[mapserver-commits] [mapserver/mapserver] af7bf8: Made format parameter optional, as long as the 'na...
GitHub noreply at github.com
Tue May 29 09:33:39 PDT 2012
  Branch: refs/heads/branch-6-0
  Home:   https://github.com/mapserver/mapserver
  Commit: af7bf80c8bc34644214cc4594770285878777db2
      https://github.com/mapserver/mapserver/commit/af7bf80c8bc34644214cc4594770285878777db2
  Author: Fabian Schindler <fabian.schindler at gmx.at>
  Date:   2012-05-24 (Thu, 24 May 2012)
  Changed paths:
    M mapwcs20.c
  Log Message:
  Made format parameter optional, as long as the 'native_format' can be retrieved (either from the source GDAL dataset or from the metadata).
  Commit: 632741899145d7f858cec79844c33813601394e9
      https://github.com/mapserver/mapserver/commit/632741899145d7f858cec79844c33813601394e9
  Changed paths:
    M mapwcs20.c
  Log Message:
  Merge branch 'wcs_native_format' into branch-6-0
  Commit: 786caa1dc2d51305560a04da4bcd129f40ab1186
      https://github.com/mapserver/mapserver/commit/786caa1dc2d51305560a04da4bcd129f40ab1186
  Changed paths:
    M HISTORY.TXT
  Log Message:
  Update HISTORY.TXT.
  Commit: fac5e35129168fd006ef9296bc53414cb311e9bd
      https://github.com/mapserver/mapserver/commit/fac5e35129168fd006ef9296bc53414cb311e9bd
  Date:   2012-05-25 (Fri, 25 May 2012)
  Changed paths:
    M mapwcs20.c
  Log Message:
  Moved nativeFormat element of CoverageDescriptions to the correct place. (#4003).
ServiceMetadata is now a section like the other sections of Capabilities. Not yet conformant with the WCS 2.0 specs but obviously a bug.
  Commit: 765017bcb8bacc99db3e35a376daadce3ecc6be2
      https://github.com/mapserver/mapserver/commit/765017bcb8bacc99db3e35a376daadce3ecc6be2
  Changed paths:
    M HISTORY.TXT
  Log Message:
  Updated HISTORY.TXT
Compare: https://github.com/mapserver/mapserver/compare/a686e14...765017b
