[mapserver-commits] r13309 - trunk/mapserver
Fri Mar 30 11:11:14 EDT 2012
Author: tbonfort
Date: 2012-03-30 08:11:13 -0700 (Fri, 30 Mar 2012)
New Revision: 13309
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/mapcairo.c
   trunk/mapserver/mapimageio.c
   trunk/mapserver/maprendering.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapsymbol.c
   trunk/mapserver/mapsymbol.h
make image loaders and renderers take premultiplied pixmap data.
refactor svg symbol renderer so it does not need to pollute the rasterBufferObj structure
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2012-03-29 12:43:28 UTC (rev 13308)
+++ trunk/mapserver/mapagg.cpp	2012-03-30 15:11:13 UTC (rev 13309)
@@ -78,6 +78,7 @@
 typedef mapserver::pixel32_type pixel_type;
 typedef mapserver::blender_rgba_pre<color_type, band_order> blender_pre;
 typedef mapserver::pixfmt_alpha_blend_rgba<blender_pre, mapserver::rendering_buffer, pixel_type> pixel_format;
 typedef mapserver::rendering_buffer rendering_buffer;
 typedef mapserver::renderer_base<pixel_format> renderer_base;
@@ -565,39 +566,10 @@
 int agg2RenderPixmapSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj * style) {
 	AGG2Renderer *r = AGG_RENDERER(img);
-	pixel_format pf;
-   rendering_buffer b;
 	rasterBufferObj *pixmap = symbol->pixmap_buffer;
 	assert(pixmap->type == MS_BUFFER_BYTE_RGBA);
-    if(!symbol->renderer_cache) {
-        band_type *data = (band_type*)msSmallMalloc(pixmap->width*pixmap->height*4*sizeof(band_type));
-        for(unsigned int row=0; row<pixmap->height;row++) {
-           unsigned char *a = pixmap->data.rgba.a + row * pixmap->data.rgba.row_step;
-           unsigned char *r = pixmap->data.rgba.r + row * pixmap->data.rgba.row_step;
-           unsigned char *g = pixmap->data.rgba.g + row * pixmap->data.rgba.row_step;
-           unsigned char *b = pixmap->data.rgba.b + row * pixmap->data.rgba.row_step;
-           band_type* pixptr = data + row * pixmap->width * 4;
-           for(unsigned int col=0;col<pixmap->width;col++) {
-              pixptr[band_order::A] = *a;
-              pixptr[band_order::G] = *g;
-              pixptr[band_order::B] = *b;
-              pixptr[band_order::R] = *r;
-              pixptr+=4;
-              a += pixmap->data.rgba.pixel_step;
-              r += pixmap->data.rgba.pixel_step;
-              g += pixmap->data.rgba.pixel_step;
-              b += pixmap->data.rgba.pixel_step;
-        //memcpy(data,pixmap->data.rgba.pixels,pixmap->width*pixmap->height*4);
-        rendering_buffer *b = new rendering_buffer(data, pixmap->width, pixmap->height, (int)pixmap->width*4);
-        symbol->renderer_cache = (void*)b;
-        pf.attach(*b);
-        pf.premultiply();
-    } else {
-        rendering_buffer *b = (rendering_buffer*)symbol->renderer_cache;
-        pf.attach(*b);
+   rendering_buffer b(pixmap->data.rgba.pixels,pixmap->width,pixmap->height,pixmap->data.rgba.row_step);
+   pixel_format pf(b);
 	r->m_rasterizer_aa.reset();
 	r->m_rasterizer_aa.filling_rule(mapserver::fill_non_zero);
@@ -951,19 +923,7 @@
 int agg2FreeSymbol(symbolObj * symbol) {
-	switch(symbol->type) {
-	case MS_SYMBOL_PIXMAP:
-        case MS_SYMBOL_SVG:
-	   if(symbol->renderer_cache) {
-	      rendering_buffer *rb = (rendering_buffer*)symbol->renderer_cache;
-	      free(rb->buf());
-	      delete (rendering_buffer*)symbol->renderer_cache;
-	   symbol->renderer_cache = NULL;
-	   break;
 	return MS_SUCCESS;
 int agg2InitCache(void **vcache) {
Modified: trunk/mapserver/mapcairo.c
--- trunk/mapserver/mapcairo.c	2012-03-29 12:43:28 UTC (rev 13308)
+++ trunk/mapserver/mapcairo.c	2012-03-30 15:11:13 UTC (rev 13309)
@@ -328,55 +328,39 @@
     return MS_SUCCESS;
+#ifdef USE_SVG_CAIRO
+struct svg_symbol_cache{
+   rasterBufferObj pixmap_buffer;
+   svg_cairo_t *svgc;
+   double scale,rotation;
+#endif
 int renderSVGSymbolCairo(imageObj *img, double x, double y, symbolObj *symbol,
                             symbolStyleObj *style) {
     cairo_renderer *r = CAIRO_RENDERER(img);
     //double ox=symbol->sizex*0.5,oy=symbol->sizey*0.5;
-    unsigned int svg_width, svg_height;
     svg_cairo_status_t status;
-    svg_cairo_t *svgc;
-    double scale;
-    //use cache for svg surface
-       status = svg_cairo_create(&svgc);
-       status = svg_cairo_parse_buffer(svgc, symbol->svg_text, strlen(symbol->svg_text));
-       if (status) {
-          msSetError(MS_RENDERERERR, "problem creating cairo svg", "renderSVGSymbolCairo()");
-          return MS_FAILURE;
-       symbol->renderer_cache = svgc;
+    struct svg_symbol_cache *cache;
+    msPreloadSVGSymbol(symbol);
     assert(symbol->renderer_cache);
-    svgc=(svg_cairo_t *)symbol->renderer_cache;
+    cache = symbol->renderer_cache;
-    svg_cairo_get_size (svgc, &svg_width, &svg_height);
-    //scale such that the SVG is rendered at the desired size in pixels
-    scale = style->scale;
-    if (style->scale != 1) {
-	    scale = MS_MIN(style->scale / (double) svg_width,
-                   style->scale / (double) svg_height);
-    } else {
     cairo_save(r->cr);
     cairo_translate(r->cr,x,y);
-    cairo_scale(r->cr,scale,scale);
+    cairo_scale(r->cr,style->scale,style->scale);
     if (style->rotation != 0) {
       cairo_rotate(r->cr, -style->rotation);
-      cairo_translate (r->cr, -(int)svg_width/2, -(int)svg_height/2);
+      cairo_translate (r->cr, -(int)(symbol->sizex/2), -(int)(symbol->sizey/2));
     else
-    status = svg_cairo_render(svgc, r->cr);
+    status = svg_cairo_render(cache->svgc, r->cr);
     cairo_restore(r->cr);
     return MS_SUCCESS;
@@ -1006,13 +990,18 @@
         cairo_path_destroy(s->renderer_cache);
         break;
-      if (s->renderer_cache) {
-        //cairo_surface_finish(s->renderer_cache);
-        cairo_surface_destroy(s->renderer_cache);
-        break;
+       cairo_surface_destroy(s->renderer_cache);
+       break;
+    case MS_SYMBOL_SVG: {
+       struct svg_symbol_cache *cache = s->renderer_cache;
+       assert(cache->svgc);
+       svg_cairo_destroy(cache->svgc);
+       msFree(s->renderer_cache);
+#endif
+      break;
     s->renderer_cache=NULL;
     return MS_SUCCESS;
@@ -1031,30 +1020,36 @@
    return MS_SUCCESS;
 int msPreloadSVGSymbol(symbolObj *symbol)
     int status;
-    if(symbol->svg_cairo_surface)
+    if(!symbol->renderer_cache) {
+       cache = msSmallCalloc(1,sizeof(struct svg_symbol_cache));
+    } else {
+    if(cache->svgc)
       return MS_SUCCESS;
     if(!symbol->svg_text)
       return MS_FAILURE;
+    status = svg_cairo_create(&cache->svgc);
     if (status) {
       msSetError(MS_RENDERERERR, "problem creating cairo svg", "msPreloadSVGSymbol()");
       return MS_FAILURE;
+    status = svg_cairo_parse_buffer(cache->svgc, symbol->svg_text, strlen(symbol->svg_text));
     if (status) {
       msSetError(MS_RENDERERERR, "problem parsing svg symbol", "msPreloadSVGSymbol()");
       return MS_FAILURE;
+    svg_cairo_get_size (cache->svgc, &svg_width, &svg_height);
     if (svg_width == 0 || svg_height == 0)
@@ -1063,9 +1058,8 @@
     symbol->sizex = svg_width;
     symbol->sizey = svg_height;
+    symbol->renderer_cache = cache;
-    symbol->svg_cairo_surface = (void *)svgc;
     return MS_SUCCESS;
 #else
@@ -1075,110 +1069,76 @@
 #endif
-int msRenderSVGToPixmap(symbolObj *symbol, symbolStyleObj *style) {
+int msRenderRasterizedSVGSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style) {
-    svg_cairo_status_t status;
-    cairo_t *cr;
-    cairo_surface_t *surface;
-    unsigned char *pb;
-    rasterBufferObj *rb;
-    //rendering_buffer *rc;
-    int width, height, surface_w, surface_h,row;
-    double scale;
+    struct svg_symbol_cache *svg_cache;
+    symbolStyleObj pixstyle;
+    symbolObj pixsymbol;
     //already rendered at the right size and scale? return
-    if (symbol->pixmap_buffer) {
-        if (style->scale == symbol->pixmap_buffer->scale &&
-            style->rotation == symbol->pixmap_buffer->rotation) {
-            return MS_SUCCESS;
-        } else {
-          if(symbol->renderer!=NULL)
-            symbol->renderer->freeSymbol(symbol);
-           msFreeRasterBuffer(symbol->pixmap_buffer);
-    if (!symbol->svg_cairo_surface )
-      msPreloadSVGSymbol(symbol);
+    if(MS_SUCCESS != msPreloadSVGSymbol(symbol))
+       return MS_FAILURE;
+    svg_cache = (struct svg_symbol_cache*) symbol->renderer_cache;
-    if (!symbol->svg_cairo_surface)
+    if(svg_cache->scale != style->scale || svg_cache->rotation != style->rotation) {
+      cairo_t *cr;
+      cairo_surface_t *surface;
+      unsigned char *pb;
+      int width, height, surface_w, surface_h;
+      /* need to recompute the pixmap */
+      msFreeRasterBuffer(&svg_cache->pixmap_buffer);
-    //set up raster
+      //increase pixmap size to accomodate scaling/rotation
+      if (style->scale != 1.0) {
+         width = surface_w = (symbol->sizex * style->scale + 0.5);
+         height = surface_h = (symbol->sizey * style->scale + 0.5);
+      } else {
+         width = surface_w = symbol->sizex;
+         height = surface_h = symbol->sizey;
+      if (style->rotation != 0) {
+         surface_w = MS_NINT(width * 1.415);
+         surface_h = MS_NINT(height * 1.415);
-    svgc =symbol->svg_cairo_surface;
-    width = surface_w = svg_width;
-    height = surface_h = svg_height;
+      surface = cairo_image_surface_create(CAIRO_FORMAT_ARGB32, surface_w, surface_h);
+      cr = cairo_create(surface);
-    scale = style->scale; /*MS_MIN(style->scale / (double) svg_width,
-                            style->scale / (double) svg_height);*/
-    //increase pixmap size to accomodate scaling/rotation
-    if (scale != 1.0 && style->scale != 1.0) {
-        width = surface_w = (svg_width * scale + 0.5);
-        height = surface_h = (svg_height * scale + 0.5);
-    if (style->rotation != 0) {
-       surface_w = MS_NINT(width * 1.415);
-       surface_h = MS_NINT(height * 1.415);
-    surface = cairo_image_surface_create (CAIRO_FORMAT_ARGB32, surface_w, surface_h);
-    cr = cairo_create(surface);
-      cairo_translate (cr, surface_w/2, surface_h/2);
-      cairo_rotate(cr, -style->rotation);
-      cairo_translate (cr, -width/2, -height/2);
-    if (style->scale != 1.0) {
-      cairo_scale(cr,scale,scale);
-    status = svg_cairo_render(svgc, cr);
-    pb = cairo_image_surface_get_data(surface);
-    //set up raster
-   symbol->pixmap_buffer = (rasterBufferObj*)calloc(1,sizeof(rasterBufferObj));
-   MS_CHECK_ALLOC(symbol->pixmap_buffer, sizeof(rasterBufferObj), MS_FAILURE);
-   initializeRasterBufferCairo(symbol->pixmap_buffer, surface_w, surface_h, 0);
-   rb = symbol->pixmap_buffer;
-   memcpy(rb->data.rgba.pixels, pb, surface_w * surface_h * 4 * sizeof(unsigned char));
-   /* unpremultiply the data */
-   for(row=0;row<rb->height;row++) {
-      int col;
-      unsigned char *a,*r,*g,*b;
-      r=rb->data.rgba.r+row*rb->data.rgba.row_step;
-      g=rb->data.rgba.g+row*rb->data.rgba.row_step;
-      b=rb->data.rgba.b+row*rb->data.rgba.row_step;
-      a=rb->data.rgba.a+row*rb->data.rgba.row_step;
-      for(col=0;col<rb->width;col++) {
-         if(*a && *a < 255) {
-            double da = *a/255.0;
-            *r/=da;
-            *g/=da;
-            *b/=da;
-         a+=rb->data.rgba.pixel_step;
-         r+=rb->data.rgba.pixel_step;
-         g+=rb->data.rgba.pixel_step;
-         b+=rb->data.rgba.pixel_step;
+         cairo_translate(cr, surface_w / 2, surface_h / 2);
+         cairo_rotate(cr, -style->rotation);
+         cairo_translate(cr, -width / 2, -height / 2);
+         cairo_scale(cr, style->scale, style->scale);
+      if(svg_cairo_render(svg_cache->svgc, cr) != SVG_CAIRO_STATUS_SUCCESS) {
+      pb = cairo_image_surface_get_data(surface);
+      //set up raster
+      initializeRasterBufferCairo(&svg_cache->pixmap_buffer, surface_w, surface_h, 0);
+      memcpy(svg_cache->pixmap_buffer.data.rgba.pixels, pb, surface_w * surface_h * 4 * sizeof (unsigned char));
+      svg_cache->scale = style->scale;
+      svg_cache->rotation = style->rotation;
+      cairo_destroy(cr);
+      cairo_surface_destroy(surface);
+   assert(svg_cache->pixmap_buffer.height && svg_cache->pixmap_buffer.width);
-   rb->scale = style->scale;
-   rb->rotation = style->rotation;
-   cairo_destroy(cr);
-   cairo_surface_destroy(surface);
+   pixstyle = *style;
+   pixstyle.rotation = 0.0;
+   pixstyle.scale = 1.0;
+   pixsymbol.pixmap_buffer = &svg_cache->pixmap_buffer;
+   pixsymbol.type = MS_SYMBOL_PIXMAP;
+   MS_IMAGE_RENDERER(img)->renderPixmapSymbol(img,x,y,&pixsymbol,&pixstyle);
+   MS_IMAGE_RENDERER(img)->freeSymbol(&pixsymbol);
    return MS_SUCCESS;
 #else
     msSetError(MS_MISCERR, "SVG Symbols requested but MapServer is not built with libsvgcairo",
Modified: trunk/mapserver/mapimageio.c
--- trunk/mapserver/mapimageio.c	2012-03-29 12:43:28 UTC (rev 13308)
+++ trunk/mapserver/mapimageio.c	2012-03-30 15:11:13 UTC (rev 13309)
@@ -719,6 +719,7 @@
 int readPNG(char *path, rasterBufferObj *rb) {
     png_uint_32 width,height,row_bytes;
+    unsigned char *a,*r,*g,*b;
     int bit_depth,color_type,i;
     unsigned char **row_pointers;
     png_structp png_ptr = NULL;
@@ -757,10 +758,10 @@
     row_pointers = (unsigned char**)malloc(height*sizeof(unsigned char*));
     rb->data.rgba.pixel_step=4;
     rb->data.rgba.row_step = width*4;
-    rb->data.rgba.b = &rb->data.rgba.pixels[0];
-    rb->data.rgba.g = &rb->data.rgba.pixels[1];
-    rb->data.rgba.r = &rb->data.rgba.pixels[2];
-    rb->data.rgba.a = &rb->data.rgba.pixels[3];
+    b = rb->data.rgba.b = &rb->data.rgba.pixels[0];
+    g = rb->data.rgba.g = &rb->data.rgba.pixels[1];
+    r = rb->data.rgba.r = &rb->data.rgba.pixels[2];
+    a = rb->data.rgba.a = &rb->data.rgba.pixels[3];
     for(i=0;i<height;i++) {
         row_pointers[i] = &(rb->data.rgba.pixels[i*rb->data.rgba.row_step]);
@@ -797,6 +798,21 @@
     row_pointers=NULL;
     png_read_end(png_ptr,NULL);
     png_destroy_read_struct(&png_ptr, &info_ptr, NULL);
+    /*premultiply data*/
+    for(i=0;i<width*height;i++) {
+       if(*a < 255) {
+          if(*a == 0)
+              *r=*g=*b=0;
+          } else {
+            *r = (*r * *a + 255) >> 8;
+            *g = (*g * *a + 255) >> 8;
+            *b = (*b * *a + 255) >> 8;
+       a+=4;b+=4;g+=4;r+=4;
     fclose(stream);
     return MS_SUCCESS;
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2012-03-29 12:43:28 UTC (rev 13308)
+++ trunk/mapserver/maprendering.c	2012-03-30 15:11:13 UTC (rev 13309)
@@ -188,9 +188,6 @@
    if(tile==NULL) {
       imageObj *tileimg;
       double p_x,p_y;
-#ifdef USE_SVG_CAIRO
-      double scale, rotation;
-#endif
       tileimg = msImageCreate(width,height,img->format,NULL,NULL,img->resolution, img->resolution, NULL);
       if(!seamlessmode) {
          p_x = width/2.0;
@@ -217,18 +214,14 @@
               if(msPreloadSVGSymbol(symbol) != MS_SUCCESS) {
                   return NULL; //failed to load image, renderer should have set the error message
-              if (renderer->supports_svg)
-                renderer->renderSVGSymbol(tileimg, p_x, p_y, symbol, s);
-              else
-                if (msRenderSVGToPixmap(symbol, s) == MS_SUCCESS){
-                    scale = s->scale;
-                    rotation = s->rotation;
-                    s->scale = 1.0;
-                    s->rotation = 0;
-                    renderer->renderPixmapSymbol(tileimg, p_x, p_y, symbol, s);
-                    s->scale = scale;
-                    s->rotation = rotation;
+              if (renderer->supports_svg) {
+                if(renderer->renderSVGSymbol(tileimg, p_x, p_y, symbol, s) != MS_SUCCESS) {
+                   return NULL;
+              else {
+                 if (msRenderRasterizedSVGSymbol(tileimg,p_x,p_y,symbol, s) != MS_SUCCESS){
+                    return NULL;
 #else
@@ -278,15 +271,7 @@
                      renderer->renderSVGSymbol(tile3img, p_x, p_y, symbol, s);
                    } else {
-                       scale = s->scale;
-                       s->scale = 1.0;
-                       s->rotation = 0;
-                       renderer->renderPixmapSymbol(tile3img, p_x, p_y, symbol, s);
-                       s->scale = scale;
+                      msRenderRasterizedSVGSymbol(tile3img,p_x,p_y,symbol, s);
 #else
                      msSetError(MS_SYMERR, "SVG symbol support is not enabled.", "getTile()");
@@ -836,7 +821,7 @@
             case (MS_SYMBOL_SVG):
-               if (!symbol->svg_cairo_surface) {
+               if (!symbol->renderer_cache) {
                   if (MS_SUCCESS != msPreloadSVGSymbol(symbol))
                      return MS_FAILURE;
@@ -933,17 +918,7 @@
                ret = renderer->renderSVGSymbol(image, p_x, p_y, symbol, &s);
             } else {
-               if (msRenderSVGToPixmap(symbol, &s) == MS_SUCCESS){
-                 //store style, render pixmap then reset style
-                 scale = s.scale;
-                 rotation = s.rotation;
-                 s.scale = 1.0;
-                 s.rotation = 0;
-                 ret = renderer->renderPixmapSymbol(image,p_x,p_y,symbol,&s);
-                 s.scale = scale;
-                 s.rotation = rotation;
+               ret = msRenderRasterizedSVGSymbol(image, p_x,p_y, symbol, &s);
 #else
                msSetError(MS_SYMERR, "SVG symbol support is not enabled.", "msDrawMarkerSymbol()");
                return MS_FAILURE;
@@ -953,10 +928,9 @@
          break;
          default:
             break;
          return ret;
       else if( MS_RENDERER_IMAGEMAP(image->format) )
          msDrawMarkerSymbolIM(symbolset, image, p, style, scalefactor);
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2012-03-29 12:43:28 UTC (rev 13308)
+++ trunk/mapserver/mapserver.h	2012-03-30 15:11:13 UTC (rev 13309)
@@ -2811,6 +2811,7 @@
 	int (*freeSymbol)(symbolObj *symbol);
 	int (*cleanup)(void *renderer_data);
+MS_DLL_EXPORT int msRenderRasterizedSVGSymbol(imageObj* img, double x, double y, symbolObj* symbol, symbolStyleObj* style);
 #endif /* SWIG */
Modified: trunk/mapserver/mapsymbol.c
--- trunk/mapserver/mapsymbol.c	2012-03-29 12:43:28 UTC (rev 13308)
+++ trunk/mapserver/mapsymbol.c	2012-03-30 15:11:13 UTC (rev 13309)
@@ -68,10 +68,6 @@
 double msSymbolGetDefaultSize(symbolObj *s) {
   double size;
-#endif
  if(s == NULL)
       return 1;
@@ -87,10 +83,8 @@
   case(MS_SYMBOL_SVG):
     size = 1;
-    assert(s->svg_cairo_surface != NULL);
-    if(s->svg_cairo_surface == NULL) return 1; //FIXME
-    svg_cairo_get_size(s->svg_cairo_surface, &svg_width, &svg_height);
-    size = (double)svg_height;
+    assert(s->renderer_cache != NULL);
+    size = s->sizey;
 #endif
     break;
     default: /* vector and ellipses, scalable */
@@ -128,7 +122,6 @@
   s->anchorpoint_x = s->anchorpoint_y = 0.5;
   s->svg_text = NULL;
-  s->svg_cairo_surface=NULL;
@@ -147,10 +140,6 @@
       free(s->pixmap_buffer);
-  if(s->svg_cairo_surface)
-    svg_cairo_destroy(s->svg_cairo_surface);
-#endif
   if(s->font) free(s->font);
   msFree(s->full_font_path);
Modified: trunk/mapserver/mapsymbol.h
--- trunk/mapserver/mapsymbol.h	2012-03-29 12:43:28 UTC (rev 13308)
+++ trunk/mapserver/mapsymbol.h	2012-03-30 15:11:13 UTC (rev 13309)
@@ -78,9 +78,6 @@
 typedef struct {
 	int type;
 	unsigned int width,height;
-#endif
 	union {
 		rgbaArrayObj rgba;
 		paletteArrayObj palette;
@@ -192,7 +189,6 @@
   void *renderer_cache;
   char *full_font_path;
   char *full_pixmap_path;
-  void *svg_cairo_surface;
 #endif /* SWIG */
 #ifdef SWIG
