0/docs/en/ogc trunk/docs/en/ogc
Sat Mar 24 04:29:37 EDT 2012
Author: havatv
Date: 2012-03-24 01:29:37 -0700 (Sat, 24 Mar 2012)
New Revision: 13301
   branches/branch-6-0/docs/en/ogc/wms_server.txt
   trunk/docs/en/ogc/wms_server.txt
Added the vendor specific parameter radius to the wms server document (#4256) plus some minor edits (fix index entry and indent note).
Modified: branches/branch-6-0/docs/en/ogc/wms_server.txt
--- branches/branch-6-0/docs/en/ogc/wms_server.txt	2012-03-23 18:14:29 UTC (rev 13300)
+++ branches/branch-6-0/docs/en/ogc/wms_server.txt	2012-03-24 08:29:37 UTC (rev 13301)
@@ -1474,7 +1474,19 @@
 .. note::
    The angle value is in degrees clockwise.
+.. index::
+   triple: WMS; Vendor specific parameters; radius
+**radius**
+- This parameter accepts two types of input:
+  - An integer that specifies the search radius in pixels.
+  - The special value `bbox` that will change the query into a bbox
+    query based on the bbox given in the request parameters.
 Sample WMS Server Mapfile
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt	2012-03-23 18:14:29 UTC (rev 13300)
+++ trunk/docs/en/ogc/wms_server.txt	2012-03-24 08:29:37 UTC (rev 13301)
@@ -1222,9 +1222,6 @@
   keyword phrases to help catalog searching for given vocabulary.
 .. index::
-   triple: WMS; METADATA; wms_layerlimit
-.. index::
    triple: WMS; METADATA; wms_languages
 **wms_languages**
@@ -1233,6 +1230,9 @@
   details please refer to the section :ref:`inspire_multi-language_support`
   in the INSPIRE View Service documentation.
+.. index::
+   triple: WMS; METADATA; wms_layerlimit
 **wms_layerlimit**
 - *WMS TAG Name:* LayerLimit (WMS1.3.0, sect. 7.2.4.3)
@@ -1924,10 +1924,22 @@
 - Angle (in degrees) to rotate the map.
-.. note::
-   The angle value is in degrees clockwise.
+ .. note::
+     The angle value is in degrees clockwise.
+.. index::
+**radius**
 .. index::
    pair: WMS; Cascading requests
