[mapserver-commits] [mapserver/mapserver] 4c7133: Stop using a submodule for msautotests
GitHub noreply at github.com
Thu Feb 25 01:32:31 PST 2016
  Branch: refs/heads/branch-6-4
  Home:   https://github.com/mapserver/mapserver
  Commit: 4c7133ad4f3c723f9f13def6f4b9d2a774061614
      https://github.com/mapserver/mapserver/commit/4c7133ad4f3c723f9f13def6f4b9d2a774061614
  Author: Thomas Bonfort <thomas.bonfort at gmail.com>
  Date:   2016-02-25 (Thu, 25 Feb 2016)
  Changed paths:
    M .gitattributes
    R .gitmodules
    M .travis.yml
    M Makefile
    R msautotest
    A msautotest/.gitignore
    A msautotest/README
    A msautotest/create_postgis_test_data.sh
    A msautotest/gdal/256_overlay_res.map
    A msautotest/gdal/256color_overdose.map
    A msautotest/gdal/256color_overdose_cmt.map
    A msautotest/gdal/256color_overdose_res.map
    A msautotest/gdal/all_require.txt
    A msautotest/gdal/alpha_on_alpha_overlay.map
    A msautotest/gdal/average_rgb.map
    A msautotest/gdal/average_rgb_plug.map
    A msautotest/gdal/bilinear_float.map
    A msautotest/gdal/class16.map
    A msautotest/gdal/class16_intoddscale.map
    A msautotest/gdal/class16_ndmap.map
    A msautotest/gdal/class16_oddscale.map
    A msautotest/gdal/class16_range.map
    A msautotest/gdal/class8_range.map
    A msautotest/gdal/classtest1.map
    A msautotest/gdal/classtest2.map
    A msautotest/gdal/classtest2_plugin.map
    A msautotest/gdal/data/float.tif
    A msautotest/gdal/data/float.wld
    A msautotest/gdal/data/grey.tif
    A msautotest/gdal/data/grey.wld
    A msautotest/gdal/data/grey_raw.tif
    A msautotest/gdal/data/grey_rot.tif
    A msautotest/gdal/data/grey_rot.wld
    A msautotest/gdal/data/grey_upsidedown.tif
    A msautotest/gdal/data/grey_upsidedown.wld
    A msautotest/gdal/data/greyalpha.vrt
    A msautotest/gdal/data/grid.gif
    A msautotest/gdal/data/grid.wld
    A msautotest/gdal/data/int16.vrt
    A msautotest/gdal/data/munich_1.crv
    A msautotest/gdal/data/munich_rgb.crv
    A msautotest/gdal/data/pct22.tif
    A msautotest/gdal/data/pct22.wld
    A msautotest/gdal/data/red_square.tif
    A msautotest/gdal/data/rgb.tif
    A msautotest/gdal/data/rgb.wld
    A msautotest/gdal/data/rgb16.tif
    A msautotest/gdal/data/rgb16.wld
    A msautotest/gdal/data/rgba.tif
    A msautotest/gdal/data/rgba.wld
    A msautotest/gdal/data/test3_with_1mask_1bit.tif
    A msautotest/gdal/data/test_with_mask_1bit.tif
    A msautotest/gdal/data/tile11.vrt
    A msautotest/gdal/data/tile12.vrt
    A msautotest/gdal/data/tile21.vrt
    A msautotest/gdal/data/tile22.vrt
    A msautotest/gdal/data/tile_index.dbf
    A msautotest/gdal/data/tile_index.mid
    A msautotest/gdal/data/tile_index.mif
    A msautotest/gdal/data/tile_index.shp
    A msautotest/gdal/data/tile_index.shx
    A msautotest/gdal/data/tile_index_mixed_srs.dbf
    A msautotest/gdal/data/tile_index_mixed_srs.prj
    A msautotest/gdal/data/tile_index_mixed_srs.shp
    A msautotest/gdal/data/tile_index_mixed_srs.shx
    A msautotest/gdal/data/tile_index_mixed_srs_26711.dbf
    A msautotest/gdal/data/tile_index_mixed_srs_26711.prj
    A msautotest/gdal/data/tile_index_mixed_srs_26711.shp
    A msautotest/gdal/data/tile_index_mixed_srs_26711.shx
    A msautotest/gdal/data/tile_index_mixed_srs_with_data_dir.dbf
    A msautotest/gdal/data/tile_index_mixed_srs_with_data_dir.prj
    A msautotest/gdal/data/tile_index_mixed_srs_with_data_dir.shp
    A msautotest/gdal/data/tile_index_mixed_srs_with_data_dir.shx
    A msautotest/gdal/data/utmsmall_bottomleft_4326.tif
    A msautotest/gdal/data/utmsmall_bottomright_3857.tif
    A msautotest/gdal/data/utmsmall_topleft_26711.tif
    A msautotest/gdal/data/utmsmall_topright_32611.tif
    A msautotest/gdal/deferred.map
    A msautotest/gdal/expected/256_overlay_res.png
    A msautotest/gdal/expected/256color_overdose.png
    A msautotest/gdal/expected/256color_overdose_cmt.png
    A msautotest/gdal/expected/256color_overdose_res.png
    A msautotest/gdal/expected/alpha_on_alpha_overlay.png
    A msautotest/gdal/expected/average_rgb.png
    A msautotest/gdal/expected/average_rgb_plug.png
    A msautotest/gdal/expected/bilinear_float.png
    A msautotest/gdal/expected/class16.png
    A msautotest/gdal/expected/class16_intoddscale.png
    A msautotest/gdal/expected/class16_ndmap.png
    A msautotest/gdal/expected/class16_oddscale.png
    A msautotest/gdal/expected/class16_range.png
    A msautotest/gdal/expected/class8_range.png
    A msautotest/gdal/expected/classtest1.png
    A msautotest/gdal/expected/classtest2.png
    A msautotest/gdal/expected/classtest2_plugin.png
    A msautotest/gdal/expected/deferred.png
    A msautotest/gdal/expected/gd_png_256_res.png
    A msautotest/gdal/expected/gd_png_tr_256.png
    A msautotest/gdal/expected/gd_png_tr_256_res.png
    A msautotest/gdal/expected/gdal_png_256_res.png
    A msautotest/gdal/expected/gdal_png_tr_256.png
    A msautotest/gdal/expected/gdal_png_tr_256_res.png
    A msautotest/gdal/expected/grayalpha.png
    A msautotest/gdal/expected/grayalpha_8bit.png
    A msautotest/gdal/expected/grayalpha_plug.png
    A msautotest/gdal/expected/lut_1_crv.png
    A msautotest/gdal/expected/lut_float.png
    A msautotest/gdal/expected/lut_inline.png
    A msautotest/gdal/expected/lut_rgb_crv.png
    A msautotest/gdal/expected/mask_1.png
    A msautotest/gdal/expected/mask_3.png
    A msautotest/gdal/expected/nodata_8bit.png
    A msautotest/gdal/expected/nodata_rgb.png
    A msautotest/gdal/expected/nodata_scaled.png
    A msautotest/gdal/expected/nonsquare.png
    A msautotest/gdal/expected/nonsquare_multiraw.png
    A msautotest/gdal/expected/offsite_8bitgrey.png
    A msautotest/gdal/expected/offsite_pct_rgb.png
    A msautotest/gdal/expected/offsite_pct_rgb_torgb.png
    A msautotest/gdal/expected/ows_extent.png
    A msautotest/gdal/expected/processing_bands.png
    A msautotest/gdal/expected/processing_scale_auto.png
    A msautotest/gdal/expected/rawmode_multiband.png
    A msautotest/gdal/expected/rawmode_nodata.png
    A msautotest/gdal/expected/rawmode_nodata_resample.png
    A msautotest/gdal/expected/reproj.png
    A msautotest/gdal/expected/rgb_16bit.png
    A msautotest/gdal/expected/rgb_overlay.png
    A msautotest/gdal/expected/rgb_overlay_plug.png
    A msautotest/gdal/expected/rgb_overlay_res.png
    A msautotest/gdal/expected/rgb_overlay_res_to8bit.png
    A msautotest/gdal/expected/rgb_overlay_res_to8bit_dithered.png
    A msautotest/gdal/expected/rgba_overlay_res.png
    A msautotest/gdal/expected/rot_out.png
    A msautotest/gdal/expected/simplealpha.png
    A msautotest/gdal/expected/simplealpha_bg.png
    A msautotest/gdal/expected/simplealpha_plug.png
    A msautotest/gdal/expected/tileindex.png
    A msautotest/gdal/expected/tileindex_mi.png
    A msautotest/gdal/expected/tileindexmixedsrs.png
    A msautotest/gdal/expected/tileindexmixedsrs2.png
    A msautotest/gdal/expected/tileindexmixedsrs3.png
    A msautotest/gdal/expected/tileindexmixedsrs4.png
    A msautotest/gdal/expected/trlay1.png
    A msautotest/gdal/expected/trlay2.png
    A msautotest/gdal/expected/trlay3.png
    A msautotest/gdal/expected/unclassified.png
    A msautotest/gdal/expected/wld_override.png
    A msautotest/gdal/expected/wld_rotate.png
    A msautotest/gdal/expected/wld_upsidedown.png
    A msautotest/gdal/expected/wmsclient.png
    A msautotest/gdal/expected/wmsclient_3543.png
    A msautotest/gdal/gd_png_256_res.map
    A msautotest/gdal/gd_png_tr_256.map
    A msautotest/gdal/gd_png_tr_256_res.map
    A msautotest/gdal/gdal_png_256_res.map
    A msautotest/gdal/gdal_png_tr_256.map
    A msautotest/gdal/gdal_png_tr_256_res.map
    A msautotest/gdal/grayalpha.map
    A msautotest/gdal/grayalpha_8bit.map
    A msautotest/gdal/grayalpha_plug.map
    A msautotest/gdal/lut_1_crv.map
    A msautotest/gdal/lut_float.map
    A msautotest/gdal/lut_inline.map
    A msautotest/gdal/lut_rgb_crv.map
    A msautotest/gdal/mask_1.map
    A msautotest/gdal/mask_3.map
    A msautotest/gdal/nodata_8bit.map
    A msautotest/gdal/nodata_rgb.map
    A msautotest/gdal/nodata_scaled.map
    A msautotest/gdal/nonsquare.map
    A msautotest/gdal/nonsquare_multiraw.map
    A msautotest/gdal/offsite_8bitgrey.map
    A msautotest/gdal/offsite_pct_rgb.map
    A msautotest/gdal/offsite_pct_rgb_torgb.map
    A msautotest/gdal/processing_bands.map
    A msautotest/gdal/processing_scale_auto.map
    A msautotest/gdal/rawmode_multiband.map
    A msautotest/gdal/rawmode_nodata.map
    A msautotest/gdal/rawmode_nodata_resample.map
    A msautotest/gdal/reproj.map
    A msautotest/gdal/rgb_16bit.map
    A msautotest/gdal/rgb_overlay.map
    A msautotest/gdal/rgb_overlay_plug.map
    A msautotest/gdal/rgb_overlay_res.map
    A msautotest/gdal/rgb_overlay_res_to8bit.map
    A msautotest/gdal/rgb_overlay_res_to8bit_dithered.map
    A msautotest/gdal/rgba_overlay_res.map
    A msautotest/gdal/rot_out.map
    A msautotest/gdal/run_test.py
    A msautotest/gdal/simplealpha.map
    A msautotest/gdal/simplealpha_bg.map
    A msautotest/gdal/simplealpha_plug.map
    A msautotest/gdal/tileindex.map
    A msautotest/gdal/tileindex_mi.map
    A msautotest/gdal/tileindexmixedsrs.map
    A msautotest/gdal/tileindexmixedsrs2.map
    A msautotest/gdal/tileindexmixedsrs3.map
    A msautotest/gdal/tileindexmixedsrs4.map
    A msautotest/gdal/trlay1.map
    A msautotest/gdal/trlay2.map
    A msautotest/gdal/trlay3.map
    A msautotest/gdal/unclassified.map
    A msautotest/gdal/wld_override.map
    A msautotest/gdal/wld_rotate.map
    A msautotest/gdal/wld_upsidedown.map
    A msautotest/gdal/wmsclient.map
    A msautotest/gdal/wmsclient_3543.map
    A msautotest/misc/attrbind.map
    A msautotest/misc/autostyle.map
    A msautotest/misc/autostyle_quoted.map
    A msautotest/misc/bug1526.map
    A msautotest/misc/bug1716.map.broken
    A msautotest/misc/contour.map
    A msautotest/misc/data/LucidaBrightRegular.ttf
    A msautotest/misc/data/Road_Works.svg
    A msautotest/misc/data/SOUNDG.dbf
    A msautotest/misc/data/SOUNDG.shp
    A msautotest/misc/data/SOUNDG.shx
    A msautotest/misc/data/WORLD_TESTPOLY_UPPERCASE.DBF
    A msautotest/misc/data/WORLD_TESTPOLY_UPPERCASE.QIX
    A msautotest/misc/data/WORLD_TESTPOLY_UPPERCASE.SHP
    A msautotest/misc/data/WORLD_TESTPOLY_UPPERCASE.SHX
    A msautotest/misc/data/attrbind.dbf
    A msautotest/misc/data/attrbind.shp
    A msautotest/misc/data/attrbind.shx
    A msautotest/misc/data/canada.dgn
    A msautotest/misc/data/chartlayer.dbf
    A msautotest/misc/data/chartlayer.shp
    A msautotest/misc/data/chartlayer.shx
    A msautotest/misc/data/colorwheel.png
    A msautotest/misc/data/contour_gwm.tif
    A msautotest/misc/data/dateline_boxes.dbf
    A msautotest/misc/data/dateline_boxes.shp
    A msautotest/misc/data/dateline_boxes.shx
    A msautotest/misc/data/gdalicon.gif
    A msautotest/misc/data/gdalicon.png
    A msautotest/misc/data/gdalicon_interlaced.gif
    A msautotest/misc/data/linemarker.png
    A msautotest/misc/data/quoted_text.DAT
    A msautotest/misc/data/quoted_text.ID
    A msautotest/misc/data/quoted_text.MAP
    A msautotest/misc/data/quoted_text.TAB
    A msautotest/misc/data/rotpoints.dbf
    A msautotest/misc/data/rotpoints.prj
    A msautotest/misc/data/rotpoints.qpj
    A msautotest/misc/data/rotpoints.shp
    A msautotest/misc/data/rotpoints.shx
    A msautotest/misc/data/shppoly/idlink.dbf
    A msautotest/misc/data/shppoly/poly.dbf
    A msautotest/misc/data/shppoly/poly.shp
    A msautotest/misc/data/shppoly/poly.shx
    A msautotest/misc/data/spiral.dbf
    A msautotest/misc/data/spiral.prj
    A msautotest/misc/data/spiral.qpj
    A msautotest/misc/data/spiral.shp
    A msautotest/misc/data/spiral.shx
    A msautotest/misc/data/testlines.dbf
    A msautotest/misc/data/testlines.shp
    A msautotest/misc/data/testlines.shx
    A msautotest/misc/data/world_testpoly.dbf
    A msautotest/misc/data/world_testpoly.shp
    A msautotest/misc/data/world_testpoly.shx
    A msautotest/misc/dateline.map
    A msautotest/misc/expected/agg_entity_encoded_follow_text.png
    A msautotest/misc/expected/attrbind_test001.png
    A msautotest/misc/expected/autostyle.png
    A msautotest/misc/expected/autostyle_quoted.png
    A msautotest/misc/expected/bug1526.png
    A msautotest/misc/expected/bug1716.png
    A msautotest/misc/expected/contour.png
    A msautotest/misc/expected/dateline.png
    A msautotest/misc/expected/geopdf-iso.pdf
    A msautotest/misc/expected/geopdf-ogc.pdf
    A msautotest/misc/expected/listexpression.png
    A msautotest/misc/expected/maxfeatures-of.png
    A msautotest/misc/expected/maxfeatures.png
    A msautotest/misc/expected/multipoint.png
    A msautotest/misc/expected/ogr_attrfilter.png
    A msautotest/misc/expected/ogr_direct.png
    A msautotest/misc/expected/ogr_join.png
    A msautotest/misc/expected/ogr_multi_defer.png
    A msautotest/misc/expected/ogr_select.png
    A msautotest/misc/expected/ogr_vrtconnect.png
    A msautotest/misc/expected/ogr_wkt.png
    A msautotest/misc/expected/ortho.png
    A msautotest/misc/expected/quantized.png
    A msautotest/misc/expected/quoted_data.png
    A msautotest/misc/expected/quoting.png
    A msautotest/misc/expected/rfc14.png
    A msautotest/misc/expected/rfc36_geojson.js
    A msautotest/misc/expected/rfc36_ogr_geojson.js
    A msautotest/misc/expected/rot_out.png
    A msautotest/misc/expected/runtime_sub_test001.txt
    A msautotest/misc/expected/runtime_sub_test002.gif
    A msautotest/misc/expected/runtime_sub_test003.txt
    A msautotest/misc/expected/runtime_sub_test004.gif
    A msautotest/misc/expected/runtime_sub_test005.txt
    A msautotest/misc/expected/runtime_sub_test008.gif
    A msautotest/misc/expected/scaletoken_data_200k.png
    A msautotest/misc/expected/scaletoken_data_29m.png
    A msautotest/misc/expected/scaletoken_data_40m.png
    A msautotest/misc/expected/scaletoken_filter_192k.png
    A msautotest/misc/expected/scaletoken_filter_424k.png
    A msautotest/misc/expected/scaletoken_filter_655k.png
    A msautotest/misc/expected/scaletoken_filteritem_192k.png
    A msautotest/misc/expected/scaletoken_filteritem_424k.png
    A msautotest/misc/expected/sde_bug2072.png
    A msautotest/misc/expected/sde_join.png
    A msautotest/misc/expected/sde_join_getinfo.xml
    A msautotest/misc/expected/sde_utf.png
    A msautotest/misc/expected/sde_utf2.png
    A msautotest/misc/expected/sde_view.png
    A msautotest/misc/expected/sde_wms_cap.xml
    A msautotest/misc/expected/sde_wms_describe.xml
    A msautotest/misc/expected/sde_wms_get_map_polygon.png
    A msautotest/misc/expected/shp2img-size.gif
    A msautotest/misc/expected/style_opacity_test001.png
    A msautotest/misc/expected/style_opacity_test002.png
    A msautotest/misc/expected/style_opacity_test003.png
    A msautotest/misc/expected/testuppercase.png
    A msautotest/misc/fonts.lst
    A msautotest/misc/geopdf.map
    A msautotest/misc/listexpression.map
    A msautotest/misc/maxfeatures.map
    A msautotest/misc/multipoint.map
    A msautotest/misc/ogr_attrfilter.map
    A msautotest/misc/ogr_direct.map
    A msautotest/misc/ogr_join.map
    A msautotest/misc/ogr_multi_defer.map
    A msautotest/misc/ogr_select.map
    A msautotest/misc/ogr_vrtconnect.map
    A msautotest/misc/ogr_wkt.map
    A msautotest/misc/ortho.map
    A msautotest/misc/quantized.map
    A msautotest/misc/quoted_data.map
    A msautotest/misc/quoting.map
    A msautotest/misc/rfc14.map
    A msautotest/misc/rfc36.map
    A msautotest/misc/rfc36.tmpl
    A msautotest/misc/rfc36_ogr.map
    A msautotest/misc/rot_out.map
    A msautotest/misc/run_test.py
    A msautotest/misc/runtime_sub.map
    A msautotest/misc/scaletoken.map
    A msautotest/misc/sde_bug2072.map
    A msautotest/misc/sde_join.map
    A msautotest/misc/sde_utf.map
    A msautotest/misc/sde_utf2.map
    A msautotest/misc/sde_view.map
    A msautotest/misc/sde_wms.map
    A msautotest/misc/shp2img-size.map
    A msautotest/misc/style_opacity.map
    A msautotest/misc/testuppercase.map
    A msautotest/mspython/.cvsignore
    A msautotest/mspython/README
    A msautotest/mspython/bug_check.py
    A msautotest/mspython/expected/bug673.png
    A msautotest/mspython/ogr_query.map
    A msautotest/mspython/ogr_query.py
    A msautotest/mspython/rqtest.py
    A msautotest/mspython/run_all_tests.py
    A msautotest/mspython/test_xmp.map
    A msautotest/mspython/test_xmp.py
    A msautotest/mspython/wkt.py
    A msautotest/php/README
    A msautotest/php/classObjTest.php
    A msautotest/php/colorObjTest.php
    A msautotest/php/errorObjTest.php
    A msautotest/php/hashtableObjTest.php
    A msautotest/php/labelObjTest.php
    A msautotest/php/labelleaderObjTest.php
    A msautotest/php/layerObjTest.php
    A msautotest/php/lineObjTest.php
    A msautotest/php/mapObjTest.php
    A msautotest/php/maps/data/LucidaBrightRegular.ttf
    A msautotest/php/maps/data/SOUNDG.dbf
    A msautotest/php/maps/data/SOUNDG.shp
    A msautotest/php/maps/data/SOUNDG.shx
    A msautotest/php/maps/data/alpinehut.svg
    A msautotest/php/maps/data/attrbind.dbf
    A msautotest/php/maps/data/attrbind.shp
    A msautotest/php/maps/data/attrbind.shx
    A msautotest/php/maps/data/bdry_counpy2.dbf
    A msautotest/php/maps/data/bdry_counpy2.shp
    A msautotest/php/maps/data/bdry_counpy2.shx
    A msautotest/php/maps/data/canada.dgn
    A msautotest/php/maps/data/chartlayer.dbf
    A msautotest/php/maps/data/chartlayer.shp
    A msautotest/php/maps/data/chartlayer.shx
    A msautotest/php/maps/data/colorwheel.png
    A msautotest/php/maps/data/dateline_boxes.dbf
    A msautotest/php/maps/data/dateline_boxes.shp
    A msautotest/php/maps/data/dateline_boxes.shx
    A msautotest/php/maps/data/epsg2
    A msautotest/php/maps/data/gdalicon.gif
    A msautotest/php/maps/data/gdalicon.png
    A msautotest/php/maps/data/gdalicon_interlaced.gif
    A msautotest/php/maps/data/grey.tif
    A msautotest/php/maps/data/grey.wld
    A msautotest/php/maps/data/indx_q100kpy4.dbf
    A msautotest/php/maps/data/indx_q100kpy4.shp
    A msautotest/php/maps/data/indx_q100kpy4.shx
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportArea.dbf
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportArea.prj
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportArea.qix
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportArea.sbn
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportArea.sbx
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportArea.shp
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportArea.shx
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportLink.dbf
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportLink.prj
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportLink.qix
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportLink.sbn
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportLink.sbx
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportLink.shp
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportLink.shx
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportNode.dbf
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportNode.prj
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportNode.qix
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportNode.sbn
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportNode.sbx
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportNode.shp
    A msautotest/php/maps/data/inspire/TN.CommonTransportElements.TransportNode.shx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayArea.dbf
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayArea.prj
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayArea.qix
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayArea.sbn
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayArea.sbx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayArea.shp
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayArea.shx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayLink.dbf
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayLink.prj
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayLink.qix
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayLink.sbn
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayLink.sbx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayLink.shp
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayLink.shx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayStationArea.dbf
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayStationArea.prj
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayStationArea.qix
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayStationArea.sbn
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayStationArea.sbx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayStationArea.shp
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayStationArea.shx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayYardArea.dbf
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayYardArea.prj
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayYardArea.qix
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayYardArea.sbn
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayYardArea.sbx
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayYardArea.shp
    A msautotest/php/maps/data/inspire/TN.RailTransportNetwork.RailwayYardArea.shx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadArea.dbf
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadArea.prj
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadArea.qix
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadArea.sbn
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadArea.sbx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadArea.shp
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadArea.shx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadLink.dbf
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadLink.prj
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadLink.qix
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadLink.sbn
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadLink.sbx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadLink.shp
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadLink.shx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.dbf
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.prj
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.qix
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.sbn
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.sbx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.shp
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.shx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.dbf
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.prj
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.qix
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.sbn
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.sbx
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.shp
    A msautotest/php/maps/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.shx
    A msautotest/php/maps/data/lakes2.dbf
    A msautotest/php/maps/data/lakes2.prj
    A msautotest/php/maps/data/lakes2.qpj
    A msautotest/php/maps/data/lakes2.shp
    A msautotest/php/maps/data/lakes2.shx
    A msautotest/php/maps/data/land_shallow_topo_2048.tif
    A msautotest/php/maps/data/land_shallow_topo_2048.txt
    A msautotest/php/maps/data/land_shallow_topo_2048.wld
    A msautotest/php/maps/data/linemarker.png
    A msautotest/php/maps/data/multi.csv
    A msautotest/php/maps/data/multiband.tif
    A msautotest/php/maps/data/mums.gfs
    A msautotest/php/maps/data/mums.gml
    A msautotest/php/maps/data/mums.xsd
    A msautotest/php/maps/data/obs.csv
    A msautotest/php/maps/data/obs.dbf
    A msautotest/php/maps/data/obs.ovf
    A msautotest/php/maps/data/obs.shp
    A msautotest/php/maps/data/obs.shx
    A msautotest/php/maps/data/pattern1.dbf
    A msautotest/php/maps/data/pattern1.shp
    A msautotest/php/maps/data/pattern1.shx
    A msautotest/php/maps/data/pattern10.dbf
    A msautotest/php/maps/data/pattern10.shp
    A msautotest/php/maps/data/pattern10.shx
    A msautotest/php/maps/data/pattern11.dbf
    A msautotest/php/maps/data/pattern11.shp
    A msautotest/php/maps/data/pattern11.shx
    A msautotest/php/maps/data/pattern12.dbf
    A msautotest/php/maps/data/pattern12.shp
    A msautotest/php/maps/data/pattern12.shx
    A msautotest/php/maps/data/pattern13.dbf
    A msautotest/php/maps/data/pattern13.shp
    A msautotest/php/maps/data/pattern13.shx
    A msautotest/php/maps/data/pattern14.dbf
    A msautotest/php/maps/data/pattern14.shp
    A msautotest/php/maps/data/pattern14.shx
    A msautotest/php/maps/data/pattern15.dbf
    A msautotest/php/maps/data/pattern15.shp
    A msautotest/php/maps/data/pattern15.shx
    A msautotest/php/maps/data/pattern2.dbf
    A msautotest/php/maps/data/pattern2.shp
    A msautotest/php/maps/data/pattern2.shx
    A msautotest/php/maps/data/pattern3.dbf
    A msautotest/php/maps/data/pattern3.shp
    A msautotest/php/maps/data/pattern3.shx
    A msautotest/php/maps/data/pattern4.dbf
    A msautotest/php/maps/data/pattern4.shp
    A msautotest/php/maps/data/pattern4.shx
    A msautotest/php/maps/data/pattern5.dbf
    A msautotest/php/maps/data/pattern5.shp
    A msautotest/php/maps/data/pattern5.shx
    A msautotest/php/maps/data/pattern6.dbf
    A msautotest/php/maps/data/pattern6.shp
    A msautotest/php/maps/data/pattern6.shx
    A msautotest/php/maps/data/pattern7.dbf
    A msautotest/php/maps/data/pattern7.shp
    A msautotest/php/maps/data/pattern7.shx
    A msautotest/php/maps/data/pattern8.dbf
    A msautotest/php/maps/data/pattern8.shp
    A msautotest/php/maps/data/pattern8.shx
    A msautotest/php/maps/data/pattern9.dbf
    A msautotest/php/maps/data/pattern9.shp
    A msautotest/php/maps/data/pattern9.shx
    A msautotest/php/maps/data/popplace.dbf
    A msautotest/php/maps/data/popplace.sbn
    A msautotest/php/maps/data/popplace.sbx
    A msautotest/php/maps/data/popplace.shp
    A msautotest/php/maps/data/popplace.shx
    A msautotest/php/maps/data/province.dbf
    A msautotest/php/maps/data/province.sbn
    A msautotest/php/maps/data/province.sbx
    A msautotest/php/maps/data/province.shp
    A msautotest/php/maps/data/province.shx
    A msautotest/php/maps/data/rivers.dbf
    A msautotest/php/maps/data/rivers.qix
    A msautotest/php/maps/data/rivers.shp
    A msautotest/php/maps/data/rivers.shx
    A msautotest/php/maps/data/road.dbf
    A msautotest/php/maps/data/road.sbn
    A msautotest/php/maps/data/road.sbx
    A msautotest/php/maps/data/road.shp
    A msautotest/php/maps/data/road.shx
    A msautotest/php/maps/data/road_eng.dbf
    A msautotest/php/maps/data/road_eng.sbn
    A msautotest/php/maps/data/road_eng.sbx
    A msautotest/php/maps/data/road_eng.shp
    A msautotest/php/maps/data/road_eng.shx
    A msautotest/php/maps/data/road_ger.dbf
    A msautotest/php/maps/data/road_ger.sbn
    A msautotest/php/maps/data/road_ger.sbx
    A msautotest/php/maps/data/road_ger.shp
    A msautotest/php/maps/data/road_ger.shx
    A msautotest/php/maps/data/rotpoints.dbf
    A msautotest/php/maps/data/rotpoints.prj
    A msautotest/php/maps/data/rotpoints.qpj
    A msautotest/php/maps/data/rotpoints.shp
    A msautotest/php/maps/data/rotpoints.shx
    A msautotest/php/maps/data/shppoly/idlink.dbf
    A msautotest/php/maps/data/shppoly/poly.dbf
    A msautotest/php/maps/data/shppoly/poly.shp
    A msautotest/php/maps/data/shppoly/poly.shx
    A msautotest/php/maps/data/sos-2147.xml
    A msautotest/php/maps/data/sos-35.xml
    A msautotest/php/maps/data/sos-604.xml
    A msautotest/php/maps/data/spiral.dbf
    A msautotest/php/maps/data/spiral.prj
    A msautotest/php/maps/data/spiral.qpj
    A msautotest/php/maps/data/spiral.shp
    A msautotest/php/maps/data/spiral.shx
    A msautotest/php/maps/data/testShape.shp
    A msautotest/php/maps/data/testShape.shx
    A msautotest/php/maps/data/testlines.dbf
    A msautotest/php/maps/data/testlines.shp
    A msautotest/php/maps/data/testlines.shx
    A msautotest/php/maps/data/toronto.tfw
    A msautotest/php/maps/data/toronto.tif
    A msautotest/php/maps/data/toronto.txt
    A msautotest/php/maps/data/wcs_index.dbf
    A msautotest/php/maps/data/wcs_index.shp
    A msautotest/php/maps/data/wcs_index.shx
    A msautotest/php/maps/data/world_testpoly.dbf
    A msautotest/php/maps/data/world_testpoly.shp
    A msautotest/php/maps/data/world_testpoly.shx
    A msautotest/php/maps/etc/fonts.txt
    A msautotest/php/maps/etc/symbols.sym
    A msautotest/php/maps/etc/vera/COPYRIGHT.TXT
    A msautotest/php/maps/etc/vera/README.TXT
    A msautotest/php/maps/etc/vera/RELEASENOTES.TXT
    A msautotest/php/maps/etc/vera/Vera.ttf
    A msautotest/php/maps/etc/vera/VeraBd.ttf
    A msautotest/php/maps/filter.map
    A msautotest/php/maps/filtermap.map
    A msautotest/php/maps/filters.map
    A msautotest/php/maps/fonts.lst
    A msautotest/php/maps/gdalicon.gif
    A msautotest/php/maps/gml.gml
    A msautotest/php/maps/helloworld-gif.map
    A msautotest/php/maps/include/bdry_counpy2_postgis.map
    A msautotest/php/maps/include/bdry_counpy2_shapefile.map
    A msautotest/php/maps/include/indx_q100kpy4_shapefile.map
    A msautotest/php/maps/labels-leader.map
    A msautotest/php/maps/labels.map
    A msautotest/php/maps/ogr_query.map
    A msautotest/php/maps/ows_wms.map
    A msautotest/php/maps/plant4.jpg
    A msautotest/php/maps/query.map
    A msautotest/php/maps/querymap.map
    A msautotest/php/maps/saveQueryAsGML
    A msautotest/php/maps/style_opacity.map
    A msautotest/php/maps/sunflower.gif
    A msautotest/php/maps/symbolset
    A msautotest/php/maps/template.map
    A msautotest/php/maps/template/feature.tmpl
    A msautotest/php/maps/template/html.tmpl
    A msautotest/php/maps/template/query.tmpl
    A msautotest/php/maps/template/template.html
    A msautotest/php/maps/test.gml
    A msautotest/php/maps/test.map
    A msautotest/php/maps/wms_simple.map
    A msautotest/php/outputFrmtObj.php
    A msautotest/php/owsRequestObjTest.php
    A msautotest/php/pointObjTest.php
    A msautotest/php/projectionObjTest.php
    A msautotest/php/queryMapObjTest.php
    A msautotest/php/rectObjTest.php
    A msautotest/php/run_test.py
    A msautotest/php/run_test.sh
    A msautotest/php/shapeFileObjTest.php
    A msautotest/php/shapeObjTest.php
    A msautotest/php/styleObjTest.php
    A msautotest/php/symbolObjTest.php
    A msautotest/php/webObjTest.php
    A msautotest/pymod/.cvsignore
    A msautotest/pymod/README_MSAUTOTEST_VIEWER
    A msautotest/pymod/config.cfg
    A msautotest/pymod/httpd_msautotest.conf
    A msautotest/pymod/index.html
    A msautotest/pymod/msautotest_viewer.py
    A msautotest/pymod/mstestlib.py
    A msautotest/pymod/pmstestlib.py
    A msautotest/pymod/testlib.py
    A msautotest/query/.gitignore
    A msautotest/query/context.map
    A msautotest/query/data/bdry_counpy2.dbf
    A msautotest/query/data/bdry_counpy2.shp
    A msautotest/query/data/bdry_counpy2.shx
    A msautotest/query/data/indx_q100kpy4.dbf
    A msautotest/query/data/indx_q100kpy4.shp
    A msautotest/query/data/indx_q100kpy4.shx
    A msautotest/query/expected/context_test001.gif
    A msautotest/query/expected/context_test002.gif
    A msautotest/query/expected/context_test003.gif
    A msautotest/query/expected/filters_test001.gif
    A msautotest/query/expected/filters_test002.gif
    A msautotest/query/expected/filters_test003.gif
    A msautotest/query/expected/filters_test004.gif
    A msautotest/query/expected/filters_test005.gif
    A msautotest/query/expected/filters_test006.gif
    A msautotest/query/expected/filters_test007.gif
    A msautotest/query/expected/filters_test008.gif
    A msautotest/query/expected/filters_test009.gif
    A msautotest/query/expected/filters_test010.gif
    A msautotest/query/expected/query_postgis_test001.txt
    A msautotest/query/expected/query_postgis_test002.txt
    A msautotest/query/expected/query_postgis_test003.txt
    A msautotest/query/expected/query_postgis_test004.txt
    A msautotest/query/expected/query_postgis_test005.txt
    A msautotest/query/expected/query_postgis_test006.txt
    A msautotest/query/expected/query_postgis_test007.txt
    A msautotest/query/expected/query_postgis_test008.txt
    A msautotest/query/expected/query_postgis_test009.txt
    A msautotest/query/expected/query_postgis_test010.txt
    A msautotest/query/expected/query_postgis_test011.txt
    A msautotest/query/expected/query_postgis_test012.txt
    A msautotest/query/expected/query_test001.txt
    A msautotest/query/expected/query_test002.txt
    A msautotest/query/expected/query_test003.txt
    A msautotest/query/expected/query_test004.txt
    A msautotest/query/expected/query_test005.txt
    A msautotest/query/expected/query_test006.txt
    A msautotest/query/expected/query_test007.txt
    A msautotest/query/expected/query_test008.txt
    A msautotest/query/expected/query_test009.txt
    A msautotest/query/expected/query_test010.txt
    A msautotest/query/expected/query_test011.txt
    A msautotest/query/expected/query_test012.txt
    A msautotest/query/expected/querymap_test001.gif
    A msautotest/query/expected/querymap_test002.gif
    A msautotest/query/expected/querymap_test003.gif
    A msautotest/query/expected/querymap_test004.gif
    A msautotest/query/expected/querymap_test005.gif
    A msautotest/query/expected/querymap_test006.gif
    A msautotest/query/expected/querymap_test007.gif
    A msautotest/query/expected/querymap_test008.gif
    A msautotest/query/expected/querymap_test009.gif
    A msautotest/query/expected/querymap_test010.gif
    A msautotest/query/expected/querymap_test011.gif
    A msautotest/query/expected/rfc62_test001.txt
    A msautotest/query/expected/rfc62_test002.txt
    A msautotest/query/expected/rfc62_test003.txt
    A msautotest/query/expected/template_test001.html
    A msautotest/query/expected/template_test002.html
    A msautotest/query/expected/text_test001.png
    A msautotest/query/expected/text_test002.png
    A msautotest/query/expected/text_test003.png
    A msautotest/query/expected/text_test004.png
    A msautotest/query/expected/text_test005.png
    A msautotest/query/expected/text_test006.png
    A msautotest/query/expected/text_test007.png
    A msautotest/query/filters.map
    A msautotest/query/include/bdry_counpy2_postgis.map
    A msautotest/query/include/bdry_counpy2_shapefile.map
    A msautotest/query/include/indx_q100kpy4_shapefile.map
    A msautotest/query/query.map
    A msautotest/query/query_postgis.map
    A msautotest/query/querymap.map
    A msautotest/query/rfc62.map
    A msautotest/query/run_test.py
    A msautotest/query/template.map
    A msautotest/query/template/feature.tmpl
    A msautotest/query/template/html.tmpl
    A msautotest/query/template/query.tmpl
    A msautotest/query/text.map
    A msautotest/renderers/average_rgb.map
    A msautotest/renderers/baseline_text.map
    A msautotest/renderers/chartlayer_bar.map
    A msautotest/renderers/chartlayer_pie.map
    A msautotest/renderers/chartlayer_pie2.map
    A msautotest/renderers/chartlayer_pie_expressions.map
    A msautotest/renderers/chartlayer_vbar.map
    A msautotest/renderers/circle_layer.map
    A msautotest/renderers/data/VL-Gothic-Regular.ttf
    A msautotest/renderers/data/fonts.lst
    A msautotest/renderers/data/wind_12.tif
    A msautotest/renderers/data/world.tif
    A msautotest/renderers/data/world_testlines.dbf
    A msautotest/renderers/data/world_testlines.prj
    A msautotest/renderers/data/world_testlines.qpj
    A msautotest/renderers/data/world_testlines.shp
    A msautotest/renderers/data/world_testlines.shx
    A msautotest/renderers/data/world_testpoly.dbf
    A msautotest/renderers/data/world_testpoly.shp
    A msautotest/renderers/data/world_testpoly.shx
    A msautotest/renderers/embed_legend.map
    A msautotest/renderers/embed_legend_rgba.map
    A msautotest/renderers/embed_legend_rgba_tr.map
    A msautotest/renderers/embed_legend_tr.map
    A msautotest/renderers/embed_sb_rgb.map
    A msautotest/renderers/embed_sb_rgb_tr.map
    A msautotest/renderers/embed_sb_rgba.map
    A msautotest/renderers/embed_sb_rgba_tr.map
    A msautotest/renderers/empty.map
    A msautotest/renderers/entity_encoded_follow_text.map
    A msautotest/renderers/expected/average_rgb.cairo.png
    A msautotest/renderers/expected/average_rgb.gif
    A msautotest/renderers/expected/average_rgb.pdf
    A msautotest/renderers/expected/average_rgb.png
    A msautotest/renderers/expected/average_rgb.svg
    A msautotest/renderers/expected/baseline_text.cairo.png
    A msautotest/renderers/expected/baseline_text.gif
    A msautotest/renderers/expected/baseline_text.pdf
    A msautotest/renderers/expected/baseline_text.png
    A msautotest/renderers/expected/baseline_text.svg
    A msautotest/renderers/expected/chartlayer_bar.cairo.png
    A msautotest/renderers/expected/chartlayer_bar.gif
    A msautotest/renderers/expected/chartlayer_bar.pdf
    A msautotest/renderers/expected/chartlayer_bar.png
    A msautotest/renderers/expected/chartlayer_bar.svg
    A msautotest/renderers/expected/chartlayer_pie.cairo.png
    A msautotest/renderers/expected/chartlayer_pie.gif
    A msautotest/renderers/expected/chartlayer_pie.pdf
    A msautotest/renderers/expected/chartlayer_pie.png
    A msautotest/renderers/expected/chartlayer_pie.svg
    A msautotest/renderers/expected/chartlayer_pie2.cairo.png
    A msautotest/renderers/expected/chartlayer_pie2.gif
    A msautotest/renderers/expected/chartlayer_pie2.pdf
    A msautotest/renderers/expected/chartlayer_pie2.png
    A msautotest/renderers/expected/chartlayer_pie2.svg
    A msautotest/renderers/expected/chartlayer_pie_expressions.cairo.png
    A msautotest/renderers/expected/chartlayer_pie_expressions.gif
    A msautotest/renderers/expected/chartlayer_pie_expressions.pdf
    A msautotest/renderers/expected/chartlayer_pie_expressions.png
    A msautotest/renderers/expected/chartlayer_pie_expressions.svg
    A msautotest/renderers/expected/chartlayer_vbar.cairo.png
    A msautotest/renderers/expected/chartlayer_vbar.gif
    A msautotest/renderers/expected/chartlayer_vbar.pdf
    A msautotest/renderers/expected/chartlayer_vbar.png
    A msautotest/renderers/expected/chartlayer_vbar.svg
    A msautotest/renderers/expected/circle_layer.cairo.png
    A msautotest/renderers/expected/circle_layer.gif
    A msautotest/renderers/expected/circle_layer.pdf
    A msautotest/renderers/expected/circle_layer.png
    A msautotest/renderers/expected/circle_layer.svg
    A msautotest/renderers/expected/embed_legend.cairo.png
    A msautotest/renderers/expected/embed_legend.gif
    A msautotest/renderers/expected/embed_legend.png
    A msautotest/renderers/expected/embed_legend_rgba.cairo.png
    A msautotest/renderers/expected/embed_legend_rgba.gif
    A msautotest/renderers/expected/embed_legend_rgba.png
    A msautotest/renderers/expected/embed_legend_rgba_tr.cairo.png
    A msautotest/renderers/expected/embed_legend_rgba_tr.gif
    A msautotest/renderers/expected/embed_legend_rgba_tr.png
    A msautotest/renderers/expected/embed_legend_tr.cairo.png
    A msautotest/renderers/expected/embed_legend_tr.gif
    A msautotest/renderers/expected/embed_legend_tr.png
    A msautotest/renderers/expected/embed_sb_rgb.cairo.png
    A msautotest/renderers/expected/embed_sb_rgb.gif
    A msautotest/renderers/expected/embed_sb_rgb.png
    A msautotest/renderers/expected/embed_sb_rgb_tr.cairo.png
    A msautotest/renderers/expected/embed_sb_rgb_tr.gif
    A msautotest/renderers/expected/embed_sb_rgb_tr.png
    A msautotest/renderers/expected/embed_sb_rgba.cairo.png
    A msautotest/renderers/expected/embed_sb_rgba.gif
    A msautotest/renderers/expected/embed_sb_rgba.png
    A msautotest/renderers/expected/embed_sb_rgba_tr.cairo.png
    A msautotest/renderers/expected/embed_sb_rgba_tr.gif
    A msautotest/renderers/expected/embed_sb_rgba_tr.png
    A msautotest/renderers/expected/empty.cairo.png
    A msautotest/renderers/expected/empty.gif
    A msautotest/renderers/expected/empty.pdf
    A msautotest/renderers/expected/empty.png
    A msautotest/renderers/expected/empty.svg
    A msautotest/renderers/expected/entity_encoded_follow_text.cairo.png
    A msautotest/renderers/expected/entity_encoded_follow_text.gif
    A msautotest/renderers/expected/entity_encoded_follow_text.pdf
    A msautotest/renderers/expected/entity_encoded_follow_text.png
    A msautotest/renderers/expected/entity_encoded_follow_text.svg
    A msautotest/renderers/expected/force_palette.cairo.png
    A msautotest/renderers/expected/force_palette.gif
    A msautotest/renderers/expected/force_palette.png
    A msautotest/renderers/expected/force_palette_rgba.cairo.png
    A msautotest/renderers/expected/force_palette_rgba.gif
    A msautotest/renderers/expected/force_palette_rgba.png
    A msautotest/renderers/expected/force_pc256.cairo.png
    A msautotest/renderers/expected/force_pc256.gif
    A msautotest/renderers/expected/force_pc256.png
    A msautotest/renderers/expected/force_pc256_rgba.cairo.png
    A msautotest/renderers/expected/force_pc256_rgba.gif
    A msautotest/renderers/expected/force_pc256_rgba.png
    A msautotest/renderers/expected/geomtransform-vertex-layer.cairo.png
    A msautotest/renderers/expected/geomtransform-vertex-layer.gif
    A msautotest/renderers/expected/geomtransform-vertex-layer.pdf
    A msautotest/renderers/expected/geomtransform-vertex-layer.png
    A msautotest/renderers/expected/geomtransform-vertex-layer.svg
    A msautotest/renderers/expected/geomtransform-vertex.cairo.png
    A msautotest/renderers/expected/geomtransform-vertex.gif
    A msautotest/renderers/expected/geomtransform-vertex.pdf
    A msautotest/renderers/expected/geomtransform-vertex.png
    A msautotest/renderers/expected/geomtransform-vertex.svg
    A msautotest/renderers/expected/grid.cairo.png
    A msautotest/renderers/expected/grid.gif
    A msautotest/renderers/expected/grid.pdf
    A msautotest/renderers/expected/grid.png
    A msautotest/renderers/expected/grid.svg
    A msautotest/renderers/expected/label-multifont.cairo.png
    A msautotest/renderers/expected/label-multifont.gif
    A msautotest/renderers/expected/label-multifont.pdf
    A msautotest/renderers/expected/label-multifont.png
    A msautotest/renderers/expected/label-multifont.svg
    A msautotest/renderers/expected/label_noclip.cairo.png
    A msautotest/renderers/expected/label_noclip.gif
    A msautotest/renderers/expected/label_noclip.pdf
    A msautotest/renderers/expected/label_noclip.png
    A msautotest/renderers/expected/label_noclip.svg
    A msautotest/renderers/expected/labelpnt.cairo.png
    A msautotest/renderers/expected/labelpnt.gif
    A msautotest/renderers/expected/labelpnt.pdf
    A msautotest/renderers/expected/labelpnt.png
    A msautotest/renderers/expected/labelpnt.svg
    A msautotest/renderers/expected/labelrot.cairo.png
    A msautotest/renderers/expected/labelrot.gif
    A msautotest/renderers/expected/labelrot.pdf
    A msautotest/renderers/expected/labelrot.png
    A msautotest/renderers/expected/labelrot.svg
    A msautotest/renderers/expected/labels-anno.cairo.png
    A msautotest/renderers/expected/labels-anno.gif
    A msautotest/renderers/expected/labels-anno.pdf
    A msautotest/renderers/expected/labels-anno.png
    A msautotest/renderers/expected/labels-anno.svg
    A msautotest/renderers/expected/labels-bitmap-multiline.gif
    A msautotest/renderers/expected/labels-bitmap-multiline.png
    A msautotest/renderers/expected/labels-bitmap.gif
    A msautotest/renderers/expected/labels-bitmap.png
    A msautotest/renderers/expected/labels-leader.cairo.png
    A msautotest/renderers/expected/labels-leader.gif
    A msautotest/renderers/expected/labels-leader.pdf
    A msautotest/renderers/expected/labels-leader.png
    A msautotest/renderers/expected/labels-leader.svg
    A msautotest/renderers/expected/labels.cairo.png
    A msautotest/renderers/expected/labels.gif
    A msautotest/renderers/expected/labels.pdf
    A msautotest/renderers/expected/labels.png
    A msautotest/renderers/expected/labels.svg
    A msautotest/renderers/expected/legend_resolution_point_1.png
    A msautotest/renderers/expected/legend_resolution_point_2.png
    A msautotest/renderers/expected/legend_resolution_point_4.png
    A msautotest/renderers/expected/line_anchorpoint.cairo.png
    A msautotest/renderers/expected/line_anchorpoint.png
    A msautotest/renderers/expected/line_label_auto.cairo.png
    A msautotest/renderers/expected/line_label_auto.gif
    A msautotest/renderers/expected/line_label_auto.pdf
    A msautotest/renderers/expected/line_label_auto.png
    A msautotest/renderers/expected/line_label_auto.svg
    A msautotest/renderers/expected/line_label_auto2.cairo.png
    A msautotest/renderers/expected/line_label_auto2.gif
    A msautotest/renderers/expected/line_label_auto2.pdf
    A msautotest/renderers/expected/line_label_auto2.png
    A msautotest/renderers/expected/line_label_auto2.svg
    A msautotest/renderers/expected/line_label_follow.cairo.png
    A msautotest/renderers/expected/line_label_follow.gif
    A msautotest/renderers/expected/line_label_follow.pdf
    A msautotest/renderers/expected/line_label_follow.png
    A msautotest/renderers/expected/line_label_follow.svg
    A msautotest/renderers/expected/line_label_follow_offsetted.cairo.png
    A msautotest/renderers/expected/line_label_follow_offsetted.gif
    A msautotest/renderers/expected/line_label_follow_offsetted.pdf
    A msautotest/renderers/expected/line_label_follow_offsetted.png
    A msautotest/renderers/expected/line_label_follow_offsetted.svg
    A msautotest/renderers/expected/line_marker_pixmap.cairo.png
    A msautotest/renderers/expected/line_marker_pixmap.gif
    A msautotest/renderers/expected/line_marker_pixmap.pdf
    A msautotest/renderers/expected/line_marker_pixmap.png
    A msautotest/renderers/expected/line_marker_pixmap.svg
    A msautotest/renderers/expected/line_marker_svg.cairo.png
    A msautotest/renderers/expected/line_marker_svg.pdf
    A msautotest/renderers/expected/line_marker_svg.png
    A msautotest/renderers/expected/line_marker_svg.svg
    A msautotest/renderers/expected/line_marker_vector.cairo.png
    A msautotest/renderers/expected/line_marker_vector.gif
    A msautotest/renderers/expected/line_marker_vector.pdf
    A msautotest/renderers/expected/line_marker_vector.png
    A msautotest/renderers/expected/line_marker_vector.svg
    A msautotest/renderers/expected/line_offset.cairo.png
    A msautotest/renderers/expected/line_offset.gif
    A msautotest/renderers/expected/line_offset.pdf
    A msautotest/renderers/expected/line_offset.png
    A msautotest/renderers/expected/line_offset.svg
    A msautotest/renderers/expected/line_pattern.cairo.png
    A msautotest/renderers/expected/line_pattern.gif
    A msautotest/renderers/expected/line_pattern.pdf
    A msautotest/renderers/expected/line_pattern.png
    A msautotest/renderers/expected/line_pattern.svg
    A msautotest/renderers/expected/line_pattern_offset.cairo.png
    A msautotest/renderers/expected/line_pattern_offset.gif
    A msautotest/renderers/expected/line_pattern_offset.pdf
    A msautotest/renderers/expected/line_pattern_offset.png
    A msautotest/renderers/expected/line_pattern_offset.svg
    A msautotest/renderers/expected/line_short_gap.cairo.png
    A msautotest/renderers/expected/line_short_gap.gif
    A msautotest/renderers/expected/line_short_gap.pdf
    A msautotest/renderers/expected/line_short_gap.png
    A msautotest/renderers/expected/line_short_gap.svg
    A msautotest/renderers/expected/line_simple.cairo.jpg
    A msautotest/renderers/expected/line_simple.cairo.png
    A msautotest/renderers/expected/line_simple.gif
    A msautotest/renderers/expected/line_simple.pdf
    A msautotest/renderers/expected/line_simple.png
    A msautotest/renderers/expected/line_simple.svg
    A msautotest/renderers/expected/marker_anchorpoint.cairo.png
    A msautotest/renderers/expected/marker_anchorpoint.gif
    A msautotest/renderers/expected/marker_anchorpoint.pdf
    A msautotest/renderers/expected/marker_anchorpoint.png
    A msautotest/renderers/expected/marker_anchorpoint.svg
    A msautotest/renderers/expected/marker_pixmap.cairo.png
    A msautotest/renderers/expected/marker_pixmap.gif
    A msautotest/renderers/expected/marker_pixmap.pdf
    A msautotest/renderers/expected/marker_pixmap.png
    A msautotest/renderers/expected/marker_pixmap.svg
    A msautotest/renderers/expected/mask.cairo.png
    A msautotest/renderers/expected/mask.gif
    A msautotest/renderers/expected/mask.png
    A msautotest/renderers/expected/mask_opacity.cairo.png
    A msautotest/renderers/expected/mask_opacity.gif
    A msautotest/renderers/expected/mask_opacity.png
    A msautotest/renderers/expected/multilabel.cairo.png
    A msautotest/renderers/expected/multilabel.gif
    A msautotest/renderers/expected/multilabel.pdf
    A msautotest/renderers/expected/multilabel.png
    A msautotest/renderers/expected/multilabel.svg
    A msautotest/renderers/expected/nodata_8bit.cairo.png
    A msautotest/renderers/expected/nodata_8bit.gif
    A msautotest/renderers/expected/nodata_8bit.pdf
    A msautotest/renderers/expected/nodata_8bit.png
    A msautotest/renderers/expected/nodata_8bit.svg
    A msautotest/renderers/expected/plb_embed_legend.cairo.png
    A msautotest/renderers/expected/plb_embed_legend.gif
    A msautotest/renderers/expected/plb_embed_legend.png
    A msautotest/renderers/expected/plb_embed_legend_rgba.cairo.png
    A msautotest/renderers/expected/plb_embed_legend_rgba.gif
    A msautotest/renderers/expected/plb_embed_legend_rgba.png
    A msautotest/renderers/expected/plb_embed_legend_rgba_tr.cairo.png
    A msautotest/renderers/expected/plb_embed_legend_rgba_tr.gif
    A msautotest/renderers/expected/plb_embed_legend_rgba_tr.png
    A msautotest/renderers/expected/plb_embed_legend_tr.cairo.png
    A msautotest/renderers/expected/plb_embed_legend_tr.gif
    A msautotest/renderers/expected/plb_embed_legend_tr.png
    A msautotest/renderers/expected/point-polaroffset.cairo.png
    A msautotest/renderers/expected/point-polaroffset.gif
    A msautotest/renderers/expected/point-polaroffset.pdf
    A msautotest/renderers/expected/point-polaroffset.png
    A msautotest/renderers/expected/point-polaroffset.svg
    A msautotest/renderers/expected/point_ellipse.cairo.png
    A msautotest/renderers/expected/point_ellipse.gif
    A msautotest/renderers/expected/point_ellipse.pdf
    A msautotest/renderers/expected/point_ellipse.png
    A msautotest/renderers/expected/point_ellipse.svg
    A msautotest/renderers/expected/point_pixmap.cairo.png
    A msautotest/renderers/expected/point_pixmap.gif
    A msautotest/renderers/expected/point_pixmap.pdf
    A msautotest/renderers/expected/point_pixmap.png
    A msautotest/renderers/expected/point_pixmap.svg
    A msautotest/renderers/expected/point_pixmap_gif.cairo.png
    A msautotest/renderers/expected/point_pixmap_gif.gif
    A msautotest/renderers/expected/point_pixmap_gif.pdf
    A msautotest/renderers/expected/point_pixmap_gif.png
    A msautotest/renderers/expected/point_pixmap_gif.svg
    A msautotest/renderers/expected/point_svg.cairo.png
    A msautotest/renderers/expected/point_svg.gif
    A msautotest/renderers/expected/point_svg.pdf
    A msautotest/renderers/expected/point_svg.png
    A msautotest/renderers/expected/point_svg.svg
    A msautotest/renderers/expected/point_truetype.cairo.png
    A msautotest/renderers/expected/point_truetype.gif
    A msautotest/renderers/expected/point_truetype.pdf
    A msautotest/renderers/expected/point_truetype.png
    A msautotest/renderers/expected/point_truetype.svg
    A msautotest/renderers/expected/point_vector.cairo.png
    A msautotest/renderers/expected/point_vector.gif
    A msautotest/renderers/expected/point_vector.pdf
    A msautotest/renderers/expected/point_vector.png
    A msautotest/renderers/expected/point_vector.svg
    A msautotest/renderers/expected/poly-label-pos-auto.cairo.png
    A msautotest/renderers/expected/poly-label-pos-auto.gif
    A msautotest/renderers/expected/poly-label-pos-auto.pdf
    A msautotest/renderers/expected/poly-label-pos-auto.png
    A msautotest/renderers/expected/poly-label-pos-auto.svg
    A msautotest/renderers/expected/poly_geomtransform_anchor.cairo.png
    A msautotest/renderers/expected/poly_geomtransform_anchor.gif
    A msautotest/renderers/expected/poly_geomtransform_anchor.pdf
    A msautotest/renderers/expected/poly_geomtransform_anchor.png
    A msautotest/renderers/expected/poly_geomtransform_anchor.svg
    A msautotest/renderers/expected/polygon-as-line-offset.cairo.png
    A msautotest/renderers/expected/polygon-as-line-offset.gif
    A msautotest/renderers/expected/polygon-as-line-offset.pdf
    A msautotest/renderers/expected/polygon-as-line-offset.png
    A msautotest/renderers/expected/polygon-as-line-offset.svg
    A msautotest/renderers/expected/polygon-as-line.cairo.png
    A msautotest/renderers/expected/polygon-as-line.gif
    A msautotest/renderers/expected/polygon-as-line.pdf
    A msautotest/renderers/expected/polygon-as-line.png
    A msautotest/renderers/expected/polygon-as-line.svg
    A msautotest/renderers/expected/polygon-hatch-dashed.cairo.png
    A msautotest/renderers/expected/polygon-hatch-dashed.gif
    A msautotest/renderers/expected/polygon-hatch-dashed.pdf
    A msautotest/renderers/expected/polygon-hatch-dashed.png
    A msautotest/renderers/expected/polygon-hatch-dashed.svg
    A msautotest/renderers/expected/polygon-hatch.cairo.png
    A msautotest/renderers/expected/polygon-hatch.gif
    A msautotest/renderers/expected/polygon-hatch.pdf
    A msautotest/renderers/expected/polygon-hatch.png
    A msautotest/renderers/expected/polygon-hatch.svg
    A msautotest/renderers/expected/polygon-pixmap.cairo.png
    A msautotest/renderers/expected/polygon-pixmap.gif
    A msautotest/renderers/expected/polygon-pixmap.pdf
    A msautotest/renderers/expected/polygon-pixmap.png
    A msautotest/renderers/expected/polygon-pixmap.svg
    A msautotest/renderers/expected/polygon-simple.cairo.png
    A msautotest/renderers/expected/polygon-simple.gif
    A msautotest/renderers/expected/polygon-simple.pdf
    A msautotest/renderers/expected/polygon-simple.png
    A msautotest/renderers/expected/polygon-simple.svg
    A msautotest/renderers/expected/polygon-ttf.cairo.png
    A msautotest/renderers/expected/polygon-ttf.gif
    A msautotest/renderers/expected/polygon-ttf.pdf
    A msautotest/renderers/expected/polygon-ttf.png
    A msautotest/renderers/expected/polygon-ttf.svg
    A msautotest/renderers/expected/polygon-vector.cairo.png
    A msautotest/renderers/expected/polygon-vector.gif
    A msautotest/renderers/expected/polygon-vector.pdf
    A msautotest/renderers/expected/polygon-vector.png
    A msautotest/renderers/expected/polygon-vector.svg
    A msautotest/renderers/expected/polyline_no_clip.png
    A msautotest/renderers/expected/raster_simple.cairo.png
    A msautotest/renderers/expected/raster_simple.gif
    A msautotest/renderers/expected/raster_simple.pdf
    A msautotest/renderers/expected/raster_simple.png
    A msautotest/renderers/expected/raster_simple.svg
    A msautotest/renderers/expected/raster_simple_opacity.cairo.png
    A msautotest/renderers/expected/raster_simple_opacity.gif
    A msautotest/renderers/expected/raster_simple_opacity.pdf
    A msautotest/renderers/expected/raster_simple_opacity.png
    A msautotest/renderers/expected/raster_simple_opacity.svg
    A msautotest/renderers/expected/reproj.cairo.png
    A msautotest/renderers/expected/reproj.gif
    A msautotest/renderers/expected/reproj.pdf
    A msautotest/renderers/expected/reproj.png
    A msautotest/renderers/expected/reproj.svg
    A msautotest/renderers/expected/resolution_line_1.png
    A msautotest/renderers/expected/resolution_line_2.png
    A msautotest/renderers/expected/resolution_line_4.png
    A msautotest/renderers/expected/resolution_point_1.png
    A msautotest/renderers/expected/resolution_point_2.png
    A msautotest/renderers/expected/resolution_point_4.png
    A msautotest/renderers/expected/resolution_polygon_1.png
    A msautotest/renderers/expected/resolution_polygon_2.png
    A msautotest/renderers/expected/resolution_polygon_4.png
    A msautotest/renderers/expected/resolution_text_1.png
    A msautotest/renderers/expected/resolution_text_2.png
    A msautotest/renderers/expected/resolution_text_4.png
    A msautotest/renderers/expected/rgb_overlay.cairo.png
    A msautotest/renderers/expected/rgb_overlay.gif
    A msautotest/renderers/expected/rgb_overlay.pdf
    A msautotest/renderers/expected/rgb_overlay.png
    A msautotest/renderers/expected/rgb_overlay.svg
    A msautotest/renderers/expected/rgb_overlay_res.cairo.png
    A msautotest/renderers/expected/rgb_overlay_res.gif
    A msautotest/renderers/expected/rgb_overlay_res.pdf
    A msautotest/renderers/expected/rgb_overlay_res.png
    A msautotest/renderers/expected/rgb_overlay_res.svg
    A msautotest/renderers/expected/rgb_overlay_res_to8bit.cairo.png
    A msautotest/renderers/expected/rgb_overlay_res_to8bit.gif
    A msautotest/renderers/expected/rgb_overlay_res_to8bit.pdf
    A msautotest/renderers/expected/rgb_overlay_res_to8bit.png
    A msautotest/renderers/expected/rgb_overlay_res_to8bit.svg
    A msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.cairo.png
    A msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.gif
    A msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.pdf
    A msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.png
    A msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.svg
    A msautotest/renderers/expected/rgba_overlay_res.cairo.png
    A msautotest/renderers/expected/rgba_overlay_res.gif
    A msautotest/renderers/expected/rgba_overlay_res.pdf
    A msautotest/renderers/expected/rgba_overlay_res.png
    A msautotest/renderers/expected/rgba_overlay_res.svg
    A msautotest/renderers/expected/transparent_layer.cairo.png
    A msautotest/renderers/expected/transparent_layer.gif
    A msautotest/renderers/expected/transparent_layer.pdf
    A msautotest/renderers/expected/transparent_layer.png
    A msautotest/renderers/expected/transparent_layer.svg
    A msautotest/renderers/expected/uvraster.cairo.png
    A msautotest/renderers/expected/uvraster.gif
    A msautotest/renderers/expected/uvraster.pdf
    A msautotest/renderers/expected/uvraster.png
    A msautotest/renderers/expected/uvraster.svg
    A msautotest/renderers/expected/uvraster_reproj.cairo.png
    A msautotest/renderers/expected/uvraster_reproj.gif
    A msautotest/renderers/expected/uvraster_reproj.pdf
    A msautotest/renderers/expected/uvraster_reproj.png
    A msautotest/renderers/expected/uvraster_reproj.svg
    A msautotest/renderers/expected/wld_rotate.cairo.png
    A msautotest/renderers/expected/wld_rotate.gif
    A msautotest/renderers/expected/wld_rotate.pdf
    A msautotest/renderers/expected/wld_rotate.png
    A msautotest/renderers/expected/wld_rotate.svg
    A msautotest/renderers/expected/wld_upsidedown.cairo.png
    A msautotest/renderers/expected/wld_upsidedown.gif
    A msautotest/renderers/expected/wld_upsidedown.pdf
    A msautotest/renderers/expected/wld_upsidedown.png
    A msautotest/renderers/expected/wld_upsidedown.svg
    A msautotest/renderers/expected/wmsclient.cairo.png
    A msautotest/renderers/expected/wmsclient.gif
    A msautotest/renderers/expected/wmsclient.pdf
    A msautotest/renderers/expected/wmsclient.png
    A msautotest/renderers/expected/wmsclient.svg
    A msautotest/renderers/force_palette.map
    A msautotest/renderers/force_palette_rgba.map
    A msautotest/renderers/force_pc256.map
    A msautotest/renderers/force_pc256_rgba.map
    A msautotest/renderers/geomtransform-vertex.map
    A msautotest/renderers/grid.map
    A msautotest/renderers/label-multifont.map
    A msautotest/renderers/label_noclip.map
    A msautotest/renderers/labelpnt.map
    A msautotest/renderers/labelrot.map
    A msautotest/renderers/labels-anno.map
    A msautotest/renderers/labels-bitmap-multiline.map
    A msautotest/renderers/labels-bitmap.map
    A msautotest/renderers/labels-leader.map
    A msautotest/renderers/labels.map
    A msautotest/renderers/line_anchorpoint.map
    A msautotest/renderers/line_label_auto.map
    A msautotest/renderers/line_label_auto2.map
    A msautotest/renderers/line_label_follow.map
    A msautotest/renderers/line_label_follow_offsetted.map
    A msautotest/renderers/line_marker_pixmap.map
    A msautotest/renderers/line_marker_svg.map
    A msautotest/renderers/line_marker_vector.map
    A msautotest/renderers/line_offset.map
    A msautotest/renderers/line_pattern.map
    A msautotest/renderers/line_pattern_offset.map
    A msautotest/renderers/line_short_gap.map
    A msautotest/renderers/line_simple.map
    A msautotest/renderers/marker_anchorpoint.map
    A msautotest/renderers/marker_pixmap.map
    A msautotest/renderers/mask.map
    A msautotest/renderers/mask_opacity.map
    A msautotest/renderers/multilabel.map
    A msautotest/renderers/nodata_8bit.map
    A msautotest/renderers/palette.txt
    A msautotest/renderers/palette_rgba.txt
    A msautotest/renderers/plb_embed_legend.map
    A msautotest/renderers/plb_embed_legend_rgba.map
    A msautotest/renderers/plb_embed_legend_rgba_tr.map
    A msautotest/renderers/plb_embed_legend_tr.map
    A msautotest/renderers/point-polaroffset.map
    A msautotest/renderers/point_ellipse.map
    A msautotest/renderers/point_pixmap.map
    A msautotest/renderers/point_pixmap_gif.map
    A msautotest/renderers/point_svg.map
    A msautotest/renderers/point_truetype.map
    A msautotest/renderers/point_vector.map
    A msautotest/renderers/poly-label-pos-auto.map
    A msautotest/renderers/poly_geomtransform_anchor.map
    A msautotest/renderers/polygon-as-line-offset.map
    A msautotest/renderers/polygon-as-line.map
    A msautotest/renderers/polygon-hatch-dashed.map
    A msautotest/renderers/polygon-hatch.map
    A msautotest/renderers/polygon-pixmap.map
    A msautotest/renderers/polygon-simple.map
    A msautotest/renderers/polygon-ttf.map
    A msautotest/renderers/polygon-vector.map
    A msautotest/renderers/polyline_no_clip.map
    A msautotest/renderers/raster_simple.map
    A msautotest/renderers/raster_simple_opacity.map
    A msautotest/renderers/reproj.map
    A msautotest/renderers/resolution.map
    A msautotest/renderers/rgb_overlay.map
    A msautotest/renderers/rgb_overlay_res.map
    A msautotest/renderers/rgb_overlay_res_to8bit.map
    A msautotest/renderers/rgb_overlay_res_to8bit_dithered.map
    A msautotest/renderers/rgba_overlay_res.map
    A msautotest/renderers/run_test.py
    A msautotest/renderers/symbolset
    A msautotest/renderers/transparent_layer.map
    A msautotest/renderers/uvraster.map
    A msautotest/renderers/uvraster_reproj.map
    A msautotest/renderers/wld_rotate.map
    A msautotest/renderers/wld_upsidedown.map
    A msautotest/renderers/wmsclient.map
    A msautotest/valgrind-suppressions.txt
    A msautotest/wxs/contour_tileindex.map
    A msautotest/wxs/data/alltypes.csv
    A msautotest/wxs/data/alltypes.csvt
    A msautotest/wxs/data/contour_gwm.tif
    A msautotest/wxs/data/contour_gwm_2.tif
    A msautotest/wxs/data/contour_ti.dbf
    A msautotest/wxs/data/contour_ti.prj
    A msautotest/wxs/data/contour_ti.shp
    A msautotest/wxs/data/contour_ti.shx
    A msautotest/wxs/data/epsg2
    A msautotest/wxs/data/grey.tif
    A msautotest/wxs/data/grey.wld
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportArea.dbf
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportArea.prj
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportArea.qix
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportArea.sbn
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportArea.sbx
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportArea.shp
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportArea.shx
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportLink.dbf
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportLink.prj
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportLink.qix
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportLink.sbn
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportLink.sbx
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportLink.shp
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportLink.shx
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportNode.dbf
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportNode.prj
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportNode.qix
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportNode.sbn
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportNode.sbx
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportNode.shp
    A msautotest/wxs/data/inspire/TN.CommonTransportElements.TransportNode.shx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayArea.dbf
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayArea.prj
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayArea.qix
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayArea.sbn
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayArea.sbx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayArea.shp
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayArea.shx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayLink.dbf
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayLink.prj
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayLink.qix
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayLink.sbn
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayLink.sbx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayLink.shp
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayLink.shx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayStationArea.dbf
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayStationArea.prj
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayStationArea.qix
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayStationArea.sbn
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayStationArea.sbx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayStationArea.shp
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayStationArea.shx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayYardArea.dbf
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayYardArea.prj
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayYardArea.qix
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayYardArea.sbn
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayYardArea.sbx
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayYardArea.shp
    A msautotest/wxs/data/inspire/TN.RailTransportNetwork.RailwayYardArea.shx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadArea.dbf
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadArea.prj
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadArea.qix
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadArea.sbn
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadArea.sbx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadArea.shp
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadArea.shx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadLink.dbf
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadLink.prj
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadLink.qix
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadLink.sbn
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadLink.sbx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadLink.shp
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadLink.shx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.dbf
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.prj
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.qix
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.sbn
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.sbx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.shp
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.RoadServiceArea.shx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.dbf
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.prj
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.qix
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.sbn
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.sbx
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.shp
    A msautotest/wxs/data/inspire/TN.RoadTransportNetwork.VehicleTrafficArea.shx
    A msautotest/wxs/data/lakes2.dbf
    A msautotest/wxs/data/lakes2.prj
    A msautotest/wxs/data/lakes2.qpj
    A msautotest/wxs/data/lakes2.shp
    A msautotest/wxs/data/lakes2.shx
    A msautotest/wxs/data/land_shallow_topo_2048.tif
    A msautotest/wxs/data/land_shallow_topo_2048.txt
    A msautotest/wxs/data/land_shallow_topo_2048.wld
    A msautotest/wxs/data/multi.csv
    A msautotest/wxs/data/multiband.tif
    A msautotest/wxs/data/mums.gfs
    A msautotest/wxs/data/mums.gml
    A msautotest/wxs/data/mums.xsd
    A msautotest/wxs/data/obs.csv
    A msautotest/wxs/data/obs.dbf
    A msautotest/wxs/data/obs.ovf
    A msautotest/wxs/data/obs.shp
    A msautotest/wxs/data/obs.shx
    A msautotest/wxs/data/pattern1.dbf
    A msautotest/wxs/data/pattern1.shp
    A msautotest/wxs/data/pattern1.shx
    A msautotest/wxs/data/pattern10.dbf
    A msautotest/wxs/data/pattern10.shp
    A msautotest/wxs/data/pattern10.shx
    A msautotest/wxs/data/pattern11.dbf
    A msautotest/wxs/data/pattern11.shp
    A msautotest/wxs/data/pattern11.shx
    A msautotest/wxs/data/pattern12.dbf
    A msautotest/wxs/data/pattern12.shp
    A msautotest/wxs/data/pattern12.shx
    A msautotest/wxs/data/pattern13.dbf
    A msautotest/wxs/data/pattern13.shp
    A msautotest/wxs/data/pattern13.shx
    A msautotest/wxs/data/pattern14.dbf
    A msautotest/wxs/data/pattern14.shp
    A msautotest/wxs/data/pattern14.shx
    A msautotest/wxs/data/pattern15.dbf
    A msautotest/wxs/data/pattern15.shp
    A msautotest/wxs/data/pattern15.shx
    A msautotest/wxs/data/pattern2.dbf
    A msautotest/wxs/data/pattern2.shp
    A msautotest/wxs/data/pattern2.shx
    A msautotest/wxs/data/pattern3.dbf
    A msautotest/wxs/data/pattern3.shp
    A msautotest/wxs/data/pattern3.shx
    A msautotest/wxs/data/pattern4.dbf
    A msautotest/wxs/data/pattern4.shp
    A msautotest/wxs/data/pattern4.shx
    A msautotest/wxs/data/pattern5.dbf
    A msautotest/wxs/data/pattern5.shp
    A msautotest/wxs/data/pattern5.shx
    A msautotest/wxs/data/pattern6.dbf
    A msautotest/wxs/data/pattern6.shp
    A msautotest/wxs/data/pattern6.shx
    A msautotest/wxs/data/pattern7.dbf
    A msautotest/wxs/data/pattern7.shp
    A msautotest/wxs/data/pattern7.shx
    A msautotest/wxs/data/pattern8.dbf
    A msautotest/wxs/data/pattern8.shp
    A msautotest/wxs/data/pattern8.shx
    A msautotest/wxs/data/pattern9.dbf
    A msautotest/wxs/data/pattern9.shp
    A msautotest/wxs/data/pattern9.shx
    A msautotest/wxs/data/popplace.dbf
    A msautotest/wxs/data/popplace.sbn
    A msautotest/wxs/data/popplace.sbx
    A msautotest/wxs/data/popplace.shp
    A msautotest/wxs/data/popplace.shx
    A msautotest/wxs/data/province.dbf
    A msautotest/wxs/data/province.sbn
    A msautotest/wxs/data/province.sbx
    A msautotest/wxs/data/province.shp
    A msautotest/wxs/data/province.shx
    A msautotest/wxs/data/rivers.dbf
    A msautotest/wxs/data/rivers.qix
    A msautotest/wxs/data/rivers.shp
    A msautotest/wxs/data/rivers.shx
    A msautotest/wxs/data/road.dbf
    A msautotest/wxs/data/road.sbn
    A msautotest/wxs/data/road.sbx
    A msautotest/wxs/data/road.shp
    A msautotest/wxs/data/road.shx
    A msautotest/wxs/data/road_eng.dbf
    A msautotest/wxs/data/road_eng.sbn
    A msautotest/wxs/data/road_eng.sbx
    A msautotest/wxs/data/road_eng.shp
    A msautotest/wxs/data/road_eng.shx
    A msautotest/wxs/data/road_ger.dbf
    A msautotest/wxs/data/road_ger.sbn
    A msautotest/wxs/data/road_ger.sbx
    A msautotest/wxs/data/road_ger.shp
    A msautotest/wxs/data/road_ger.shx
    A msautotest/wxs/data/sos-2147.xml
    A msautotest/wxs/data/sos-35.xml
    A msautotest/wxs/data/sos-604.xml
    A msautotest/wxs/data/toronto.tfw
    A msautotest/wxs/data/toronto.tif
    A msautotest/wxs/data/toronto.txt
    A msautotest/wxs/data/wcs_index.dbf
    A msautotest/wxs/data/wcs_index.shp
    A msautotest/wxs/data/wcs_index.shx
    A msautotest/wxs/data/wcs_mask.dbf
    A msautotest/wxs/data/wcs_mask.prj
    A msautotest/wxs/data/wcs_mask.qpj
    A msautotest/wxs/data/wcs_mask.shp
    A msautotest/wxs/data/wcs_mask.shx
    A msautotest/wxs/data/withnullvalues.csv
    A msautotest/wxs/data/withnullvalues.csvt
    A msautotest/wxs/etc/fonts.txt
    A msautotest/wxs/etc/largesld.sld
    A msautotest/wxs/etc/repeat.sld
    A msautotest/wxs/etc/symbols.sym
    A msautotest/wxs/etc/vera/COPYRIGHT.TXT
    A msautotest/wxs/etc/vera/README.TXT
    A msautotest/wxs/etc/vera/RELEASENOTES.TXT
    A msautotest/wxs/etc/vera/Vera.ttf
    A msautotest/wxs/etc/vera/VeraBd.ttf
    A msautotest/wxs/expected/mode_maplegend_74.png
    A msautotest/wxs/expected/mode_maplegend_all.png
    A msautotest/wxs/expected/ows_all_wfs_capabilities.xml
    A msautotest/wxs/expected/ows_all_wfs_getfeature.xml
    A msautotest/wxs/expected/ows_all_wms_capabilities.xml
    A msautotest/wxs/expected/ows_all_wms_capabilities_post.xml
    A msautotest/wxs/expected/ows_all_wms_getfeatureinfo.xml
    A msautotest/wxs/expected/ows_sos_capabilities.xml
    A msautotest/wxs/expected/ows_sos_describesensor.xml
    A msautotest/wxs/expected/ows_sos_disabled.xml
    A msautotest/wxs/expected/ows_sos_getobservation.xml
    A msautotest/wxs/expected/ows_wcs11_disabled.xml
    A msautotest/wxs/expected/ows_wcs20_disabled.xml
    A msautotest/wxs/expected/ows_wcs_capabilities.xml
    A msautotest/wxs/expected/ows_wcs_describecoverage.xml
    A msautotest/wxs/expected/ows_wcs_getcoverage.xml
    A msautotest/wxs/expected/ows_wfs10_disabled.xml
    A msautotest/wxs/expected/ows_wfs11_disabled.xml
    A msautotest/wxs/expected/ows_wfs_capabilities.xml
    A msautotest/wxs/expected/ows_wfs_describefeaturetype.xml
    A msautotest/wxs/expected/ows_wfs_getfeature.xml
    A msautotest/wxs/expected/ows_wms11_disabled.xml
    A msautotest/wxs/expected/ows_wms13_disabled.xml
    A msautotest/wxs/expected/ows_wms_capabilities.xml
    A msautotest/wxs/expected/ows_wms_describelayer.xml
    A msautotest/wxs/expected/ows_wms_getfeatureinfo.xml
    A msautotest/wxs/expected/ows_wms_getfeatureinfo_gml.xml
    A msautotest/wxs/expected/ows_wms_getfeatureinfo_gml_alias.xml
    A msautotest/wxs/expected/ows_wms_getfeatureinfo_plain.xml
    A msautotest/wxs/expected/ows_wms_getfeatureinfo_plain_alias.xml
    A msautotest/wxs/expected/ows_wms_getfeatureinfo_plain_noalias.xml
    A msautotest/wxs/expected/ows_wms_getlegendgraphic.xml
    A msautotest/wxs/expected/ows_wms_getmap.xml
    A msautotest/wxs/expected/ows_wms_getmap_exception.png
    A msautotest/wxs/expected/ows_wms_getmap_valid.png
    A msautotest/wxs/expected/sos_cap.xml
    A msautotest/wxs/expected/sos_cap0.xml
    A msautotest/wxs/expected/sos_cap1.xml
    A msautotest/wxs/expected/sos_caps_updatesequence.xml
    A msautotest/wxs/expected/sos_descobs.xml
    A msautotest/wxs/expected/sos_descobs_ex1.xml
    A msautotest/wxs/expected/sos_descobs_ex2.xml
    A msautotest/wxs/expected/sos_describe.xml
    A msautotest/wxs/expected/sos_exception_acceptversions.xml
    A msautotest/wxs/expected/sos_exception_updatesequence1.xml
    A msautotest/wxs/expected/sos_exception_updatesequence2.xml
    A msautotest/wxs/expected/sos_getobs_all.xml
    A msautotest/wxs/expected/sos_getobs_datablock.xml
    A msautotest/wxs/expected/sos_getobs_epsg_4326.xml
    A msautotest/wxs/expected/sos_getobs_filter.xml
    A msautotest/wxs/expected/sos_getobs_foi.xml
    A msautotest/wxs/expected/sos_getobs_proc.xml
    A msautotest/wxs/expected/sos_getobs_time.xml
    A msautotest/wxs/expected/sos_getobs_time_filter.xml
    A msautotest/wxs/expected/sos_getobs_time_filter_foi.xml
    A msautotest/wxs/expected/sos_se0.xml
    A msautotest/wxs/expected/sos_se1.xml
    A msautotest/wxs/expected/sos_se10.xml
    A msautotest/wxs/expected/sos_se11.xml
    A msautotest/wxs/expected/sos_se2.xml
    A msautotest/wxs/expected/sos_se3.xml
    A msautotest/wxs/expected/sos_se4.xml
    A msautotest/wxs/expected/sos_se5.xml
    A msautotest/wxs/expected/sos_se6.xml
    A msautotest/wxs/expected/sos_se7.xml
    A msautotest/wxs/expected/sos_se8.xml
    A msautotest/wxs/expected/sos_se9.xml
    A msautotest/wxs/expected/wcs11_cap.txt
    A msautotest/wxs/expected/wcs11_cap.xml
    A msautotest/wxs/expected/wcs11_caps_section1.xml
    A msautotest/wxs/expected/wcs11_caps_section2.xml
    A msautotest/wxs/expected/wcs11_caps_section3.xml
    A msautotest/wxs/expected/wcs11_caps_updatesequence.xml
    A msautotest/wxs/expected/wcs11_describe.xml
    A msautotest/wxs/expected/wcs11_exception_updatesequence1.xml
    A msautotest/wxs/expected/wcs11_exception_updatesequence2.xml
    A msautotest/wxs/expected/wcs11_post_cap.xml
    A msautotest/wxs/expected/wcs11_post_caps_section1.xml
    A msautotest/wxs/expected/wcs11_post_caps_section2.xml
    A msautotest/wxs/expected/wcs11_post_caps_section3.xml
    A msautotest/wxs/expected/wcs11_post_caps_updatesequence.xml
    A msautotest/wxs/expected/wcs11_post_describe.xml
    A msautotest/wxs/expected/wcs11_post_exception_invalidparam_coverage.xml
    A msautotest/wxs/expected/wcs11_post_exception_invalidparam_format.xml
    A msautotest/wxs/expected/wcs11_post_exception_invalidparam_request.xml
    A msautotest/wxs/expected/wcs11_post_exception_missingparam_coverage.xml
    A msautotest/wxs/expected/wcs11_post_exception_missingparam_format.xml
    A msautotest/wxs/expected/wcs11_post_exception_updatesequence1.xml
    A msautotest/wxs/expected/wcs11_post_exception_updatesequence2.xml
    A msautotest/wxs/expected/wcs11_post_getcov_gdpng8.dat
    A msautotest/wxs/expected/wcs11_post_getcov_grd.dat
    A msautotest/wxs/expected/wcs11_post_getcov_grd_4326.dat
    A msautotest/wxs/expected/wcs11_post_getcov_grd_imagecrs.dat
    A msautotest/wxs/expected/wcs11_post_getcov_grd_wgs84.dat
    A msautotest/wxs/expected/wcs_10_getcov_bands_name_new.dat
    A msautotest/wxs/expected/wcs_16.grd
    A msautotest/wxs/expected/wcs_16_ds.grd
    A msautotest/wxs/expected/wcs_16_repro.grd
    A msautotest/wxs/expected/wcs_20_cap.txt
    A msautotest/wxs/expected/wcs_20_cap.xml
    A msautotest/wxs/expected/wcs_20_cap_200.xml
    A msautotest/wxs/expected/wcs_20_cap_accept_versions.xml
    A msautotest/wxs/expected/wcs_20_cap_sections_all.xml
    A msautotest/wxs/expected/wcs_20_cap_sections_all_specific.xml
    A msautotest/wxs/expected/wcs_20_cap_sections_contents.xml
    A msautotest/wxs/expected/wcs_20_cap_sections_operations_metadata.xml
    A msautotest/wxs/expected/wcs_20_cap_sections_service_identification.xml
    A msautotest/wxs/expected/wcs_20_cap_sections_service_metadata.xml
    A msautotest/wxs/expected/wcs_20_cap_sections_service_provider.xml
    A msautotest/wxs/expected/wcs_20_cap_updatesequence.xml
    A msautotest/wxs/expected/wcs_20_desc.txt
    A msautotest/wxs/expected/wcs_20_desc.xml
    A msautotest/wxs/expected/wcs_20_desc_bands.xml
    A msautotest/wxs/expected/wcs_20_exception_exceed_maxsize.xml
    A msautotest/wxs/expected/wcs_20_exception_extent_nooverlap.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidaxislabel.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidaxislabel_2.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidparam_coverage.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidparam_format.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidparam_interpolation.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidparam_mediatype.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidparam_request.txt
    A msautotest/wxs/expected/wcs_20_exception_invalidparam_request.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidsubsetting.xml
    A msautotest/wxs/expected/wcs_20_exception_invalidsubsetting_2.xml
    A msautotest/wxs/expected/wcs_20_exception_missingparam_coverage.xml
    A msautotest/wxs/expected/wcs_20_exception_missingparam_request.xml
    A msautotest/wxs/expected/wcs_20_exception_requestparseerror.xml
    A msautotest/wxs/expected/wcs_20_exception_scaling.xml
    A msautotest/wxs/expected/wcs_20_exception_toomanyparams_coverage.xml
    A msautotest/wxs/expected/wcs_20_exception_updatesequence_equal.xml
    A msautotest/wxs/expected/wcs_20_exception_updatesequence_higher.xml
    A msautotest/wxs/expected/wcs_20_getcov_bands_index.tif
    A msautotest/wxs/expected/wcs_20_getcov_bands_index_new.tif
    A msautotest/wxs/expected/wcs_20_getcov_bands_name.dat
    A msautotest/wxs/expected/wcs_20_getcov_bands_name.tif
    A msautotest/wxs/expected/wcs_20_getcov_bands_name_new.dat
    A msautotest/wxs/expected/wcs_20_getcov_bands_name_new.tif
    A msautotest/wxs/expected/wcs_20_getcov_bands_name_new_reproject.dat
    A msautotest/wxs/expected/wcs_20_getcov_full.dat
    A msautotest/wxs/expected/wcs_20_getcov_full.png
    A msautotest/wxs/expected/wcs_20_getcov_full.tif
    A msautotest/wxs/expected/wcs_20_getcov_grd.dat
    A msautotest/wxs/expected/wcs_20_getcov_grd_mp.dat
    A msautotest/wxs/expected/wcs_20_getcov_imageCRS.tif
    A msautotest/wxs/expected/wcs_20_getcov_imageCRS_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_imageCRS_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_interpolation_average.tif
    A msautotest/wxs/expected/wcs_20_getcov_interpolation_bilinear.tif
    A msautotest/wxs/expected/wcs_20_getcov_interpolation_nearest.tif
    A msautotest/wxs/expected/wcs_20_getcov_native_format.tif
    A msautotest/wxs/expected/wcs_20_getcov_origCRS.tif
    A msautotest/wxs/expected/wcs_20_getcov_origCRS_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_origCRS_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_reproj.dat
    A msautotest/wxs/expected/wcs_20_getcov_reproj.tif
    A msautotest/wxs/expected/wcs_20_getcov_reproj_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_reproj_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_scaling_resolution_full.tif
    A msautotest/wxs/expected/wcs_20_getcov_scaling_resolution_size.tif
    A msautotest/wxs/expected/wcs_20_getcov_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_scaling_size_full.tif
    A msautotest/wxs/expected/wcs_20_getcov_scaling_size_resolution.tif
    A msautotest/wxs/expected/wcs_20_getcov_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_x_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_x_max.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_x_min.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_x_y_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_x_y_both_1px.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_y_both.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_y_max.tif
    A msautotest/wxs/expected/wcs_20_getcov_trim_y_min.tif
    A msautotest/wxs/expected/wcs_20_multi_getcov_trim_x_to_1px.tif
    A msautotest/wxs/expected/wcs_20_multi_getcov_trim_y_to_1px.tif
    A msautotest/wxs/expected/wcs_20_post_bands_index.tif
    A msautotest/wxs/expected/wcs_20_post_bands_index_new.tif
    A msautotest/wxs/expected/wcs_20_post_bands_name.dat
    A msautotest/wxs/expected/wcs_20_post_bands_name.tif
    A msautotest/wxs/expected/wcs_20_post_bands_name_new.dat
    A msautotest/wxs/expected/wcs_20_post_bands_name_new.tif
    A msautotest/wxs/expected/wcs_20_post_cap.xml
    A msautotest/wxs/expected/wcs_20_post_desc.xml
    A msautotest/wxs/expected/wcs_20_post_exception_extent_nooverlap.xml
    A msautotest/wxs/expected/wcs_20_post_exception_invalidparam_coverage.xml
    A msautotest/wxs/expected/wcs_20_post_exception_invalidparam_format.xml
    A msautotest/wxs/expected/wcs_20_post_exception_invalidparam_interpolation.xml
    A msautotest/wxs/expected/wcs_20_post_exception_invalidparam_request.xml
    A msautotest/wxs/expected/wcs_20_post_exception_missingparam_coverage.xml
    A msautotest/wxs/expected/wcs_20_post_exception_missingparam_format_no_native.xml
    A msautotest/wxs/expected/wcs_20_post_exception_scaling.xml
    A msautotest/wxs/expected/wcs_20_post_exception_toomanyparams_coverage.xml
    A msautotest/wxs/expected/wcs_20_post_getcov_full_multipart.dat
    A msautotest/wxs/expected/wcs_20_post_getcov_imageCRS.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_imageCRS_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_imageCRS_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_interpolation_average.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_interpolation_bilinear.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_interpolation_nearest.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_origCRS.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_origCRS_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_origCRS_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_reproj.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_reproj_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_reproj_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_scaling_resolution_full.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_scaling_resolution_size.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_scaling_size_full.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_scaling_size_resolution.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_x_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_x_max.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_x_min.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_x_y_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_x_y_both_1px.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_y_both.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_y_max.tif
    A msautotest/wxs/expected/wcs_20_post_getcov_trim_y_min.tif
    A msautotest/wxs/expected/wcs_bilinear.png
    A msautotest/wxs/expected/wcs_cap.txt
    A msautotest/wxs/expected/wcs_cap.xml
    A msautotest/wxs/expected/wcs_cap_highversion_x.xml
    A msautotest/wxs/expected/wcs_cap_highversion_x.y.xml
    A msautotest/wxs/expected/wcs_cap_highversion_x.y.z.xml
    A msautotest/wxs/expected/wcs_cap_noversion.xml
    A msautotest/wxs/expected/wcs_caps_updatesequence.xml
    A msautotest/wxs/expected/wcs_describe.xml
    A msautotest/wxs/expected/wcs_describe_coverage_tileindexmixedsrs_26711.xml
    A msautotest/wxs/expected/wcs_empty_cap100.xml
    A msautotest/wxs/expected/wcs_empty_cap110.xml
    A msautotest/wxs/expected/wcs_empty_cap200.xml
    A msautotest/wxs/expected/wcs_empty_cap_latestversion.xml
    A msautotest/wxs/expected/wcs_exception-2.xml
    A msautotest/wxs/expected/wcs_exception-3.xml
    A msautotest/wxs/expected/wcs_exception-4.xml
    A msautotest/wxs/expected/wcs_exception-5.xml
    A msautotest/wxs/expected/wcs_exception-6.xml
    A msautotest/wxs/expected/wcs_exception-7.xml
    A msautotest/wxs/expected/wcs_exception.xml
    A msautotest/wxs/expected/wcs_exception_updatesequence1.xml
    A msautotest/wxs/expected/wcs_exception_updatesequence2.xml
    A msautotest/wxs/expected/wcs_get_capabilities_tileindexmixedsrs_26711.xml
    A msautotest/wxs/expected/wcs_get_caps.xml
    A msautotest/wxs/expected/wcs_get_coverage_tileindexmixedsrs_26711.tif
    A msautotest/wxs/expected/wcs_getcov_exception_bands.xml
    A msautotest/wxs/expected/wcs_getcov_exception_bbox.xml
    A msautotest/wxs/expected/wcs_getcov_exception_maxsize.xml
    A msautotest/wxs/expected/wcs_getcov_grd_10.dat
    A msautotest/wxs/expected/wcs_getcov_grd_11.dat
    A msautotest/wxs/expected/wcs_getcov_grd_11_4326.dat
    A msautotest/wxs/expected/wcs_getcov_grd_11_imagecrs.dat
    A msautotest/wxs/expected/wcs_getcov_grd_11_wgs84.dat
    A msautotest/wxs/expected/wcs_getcov_png8_11.dat
    A msautotest/wxs/expected/wcs_mask_16.grd
    A msautotest/wxs/expected/wcs_mask_16_ds.grd
    A msautotest/wxs/expected/wcs_mask_16_repro.grd
    A msautotest/wxs/expected/wcs_mask_20_getcov_full.dat
    A msautotest/wxs/expected/wcs_mask_20_getcov_full.gif
    A msautotest/wxs/expected/wcs_mask_20_getcov_full.png
    A msautotest/wxs/expected/wcs_mask_20_getcov_full.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_grd.dat
    A msautotest/wxs/expected/wcs_mask_20_getcov_grd_mp.dat
    A msautotest/wxs/expected/wcs_mask_20_getcov_imageCRS.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_imageCRS_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_imageCRS_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_interpolation_average.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_interpolation_bilinear.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_interpolation_nearest.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_origCRS.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_origCRS_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_origCRS_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_reproj.dat
    A msautotest/wxs/expected/wcs_mask_20_getcov_reproj.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_reproj_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_reproj_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_scaling_resolution_full.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_scaling_resolution_size.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_scaling_resolution_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_scaling_size_full.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_scaling_size_resolution.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_scaling_size_trim_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_x_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_x_max.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_x_min.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_x_y_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_x_y_both_1px.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_y_both.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_y_max.tif
    A msautotest/wxs/expected/wcs_mask_20_getcov_trim_y_min.tif
    A msautotest/wxs/expected/wcs_mask_bilinear.gif
    A msautotest/wxs/expected/wcs_mask_bilinear.png
    A msautotest/wxs/expected/wcs_mask_getcov_grd_10.dat
    A msautotest/wxs/expected/wcs_mask_getcov_grd_11.dat
    A msautotest/wxs/expected/wcs_mask_getcov_grd_11_4326.dat
    A msautotest/wxs/expected/wcs_mask_getcov_grd_11_imagecrs.dat
    A msautotest/wxs/expected/wcs_mask_getcov_grd_11_wgs84.dat
    A msautotest/wxs/expected/wcs_mask_getcov_png8_11.dat
    A msautotest/wxs/expected/wcs_mask_simple.gif
    A msautotest/wxs/expected/wcs_mask_simple.png
    A msautotest/wxs/expected/wcs_post_exception1.xml
    A msautotest/wxs/expected/wcs_post_exception2.xml
    A msautotest/wxs/expected/wcs_simple.png
    A msautotest/wxs/expected/wfs11_cap.xml
    A msautotest/wxs/expected/wfs11_cap_ogr.xml
    A msautotest/wxs/expected/wfs11_caps_updatesequence.xml
    A msautotest/wxs/expected/wfs11_caps_updatesequence_ogr.xml
    A msautotest/wxs/expected/wfs11_describe.xml
    A msautotest/wxs/expected/wfs11_describe_ogr.xml
    A msautotest/wxs/expected/wfs11_exception.xml
    A msautotest/wxs/expected/wfs11_exception_invalid_srsname.xml
    A msautotest/wxs/expected/wfs11_exception_invalid_srsname_ogr.xml
    A msautotest/wxs/expected/wfs11_exception_ogr.xml
    A msautotest/wxs/expected/wfs11_exception_updatesequence1.xml
    A msautotest/wxs/expected/wfs11_exception_updatesequence1_ogr.xml
    A msautotest/wxs/expected/wfs11_exception_updatesequence2.xml
    A msautotest/wxs/expected/wfs11_exception_updatesequence2_ogr.xml
    A msautotest/wxs/expected/wfs11_get_feature.xml
    A msautotest/wxs/expected/wfs11_get_feature_hits.xml
    A msautotest/wxs/expected/wfs11_get_feature_hits_ogr.xml
    A msautotest/wxs/expected/wfs11_get_feature_id.xml
    A msautotest/wxs/expected/wfs11_get_feature_id_gml2.xml
    A msautotest/wxs/expected/wfs11_get_feature_id_gml2_ogr.xml
    A msautotest/wxs/expected/wfs11_get_feature_id_ogr.xml
    A msautotest/wxs/expected/wfs11_get_feature_maxfeatures.xml
    A msautotest/wxs/expected/wfs11_get_feature_maxfeatures_ogr.xml
    A msautotest/wxs/expected/wfs11_get_feature_ogr.xml
    A msautotest/wxs/expected/wfs11_get_feature_srsname.xml
    A msautotest/wxs/expected/wfs11_get_feature_srsname_ogr.xml
    A msautotest/wxs/expected/wfs_alltypes_describefeaturetype.xml
    A msautotest/wxs/expected/wfs_cap.xml
    A msautotest/wxs/expected/wfs_cap_ogr.xml
    A msautotest/wxs/expected/wfs_caps_updatesequence.xml
    A msautotest/wxs/expected/wfs_caps_updatesequence_ogr.xml
    A msautotest/wxs/expected/wfs_describe.xml
    A msautotest/wxs/expected/wfs_describe_feature_type_gml2.xml
    A msautotest/wxs/expected/wfs_describe_feature_type_gml3l0.xml
    A msautotest/wxs/expected/wfs_describe_ogr.xml
    A msautotest/wxs/expected/wfs_exception.xml
    A msautotest/wxs/expected/wfs_exception_ogr.xml
    A msautotest/wxs/expected/wfs_exception_updatesequence1.xml
    A msautotest/wxs/expected/wfs_exception_updatesequence1_ogr.xml
    A msautotest/wxs/expected/wfs_exception_updatesequence2.xml
    A msautotest/wxs/expected/wfs_exception_updatesequence2_ogr.xml
    A msautotest/wxs/expected/wfs_filter_bbox.xml
    A msautotest/wxs/expected/wfs_filter_bbox_urlepsg.xml
    A msautotest/wxs/expected/wfs_filter_bbox_urnepsg.xml
    A msautotest/wxs/expected/wfs_filter_beyond.xml
    A msautotest/wxs/expected/wfs_filter_contains.xml
    A msautotest/wxs/expected/wfs_filter_crosses.xml
    A msautotest/wxs/expected/wfs_filter_disjoint.xml
    A msautotest/wxs/expected/wfs_filter_dwithin.xml
    A msautotest/wxs/expected/wfs_filter_dwithin_multipoint.xml
    A msautotest/wxs/expected/wfs_filter_dwithin_units.xml
    A msautotest/wxs/expected/wfs_filter_equals.xml
    A msautotest/wxs/expected/wfs_filter_equals_poly.xml
    A msautotest/wxs/expected/wfs_filter_greater_than_or_equalto.xml
    A msautotest/wxs/expected/wfs_filter_intersects.xml
    A msautotest/wxs/expected/wfs_filter_intersects_line.xml
    A msautotest/wxs/expected/wfs_filter_intersects_multipoint.xml
    A msautotest/wxs/expected/wfs_filter_is_not_equal.xml
    A msautotest/wxs/expected/wfs_filter_isbetween.xml
    A msautotest/wxs/expected/wfs_filter_isbetween_and_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_isbetween_and_not_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_isbetween_or_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_iseq_or_iseq_str1.xml
    A msautotest/wxs/expected/wfs_filter_iseq_or_iseq_str2.xml
    A msautotest/wxs/expected/wfs_filter_iseq_or_iseq_str3.xml
    A msautotest/wxs/expected/wfs_filter_iseq_or_iseq_str4.xml
    A msautotest/wxs/expected/wfs_filter_iseq_or_iseq_str5.xml
    A msautotest/wxs/expected/wfs_filter_isequalto_and_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_isequalto_and_isequalto_reverse.xml
    A msautotest/wxs/expected/wfs_filter_isequalto_or_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_isequalto_or_isequalto_reverse.xml
    A msautotest/wxs/expected/wfs_filter_isgreater_than.xml
    A msautotest/wxs/expected/wfs_filter_isless_than.xml
    A msautotest/wxs/expected/wfs_filter_isless_than_or_equalto.xml
    A msautotest/wxs/expected/wfs_filter_islike.xml
    A msautotest/wxs/expected/wfs_filter_islike_logical.xml
    A msautotest/wxs/expected/wfs_filter_not_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_overlaps.xml
    A msautotest/wxs/expected/wfs_filter_postgis_bbox.xml
    A msautotest/wxs/expected/wfs_filter_postgis_beyond.xml
    A msautotest/wxs/expected/wfs_filter_postgis_contains.xml
    A msautotest/wxs/expected/wfs_filter_postgis_crosses.xml
    A msautotest/wxs/expected/wfs_filter_postgis_disjoint.xml
    A msautotest/wxs/expected/wfs_filter_postgis_dwithin.xml
    A msautotest/wxs/expected/wfs_filter_postgis_dwithin_units.xml
    A msautotest/wxs/expected/wfs_filter_postgis_equals.xml
    A msautotest/wxs/expected/wfs_filter_postgis_equals_poly.xml
    A msautotest/wxs/expected/wfs_filter_postgis_greater_than_or_equalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_intersects.xml
    A msautotest/wxs/expected/wfs_filter_postgis_intersects_line.xml
    A msautotest/wxs/expected/wfs_filter_postgis_is_not_equal.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isbetween.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isbetween_and_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isbetween_and_not_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isbetween_or_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_iseq_or_iseq_str1.xml
    A msautotest/wxs/expected/wfs_filter_postgis_iseq_or_iseq_str2.xml
    A msautotest/wxs/expected/wfs_filter_postgis_iseq_or_iseq_str3.xml
    A msautotest/wxs/expected/wfs_filter_postgis_iseq_or_iseq_str4.xml
    A msautotest/wxs/expected/wfs_filter_postgis_iseq_or_iseq_str5.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isequalto_and_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isequalto_and_isequalto_reverse.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isequalto_or_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isequalto_or_isequalto_reverse.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isgreater_than.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isless_than.xml
    A msautotest/wxs/expected/wfs_filter_postgis_isless_than_or_equalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_islike.xml
    A msautotest/wxs/expected/wfs_filter_postgis_islike_logical.xml
    A msautotest/wxs/expected/wfs_filter_postgis_not_isequalto.xml
    A msautotest/wxs/expected/wfs_filter_postgis_overlaps.xml
    A msautotest/wxs/expected/wfs_filter_postgis_property_is_equal.xml
    A msautotest/wxs/expected/wfs_filter_postgis_property_is_equal_quote1.xml
    A msautotest/wxs/expected/wfs_filter_postgis_property_is_equal_quote2.xml
    A msautotest/wxs/expected/wfs_filter_postgis_property_is_equal_quote3.xml
    A msautotest/wxs/expected/wfs_filter_postgis_property_is_equal_quote4.xml
    A msautotest/wxs/expected/wfs_filter_postgis_property_is_equal_quote5.xml
    A msautotest/wxs/expected/wfs_filter_postgis_property_is_equal_quote6.xml
    A msautotest/wxs/expected/wfs_filter_postgis_startindex.xml
    A msautotest/wxs/expected/wfs_filter_postgis_startindex2.xml
    A msautotest/wxs/expected/wfs_filter_postgis_touches.xml
    A msautotest/wxs/expected/wfs_filter_postgis_within.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_bbox.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_beyond.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_contains.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_crosses.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_disjoint.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_dwithin.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_equals.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_equals_poly.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_intersects.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_intersects_line.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_overlaps.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_touches.xml
    A msautotest/wxs/expected/wfs_filter_projmeter_within.xml
    A msautotest/wxs/expected/wfs_filter_property_is_equal.xml
    A msautotest/wxs/expected/wfs_filter_property_is_equal_quote1.xml
    A msautotest/wxs/expected/wfs_filter_property_is_equal_quote2.xml
    A msautotest/wxs/expected/wfs_filter_property_is_equal_quote3.xml
    A msautotest/wxs/expected/wfs_filter_property_is_equal_quote4.xml
    A msautotest/wxs/expected/wfs_filter_property_is_equal_quote5.xml
    A msautotest/wxs/expected/wfs_filter_property_is_equal_quote6.xml
    A msautotest/wxs/expected/wfs_filter_startindex.xml
    A msautotest/wxs/expected/wfs_filter_startindex2.xml
    A msautotest/wxs/expected/wfs_filter_touches.xml
    A msautotest/wxs/expected/wfs_filter_within.xml
    A msautotest/wxs/expected/wfs_get_caps.xml
    A msautotest/wxs/expected/wfs_get_feature.xml
    A msautotest/wxs/expected/wfs_get_feature_gml2.xml
    A msautotest/wxs/expected/wfs_get_feature_gml3l0.xml
    A msautotest/wxs/expected/wfs_get_feature_id.xml
    A msautotest/wxs/expected/wfs_get_feature_id_ogr.xml
    A msautotest/wxs/expected/wfs_get_feature_ogr.xml
    A msautotest/wxs/expected/wfs_get_feature_propertyname.xml
    A msautotest/wxs/expected/wfs_get_feature_propertyname_geometry.xml
    A msautotest/wxs/expected/wfs_get_feature_propertyname_geometry_ogr.xml
    A msautotest/wxs/expected/wfs_get_feature_propertyname_ogr.xml
    A msautotest/wxs/expected/wfs_getfeature_twotypenames1.xml
    A msautotest/wxs/expected/wfs_getfeature_twotypenames2.xml
    A msautotest/wxs/expected/wfsogr10_caps.xml
    A msautotest/wxs/expected/wfsogr10_csvstream.txt
    A msautotest/wxs/expected/wfsogr10_gml2.xml
    A msautotest/wxs/expected/wfsogr10_midmif.txt
    A msautotest/wxs/expected/wfsogr10_multi.xml
    A msautotest/wxs/expected/wfsogr10_nullnumeric.xml
    A msautotest/wxs/expected/wfsogr10_ograuto.xml
    A msautotest/wxs/expected/wfsogr10_ogrgml.xml
    A msautotest/wxs/expected/wfsogr10_shapezip.zip
    A msautotest/wxs/expected/wfsogr10_template.xml
    A msautotest/wxs/expected/wfsogr10_twolayer.xml
    A msautotest/wxs/expected/wfsogr11_caps.xml
    A msautotest/wxs/expected/wfsogr11_ogrcsv.xml
    A msautotest/wxs/expected/wfsogr11_ogrgml.xml
    A msautotest/wxs/expected/wfsogr11_ogrgml_ll.xml
    A msautotest/wxs/expected/wfsogr_wms_getfeatureinfo.xml
    A msautotest/wxs/expected/wms_cap.xml
    A msautotest/wxs/expected/wms_cap130.xml
    A msautotest/wxs/expected/wms_cap130_postgis.xml
    A msautotest/wxs/expected/wms_cap_1.1.1.xml
    A msautotest/wxs/expected/wms_cap_latestversion.xml
    A msautotest/wxs/expected/wms_cap_latestversion_postgis.xml
    A msautotest/wxs/expected/wms_cap_postgis.xml
    A msautotest/wxs/expected/wms_caps_updatesequence.xml
    A msautotest/wxs/expected/wms_caps_updatesequence_postgis.xml
    A msautotest/wxs/expected/wms_content_legend_all_all.png
    A msautotest/wxs/expected/wms_content_legend_all_all_sld.png
    A msautotest/wxs/expected/wms_content_legend_all_default.png
    A msautotest/wxs/expected/wms_content_legend_all_only74.png
    A msautotest/wxs/expected/wms_content_legend_all_only74_sld.png
    A msautotest/wxs/expected/wms_content_legend_empty_sld.png
    A msautotest/wxs/expected/wms_content_legend_l1_all.png
    A msautotest/wxs/expected/wms_content_legend_l1_all_sld.png
    A msautotest/wxs/expected/wms_content_legend_l1_changefont.png
    A msautotest/wxs/expected/wms_content_legend_l1_default.png
    A msautotest/wxs/expected/wms_content_legend_l1_only74.png
    A msautotest/wxs/expected/wms_content_legend_l1_only74_sld.png
    A msautotest/wxs/expected/wms_contour_inline_ti.png
    A msautotest/wxs/expected/wms_contour_layer_ti.png
    A msautotest/wxs/expected/wms_describe.xml
    A msautotest/wxs/expected/wms_describe_1.1.1.xml
    A msautotest/wxs/expected/wms_describe_layer.xml
    A msautotest/wxs/expected/wms_describe_postgis.xml
    A msautotest/wxs/expected/wms_describelayer130.xml
    A msautotest/wxs/expected/wms_describelayer130_postgis.xml
    A msautotest/wxs/expected/wms_dimension_cap.xml
    A msautotest/wxs/expected/wms_dimension_cap130.xml
    A msautotest/wxs/expected/wms_dimension_extent_1.png
    A msautotest/wxs/expected/wms_dimension_extent_2.png
    A msautotest/wxs/expected/wms_dimension_extent_3.xml
    A msautotest/wxs/expected/wms_dimension_extent_4.xml
    A msautotest/wxs/expected/wms_dimension_extent_5.xml
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_1.png
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_2.png
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_3.xml
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_4.png
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_5.png
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_6.xml
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_7.xml
    A msautotest/wxs/expected/wms_dimension_extent_multi_range_8.xml
    A msautotest/wxs/expected/wms_dimension_extent_range_1.png
    A msautotest/wxs/expected/wms_dimension_extent_range_2.png
    A msautotest/wxs/expected/wms_dimension_extent_range_3.xml
    A msautotest/wxs/expected/wms_dimension_extent_range_4.xml
    A msautotest/wxs/expected/wms_dimension_extent_range_5.xml
    A msautotest/wxs/expected/wms_dimension_misc_1.png
    A msautotest/wxs/expected/wms_dimension_numeric_1.png
    A msautotest/wxs/expected/wms_dimension_numeric_2.png
    A msautotest/wxs/expected/wms_dimension_numeric_3.xml
    A msautotest/wxs/expected/wms_dimension_numeric_4.xml
    A msautotest/wxs/expected/wms_dimension_numeric_5.xml
    A msautotest/wxs/expected/wms_dimension_string_1.png
    A msautotest/wxs/expected/wms_dimension_string_2.png
    A msautotest/wxs/expected/wms_dimension_string_3.xml
    A msautotest/wxs/expected/wms_dimension_string_4.xml
    A msautotest/wxs/expected/wms_dimension_string_5.xml
    A msautotest/wxs/expected/wms_empty_cap100.xml
    A msautotest/wxs/expected/wms_empty_cap111.xml
    A msautotest/wxs/expected/wms_empty_cap130.xml
    A msautotest/wxs/expected/wms_empty_cap_latestversion.xml
    A msautotest/wxs/expected/wms_exception130.xml
    A msautotest/wxs/expected/wms_exception130_postgis.xml
    A msautotest/wxs/expected/wms_exception_updatesequence1.xml
    A msautotest/wxs/expected/wms_exception_updatesequence1_postgis.xml
    A msautotest/wxs/expected/wms_exception_updatesequence2.xml
    A msautotest/wxs/expected/wms_exception_updatesequence2_postgis.xml
    A msautotest/wxs/expected/wms_get_capabilities_tileindexmixedsrs.xml
    A msautotest/wxs/expected/wms_get_caps.xml
    A msautotest/wxs/expected/wms_get_feature_info_raster.gml
    A msautotest/wxs/expected/wms_get_feature_info_raster.html
    A msautotest/wxs/expected/wms_get_feature_info_raster_feature_count.gml
    A msautotest/wxs/expected/wms_get_feature_info_vector.gml
    A msautotest/wxs/expected/wms_get_feature_info_vector.html
    A msautotest/wxs/expected/wms_get_legend_graphic.png
    A msautotest/wxs/expected/wms_get_map_ext_sld_404.xml
    A msautotest/wxs/expected/wms_get_map_ext_sld_fileproto.xml
    A msautotest/wxs/expected/wms_get_map_ext_sld_proto.xml
    A msautotest/wxs/expected/wms_get_map_ext_sld_too_large.xml
    A msautotest/wxs/expected/wms_get_map_ext_sld_too_large_override.png
    A msautotest/wxs/expected/wms_get_map_line_dash_sld.png
    A msautotest/wxs/expected/wms_get_map_line_dash_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_line_elsefilter_sld.png
    A msautotest/wxs/expected/wms_get_map_line_elsefilter_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_line_filter_islike.png
    A msautotest/wxs/expected/wms_get_map_line_filter_islike_postgis.png
    A msautotest/wxs/expected/wms_get_map_line_filter_sld.png
    A msautotest/wxs/expected/wms_get_map_line_filter_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_line_multi_filter_sld.png
    A msautotest/wxs/expected/wms_get_map_line_multi_filter_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_line_multi_symbol_text_sld.png
    A msautotest/wxs/expected/wms_get_map_line_multi_symbol_text_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_line_sld.png
    A msautotest/wxs/expected/wms_get_map_line_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_line_width_sld.png
    A msautotest/wxs/expected/wms_get_map_line_width_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_mark_symbol_filter_quote1_sld.png
    A msautotest/wxs/expected/wms_get_map_mark_symbol_filter_quote1_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_mark_symbol_filter_quote2_sld.png
    A msautotest/wxs/expected/wms_get_map_mark_symbol_filter_quote2_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_mark_symbol_sld.png
    A msautotest/wxs/expected/wms_get_map_mark_symbol_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_all_layers.png
    A msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_all_layers_postgis.png
    A msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_one_layer.png
    A msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_one_layer_postgis.png
    A msautotest/wxs/expected/wms_get_map_multi_polygon_filter.png
    A msautotest/wxs/expected/wms_get_map_multi_polygon_filter_postgis.png
    A msautotest/wxs/expected/wms_get_map_multi_styles_same_layer.png
    A msautotest/wxs/expected/wms_get_map_multi_styles_same_layer_postgis.png
    A msautotest/wxs/expected/wms_get_map_multi_styles_sld_same_layer.png
    A msautotest/wxs/expected/wms_get_map_multi_styles_sld_same_layer_postgis.png
    A msautotest/wxs/expected/wms_get_map_namedstyle_layerfeatureconstraints_postgis.png
    A msautotest/wxs/expected/wms_get_map_namedstyle_postgis.png
    A msautotest/wxs/expected/wms_get_map_polygon.kml
    A msautotest/wxs/expected/wms_get_map_polygon.kmz
    A msautotest/wxs/expected/wms_get_map_polygon.png
    A msautotest/wxs/expected/wms_get_map_polygon_fill_ext_symbol_sld.png
    A msautotest/wxs/expected/wms_get_map_polygon_fill_outline_sld.png
    A msautotest/wxs/expected/wms_get_map_polygon_fill_outline_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_polygon_fill_sld.png
    A msautotest/wxs/expected/wms_get_map_polygon_fill_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_polygon_fill_symbol_sld.png
    A msautotest/wxs/expected/wms_get_map_polygon_fill_symbol_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_polygon_postgis.png
    A msautotest/wxs/expected/wms_get_map_repeated_layer_ext_sld.png
    A msautotest/wxs/expected/wms_get_map_repeated_layer_sld.png
    A msautotest/wxs/expected/wms_get_map_sld_proj.png
    A msautotest/wxs/expected/wms_get_map_symbol_ext_sld.png
    A msautotest/wxs/expected/wms_get_map_text_alias_sld.png
    A msautotest/wxs/expected/wms_get_map_text_alias_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_text_sld.png
    A msautotest/wxs/expected/wms_get_map_text_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_text_symbol_sld.png
    A msautotest/wxs/expected/wms_get_map_text_symbol_sld_postgis.png
    A msautotest/wxs/expected/wms_get_map_tileindexmixedsrs.tif
    A msautotest/wxs/expected/wms_get_map_unsupported_featuretypeconstraints_extent.xml
    A msautotest/wxs/expected/wms_get_map_unsupported_featuretypename.xml
    A msautotest/wxs/expected/wms_get_map_unsupported_multiple_featuretypeconstraints.xml
    A msautotest/wxs/expected/wms_get_map_userstyle_filters_layerfeatureconstraints_postgis.png
    A msautotest/wxs/expected/wms_get_map_userstyle_layerfeatureconstraints_layer_with_filter_postgis.png
    A msautotest/wxs/expected/wms_get_map_userstyle_layerfeatureconstraints_postgis.png
    A msautotest/wxs/expected/wms_get_styles.sld
    A msautotest/wxs/expected/wms_getfeatureinfo.xml
    A msautotest/wxs/expected/wms_getfeatureinfo130.xml
    A msautotest/wxs/expected/wms_getfeatureinfo130_postgis.xml
    A msautotest/wxs/expected/wms_getmap.png
    A msautotest/wxs/expected/wms_getmap130.png
    A msautotest/wxs/expected/wms_getmap130_postgis.png
    A msautotest/wxs/expected/wms_getmap130crsexception.xml
    A msautotest/wxs/expected/wms_getmap130crsexception_postgis.xml
    A msautotest/wxs/expected/wms_getmap130layerlimitexception.xml
    A msautotest/wxs/expected/wms_getmap130layerlimitexception_postgis.xml
    A msautotest/wxs/expected/wms_getschemaex.xml
    A msautotest/wxs/expected/wms_getschemaex_postgis.xml
    A msautotest/wxs/expected/wms_getstyles.xml
    A msautotest/wxs/expected/wms_getstyles130.xml
    A msautotest/wxs/expected/wms_getstyles130_postgis.xml
    A msautotest/wxs/expected/wms_getstyles_postgis.xml
    A msautotest/wxs/expected/wms_inspire_cap.xml
    A msautotest/wxs/expected/wms_inspire_cap_111.xml
    A msautotest/wxs/expected/wms_inspire_cap_111_eng.xml
    A msautotest/wxs/expected/wms_inspire_cap_111_ger.xml
    A msautotest/wxs/expected/wms_inspire_cap_eng.xml
    A msautotest/wxs/expected/wms_inspire_cap_ger.xml
    A msautotest/wxs/expected/wms_inspire_describe_all.xml
    A msautotest/wxs/expected/wms_inspire_describe_commontransportelements.xml
    A msautotest/wxs/expected/wms_inspire_describe_railtransportnetwork.xml
    A msautotest/wxs/expected/wms_inspire_describe_roadtransportnetwork.xml
    A msautotest/wxs/expected/wms_inspire_describe_transportnode.xml
    A msautotest/wxs/expected/wms_inspire_featureinfo_all.xml
    A msautotest/wxs/expected/wms_inspire_featureinfo_all_mime_plain.txt
    A msautotest/wxs/expected/wms_inspire_featureinfo_all_mime_xml.txt
    A msautotest/wxs/expected/wms_inspire_featureinfo_commontransportelements.xml
    A msautotest/wxs/expected/wms_inspire_featureinfo_railtransportnetwork.xml
    A msautotest/wxs/expected/wms_inspire_featureinfo_roadtransportnetwork.xml
    A msautotest/wxs/expected/wms_inspire_legendgraphic_all.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_commontransportelements.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_railtransportnetwork.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_roadtransportnetwork.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_transportarea1.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_transportarea2.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_transportlink1.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_transportlink2.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_transportnode1.png
    A msautotest/wxs/expected/wms_inspire_legendgraphic_transportnode2.png
    A msautotest/wxs/expected/wms_inspire_map_all.png
    A msautotest/wxs/expected/wms_inspire_map_all_style1.png
    A msautotest/wxs/expected/wms_inspire_map_all_style2.png
    A msautotest/wxs/expected/wms_inspire_map_annotation.png
    A msautotest/wxs/expected/wms_inspire_map_commontransportelements.png
    A msautotest/wxs/expected/wms_inspire_map_railtransportnetwork.png
    A msautotest/wxs/expected/wms_inspire_map_railwayarea.png
    A msautotest/wxs/expected/wms_inspire_map_railwaylink.png
    A msautotest/wxs/expected/wms_inspire_map_railwaystationarea.png
    A msautotest/wxs/expected/wms_inspire_map_railwayyardarea.png
    A msautotest/wxs/expected/wms_inspire_map_roadarea.png
    A msautotest/wxs/expected/wms_inspire_map_roadlink.png
    A msautotest/wxs/expected/wms_inspire_map_roadservicearea.png
    A msautotest/wxs/expected/wms_inspire_map_roadtransportnetwork.png
    A msautotest/wxs/expected/wms_inspire_map_transportarea.png
    A msautotest/wxs/expected/wms_inspire_map_transportarea_style1.png
    A msautotest/wxs/expected/wms_inspire_map_transportarea_style2.png
    A msautotest/wxs/expected/wms_inspire_map_transportlink.png
    A msautotest/wxs/expected/wms_inspire_map_transportnode.png
    A msautotest/wxs/expected/wms_inspire_map_vehicletrafficarea.png
    A msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_cap130_eng.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_cap130_ger.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_describe130_airlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_describe130_roadarea.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_describe130_roadlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_describe130_transportlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_legendgraphic_airlink.png
    A msautotest/wxs/expected/wms_inspire_scenario1_legendgraphic_roadarea.png
    A msautotest/wxs/expected/wms_inspire_scenario1_legendgraphic_roadlink.png
    A msautotest/wxs/expected/wms_inspire_scenario1_legendgraphic_transportlink.png
    A msautotest/wxs/expected/wms_inspire_scenario1_map130_airlink.png
    A msautotest/wxs/expected/wms_inspire_scenario1_map130_roadarea.png
    A msautotest/wxs/expected/wms_inspire_scenario1_map130_roadlink.png
    A msautotest/wxs/expected/wms_inspire_scenario1_map130_transportlink.png
    A msautotest/wxs/expected/wms_inspire_scenario1_styles130_airlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_styles130_roadarea.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_styles130_roadlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario1_styles130_transportlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_cap111.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_cap111_eng.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_cap111_ger.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_cap130.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_cap130_eng.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_cap130_ger.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_describe130_airlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_describe130_roadarea.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_describe130_roadlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_describe130_transportlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_legendgraphic_airlink.png
    A msautotest/wxs/expected/wms_inspire_scenario2_legendgraphic_roadarea.png
    A msautotest/wxs/expected/wms_inspire_scenario2_legendgraphic_roadlink.png
    A msautotest/wxs/expected/wms_inspire_scenario2_legendgraphic_transportlink.png
    A msautotest/wxs/expected/wms_inspire_scenario2_map130_airlink.png
    A msautotest/wxs/expected/wms_inspire_scenario2_map130_roadarea.png
    A msautotest/wxs/expected/wms_inspire_scenario2_map130_roadlink.png
    A msautotest/wxs/expected/wms_inspire_scenario2_map130_transportlink.png
    A msautotest/wxs/expected/wms_inspire_scenario2_styles130_airlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_styles130_roadarea.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_styles130_roadlink.xml
    A msautotest/wxs/expected/wms_inspire_scenario2_styles130_transportlink.xml
    A msautotest/wxs/expected/wms_inspire_styles_all.xml
    A msautotest/wxs/expected/wms_inspire_styles_commontransportelements.xml
    A msautotest/wxs/expected/wms_inspire_styles_railtransportnetwork.xml
    A msautotest/wxs/expected/wms_inspire_styles_roadtransportnetwork.xml
    A msautotest/wxs/expected/wms_inspire_styles_transportnode.xml
    A msautotest/wxs/expected/wms_keyimage_legend.png
    A msautotest/wxs/expected/wms_nosld_cap.xml
    A msautotest/wxs/expected/wms_nosld_cap_postgis.xml
    A msautotest/wxs/expected/wms_nosld_get_map_line_sld.png
    A msautotest/wxs/expected/wms_nosld_get_map_line_sld_postgis.png
    A msautotest/wxs/expected/wms_nosld_legend.png
    A msautotest/wxs/expected/wms_nosld_legend_postgis.png
    A msautotest/wxs/expected/wms_rast_cap.xml
    A msautotest/wxs/expected/wms_rast_empty.txt
    A msautotest/wxs/expected/wms_rast_featureinfo.xml
    A msautotest/wxs/expected/wms_rast_featureinfo_reproj.xml
    A msautotest/wxs/expected/wms_time_cap.xml
    A msautotest/wxs/expected/wms_time_cap130.xml
    A msautotest/wxs/expected/wms_time_cap130_postgis_postgis.xml
    A msautotest/wxs/expected/wms_time_cap_postgis_postgis.xml
    A msautotest/wxs/expected/wms_time_default_value.png
    A msautotest/wxs/expected/wms_time_default_value_postgis.png
    A msautotest/wxs/expected/wms_time_multi_ranges_reso_hour.png
    A msautotest/wxs/expected/wms_time_multi_ranges_reso_hour_postgis.png
    A msautotest/wxs/expected/wms_time_multi_reverse.png
    A msautotest/wxs/expected/wms_time_multi_reverse_postgis.png
    A msautotest/wxs/expected/wms_time_no_default_value.xml
    A msautotest/wxs/expected/wms_time_no_default_value_postgis.xml
    A msautotest/wxs/expected/wms_time_no_time_param.png
    A msautotest/wxs/expected/wms_time_no_time_param_postgis.png
    A msautotest/wxs/expected/wms_time_out_of_extents_multi.xml
    A msautotest/wxs/expected/wms_time_out_of_extents_multi_postgis.xml
    A msautotest/wxs/expected/wms_time_out_of_extents_multi_ranges.xml
    A msautotest/wxs/expected/wms_time_out_of_extents_multi_ranges_postgis.xml
    A msautotest/wxs/expected/wms_time_out_of_extents_single.xml
    A msautotest/wxs/expected/wms_time_out_of_extents_single_postgis.xml
    A msautotest/wxs/expected/wms_time_out_of_extents_single_range.xml
    A msautotest/wxs/expected/wms_time_out_of_extents_single_range_postgis.xml
    A msautotest/wxs/expected/wms_time_pattern10a.png
    A msautotest/wxs/expected/wms_time_pattern10a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern10b.png
    A msautotest/wxs/expected/wms_time_pattern10b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern10c.png
    A msautotest/wxs/expected/wms_time_pattern10c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern10d.png
    A msautotest/wxs/expected/wms_time_pattern10d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern11a.png
    A msautotest/wxs/expected/wms_time_pattern11a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern11b.png
    A msautotest/wxs/expected/wms_time_pattern11b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern11c.png
    A msautotest/wxs/expected/wms_time_pattern11c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern11d.png
    A msautotest/wxs/expected/wms_time_pattern11d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern12a.png
    A msautotest/wxs/expected/wms_time_pattern12a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern12b.png
    A msautotest/wxs/expected/wms_time_pattern12b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern12c.png
    A msautotest/wxs/expected/wms_time_pattern12c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern12d.png
    A msautotest/wxs/expected/wms_time_pattern12d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern13a.png
    A msautotest/wxs/expected/wms_time_pattern13a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern13b.png
    A msautotest/wxs/expected/wms_time_pattern13b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern13c.png
    A msautotest/wxs/expected/wms_time_pattern13c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern13d.png
    A msautotest/wxs/expected/wms_time_pattern13d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern14a.png
    A msautotest/wxs/expected/wms_time_pattern14a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern14b.png
    A msautotest/wxs/expected/wms_time_pattern14b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern14c.png
    A msautotest/wxs/expected/wms_time_pattern14c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern14d.png
    A msautotest/wxs/expected/wms_time_pattern14d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern15a.png
    A msautotest/wxs/expected/wms_time_pattern15a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern15b.png
    A msautotest/wxs/expected/wms_time_pattern15b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern15c.png
    A msautotest/wxs/expected/wms_time_pattern15c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern15d.png
    A msautotest/wxs/expected/wms_time_pattern15d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern2a.png
    A msautotest/wxs/expected/wms_time_pattern2a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern2b.png
    A msautotest/wxs/expected/wms_time_pattern2b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern2c.png
    A msautotest/wxs/expected/wms_time_pattern2c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern3a.png
    A msautotest/wxs/expected/wms_time_pattern3a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern3b.png
    A msautotest/wxs/expected/wms_time_pattern3b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern3c.png
    A msautotest/wxs/expected/wms_time_pattern3c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern3d.png
    A msautotest/wxs/expected/wms_time_pattern3d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern4a.png
    A msautotest/wxs/expected/wms_time_pattern4a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern4b.png
    A msautotest/wxs/expected/wms_time_pattern4b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern4c.png
    A msautotest/wxs/expected/wms_time_pattern4c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern4d.png
    A msautotest/wxs/expected/wms_time_pattern4d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern5a.png
    A msautotest/wxs/expected/wms_time_pattern5a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern5b.png
    A msautotest/wxs/expected/wms_time_pattern5b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern5c.png
    A msautotest/wxs/expected/wms_time_pattern5c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern5d.png
    A msautotest/wxs/expected/wms_time_pattern5d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern6a.png
    A msautotest/wxs/expected/wms_time_pattern6a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern6b.png
    A msautotest/wxs/expected/wms_time_pattern6b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern6c.png
    A msautotest/wxs/expected/wms_time_pattern6c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern6d.png
    A msautotest/wxs/expected/wms_time_pattern6d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern7a.png
    A msautotest/wxs/expected/wms_time_pattern7a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern7b.png
    A msautotest/wxs/expected/wms_time_pattern7b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern7c.png
    A msautotest/wxs/expected/wms_time_pattern7c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern7d.png
    A msautotest/wxs/expected/wms_time_pattern7d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern8a.png
    A msautotest/wxs/expected/wms_time_pattern8a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern8b.png
    A msautotest/wxs/expected/wms_time_pattern8b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern8c.png
    A msautotest/wxs/expected/wms_time_pattern8c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern8d.png
    A msautotest/wxs/expected/wms_time_pattern8d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern9a.png
    A msautotest/wxs/expected/wms_time_pattern9a_postgis.png
    A msautotest/wxs/expected/wms_time_pattern9b.png
    A msautotest/wxs/expected/wms_time_pattern9b_postgis.png
    A msautotest/wxs/expected/wms_time_pattern9c.png
    A msautotest/wxs/expected/wms_time_pattern9c_postgis.png
    A msautotest/wxs/expected/wms_time_pattern9d.png
    A msautotest/wxs/expected/wms_time_pattern9d_postgis.png
    A msautotest/wxs/expected/wms_time_pattern_fail1.xml
    A msautotest/wxs/expected/wms_time_pattern_fail2.xml
    A msautotest/wxs/expected/wms_time_pattern_fail3.xml
    A msautotest/wxs/expected/wms_time_pattern_fail4.xml
    A msautotest/wxs/expected/wms_version_exception.xml
    A msautotest/wxs/expected/wms_version_exception_blank.png
    A msautotest/wxs/expected/wms_version_exception_blank_postgis.png
    A msautotest/wxs/expected/wms_version_exception_inimage.png
    A msautotest/wxs/expected/wms_version_exception_inimage_postgis.png
    A msautotest/wxs/expected/wms_version_exception_postgis.xml
    A msautotest/wxs/expected/wms_version_exception_xml.xml
    A msautotest/wxs/expected/wms_version_exception_xml_postgis.xml
    A msautotest/wxs/ows_all.map
    A msautotest/wxs/ows_disable.map
    A msautotest/wxs/ows_empty.map
    A msautotest/wxs/ows_sos.map
    A msautotest/wxs/ows_wcs.map
    A msautotest/wxs/ows_wfs.map
    A msautotest/wxs/ows_wms.map
    A msautotest/wxs/postgis.include
    A msautotest/wxs/run_test.py
    A msautotest/wxs/sos.map
    A msautotest/wxs/templates/land_shallow_topo_2048_query_body.html
    A msautotest/wxs/templates/land_shallow_topo_2048_query_header.html
    A msautotest/wxs/templates/mums_query_body.html
    A msautotest/wxs/templates/mums_query_header.html
    A msautotest/wxs/templates/none_query_body.html
    A msautotest/wxs/templates/none_query_header.html
    A msautotest/wxs/templates/query_footer.html
    A msautotest/wxs/templates/query_header.html
    A msautotest/wxs/templates/rivers_query_body.html
    A msautotest/wxs/templates/rivers_query_header.html
    A msautotest/wxs/tmp/.gitignore
    A msautotest/wxs/tomk_workshop.map
    A msautotest/wxs/wcs_mask.map
    A msautotest/wxs/wcs_multi.map
    A msautotest/wxs/wcs_post.map
    A msautotest/wxs/wcs_simple.map
    A msautotest/wxs/wcs_tileindexmixedsrs.map
    A msautotest/wxs/wfs_alltypes.map
    A msautotest/wxs/wfs_filter.map
    A msautotest/wxs/wfs_filter_postgis.map
    A msautotest/wxs/wfs_filter_projmeter.map
    A msautotest/wxs/wfs_misc.map
    A msautotest/wxs/wfs_ogr.map
    A msautotest/wxs/wfs_simple.map
    A msautotest/wxs/wfs_simple_ogr.map
    A msautotest/wxs/wms_dimensions.map
    A msautotest/wxs/wms_inspire.map
    A msautotest/wxs/wms_inspire_scenario1.map
    A msautotest/wxs/wms_inspire_scenario2.map
    A msautotest/wxs/wms_legend.map
    A msautotest/wxs/wms_nosld.map
    A msautotest/wxs/wms_nosld_postgis.map
    A msautotest/wxs/wms_raster.map
    A msautotest/wxs/wms_simple.map
    A msautotest/wxs/wms_simple_kml.map
    A msautotest/wxs/wms_simple_postgis.map
    A msautotest/wxs/wms_sld.map
    A msautotest/wxs/wms_sld2.map
    A msautotest/wxs/wms_sld_postgis.map
    A msautotest/wxs/wms_sld_proj.map
    A msautotest/wxs/wms_tileindexmixedsrs.map
    A msautotest/wxs/wms_time1.map
    A msautotest/wxs/wms_time1_postgis.map
    A msautotest/wxs/wms_time2.map
    A msautotest/wxs/wms_time2_postgis.map
    A msautotest/wxs/wms_time_pattern.map
    A msautotest/wxs/wms_time_pattern_12_13_test.map
    A msautotest/wxs/wms_time_pattern_12_13_test_postgis.map
    A msautotest/wxs/wms_time_pattern_fail.map
    A msautotest/wxs/wms_time_pattern_postgis.map
    M print-test-results.sh
    R run-test-suite.sh
  Log Message:
  Stop using a submodule for msautotests
backported from branch-7-0
