[mapserver-commits] [mapserver/mapserver] 3cf682: OGR: implement expression conversion to Spatialite...
GitHub noreply at github.com
Fri Jun 3 05:37:38 PDT 2016
  Branch: refs/heads/branch-7-0
  Home:   https://github.com/mapserver/mapserver
  Commit: 3cf682d17003521213868f1e727d7be7a3263c7e
      https://github.com/mapserver/mapserver/commit/3cf682d17003521213868f1e727d7be7a3263c7e
  Author: Ari Jolma <ari.jolma at gmail.com>
  Date:   2016-05-31 (Tue, 31 May 2016)
  Changed paths:
    M mapogr.cpp
    A msautotest/wxs/data/db.sqlite
    A msautotest/wxs/expected/wfs_ogr_native_sql_01.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_02.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_03.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_04.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_05.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_06.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_07.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_08.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_09.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_10.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_11.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_12.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_13.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_14.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_15.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_16.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_17.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_18.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_19.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_20.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_21.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_22.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_23.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_24.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_25.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_26.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_27.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_28.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_29.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_30.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_31.xml
    A msautotest/wxs/expected/wfs_ogr_native_sql_32.xml
    A msautotest/wxs/wfs_ogr_native_sql.map
    A msautotest/wxs/wfs_ogr_no_native_sql.map
  Log Message:
  OGR: implement expression conversion to Spatialite SQL
When serving a Spatialite DB through WFS for example, the WFS filter
was only evaluated on MapServer side instead of being evaluated by
SQLite + Spatialite functions.
  Commit: 0e20de083d7186298fbebbfd764ba721134ce3a0
      https://github.com/mapserver/mapserver/commit/0e20de083d7186298fbebbfd764ba721134ce3a0
  Author: Even Rouault <even.rouault at spatialys.com>
  Changed paths:
    M mapogr.cpp
  Log Message:
  Follow-up of 3cf682d17003521213868f1e727d7be7a3263c7e: simplify string handling in msOGRGetToken()
  Commit: 1f99a9f29fefebb7c0e5f39878061763506f94f1
      https://github.com/mapserver/mapserver/commit/1f99a9f29fefebb7c0e5f39878061763506f94f1
  Changed paths:
    M mapogr.cpp
  Log Message:
  Follow-up of 3cf682d17003521213868f1e727d7be7a3263c7e: windows build fix
  Commit: ee3397f4104d441c11784b2a65eddf6b41f416a3
      https://github.com/mapserver/mapserver/commit/ee3397f4104d441c11784b2a65eddf6b41f416a3
  Changed paths:
    M mapogr.cpp
  Log Message:
  Follow-up of 3cf682d17003521213868f1e727d7be7a3263c7e: fix memleak in Beyond case
  Commit: a534114825e7bcbfc5832be2e6880f15291cb9ef
      https://github.com/mapserver/mapserver/commit/a534114825e7bcbfc5832be2e6880f15291cb9ef
  Changed paths:
    M msautotest/valgrind-suppressions.txt
  Log Message:
  valgrind-suppressions.txt: add suppressions linked to libgdal
  Commit: 9996f079828d9ca1e24e11a5986a8f89d2eff0da
      https://github.com/mapserver/mapserver/commit/9996f079828d9ca1e24e11a5986a8f89d2eff0da
  Date:   2016-06-03 (Fri, 03 Jun 2016)
  Changed paths:
    M mapogr.cpp
  Log Message:
  Merge branch 'ajolma_spatialite' into branch-7-0
Compare: https://github.com/mapserver/mapserver/compare/bb577dd7da25...9996f079828d
