[mapserver-commits] [mapserver/mapserver] 9b8a90: [OGR] Do not install spatial filter on a layer wit...
GitHub noreply at github.com
Fri Sep 2 01:41:55 PDT 2016
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: 9b8a907eb6bf076b0ab1399a55245662294c0ce1
      https://github.com/mapserver/mapserver/commit/9b8a907eb6bf076b0ab1399a55245662294c0ce1
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2016-09-02 (Fri, 02 Sep 2016)
  Changed paths:
    M mapogr.cpp
    A msautotest/wxs/expected/wfs_ogr_native_sql_39.xml
    M msautotest/wxs/wfs_ogr_native_sql.map
  Log Message:
  [OGR] Do not install spatial filter on a layer without geometry to avoid a OGR error to be triggered at msOGRFileNextShape() time (typical of a SQLite/Spatialite/GPKG SQL select layer that returns zero records) (#5317)
  Commit: efa6ce2c6c821a0ff34e0e4d4a86fc5e11cee666
      https://github.com/mapserver/mapserver/commit/efa6ce2c6c821a0ff34e0e4d4a86fc5e11cee666
  Changed paths:
    M mapogr.cpp
  Log Message:
  Merge branch 'branch-7-0'
Compare: https://github.com/mapserver/mapserver/compare/e92f215da9ae...efa6ce2c6c82
