[mapserver-commits] [mapserver/mapserver] f8e104: msGetInnerList(): fix behaviour for inner ring tou...
GitHub noreply at github.com
Thu Sep 8 02:55:10 PDT 2016
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: f8e104e59df25e8a96bad8e36ca99539a353aae5
      https://github.com/mapserver/mapserver/commit/f8e104e59df25e8a96bad8e36ca99539a353aae5
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2016-09-08 (Thu, 08 Sep 2016)
  Changed paths:
    M mapprimitive.c
    A msautotest/wxs/data/test5299.csv
    A msautotest/wxs/expected/wfs_test5299.xml
    A msautotest/wxs/wfs_test5299.map
  Log Message:
  msGetInnerList(): fix behaviour for inner ring touching its outer ring (#5299)
Currently the behaviour was undefined if the first point of the inner
ring touched its outer ring.
  Commit: a1c396e9865218943b709acf81dae6628396515b
      https://github.com/mapserver/mapserver/commit/a1c396e9865218943b709acf81dae6628396515b
  Changed paths:
    M mapprimitive.c
  Log Message:
  Merge branch 'branch-7-0'
Compare: https://github.com/mapserver/mapserver/compare/efa6ce2c6c82...a1c396e98652
