[mapserver-commits] [mapserver/mapserver] 026847: msResampleGDALToMap(): fix issue that cause line p...
GitHub noreply at github.com
Tue Jan 17 08:24:19 PST 2017
  Branch: refs/heads/branch-7-0
  Home:   https://github.com/mapserver/mapserver
  Commit: 026847b1c962cdd666d28cfbe38ac40fff54ffbb
      https://github.com/mapserver/mapserver/commit/026847b1c962cdd666d28cfbe38ac40fff54ffbb
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2017-01-17 (Tue, 17 Jan 2017)
  Changed paths:
    M mapresample.c
    M msautotest/gdal/expected/average_rgb.png
    M msautotest/gdal/expected/average_rgb_plug.png
    M msautotest/gdal/expected/wmsclient_3543.png
    M msautotest/misc/expected/runtime_sub_test012.png
    M msautotest/misc/expected/runtime_sub_test013.png
    M msautotest/renderers/expected/average_rgb.cairo.png
    M msautotest/renderers/expected/average_rgb.pdf
    M msautotest/renderers/expected/average_rgb.png
    M msautotest/renderers/expected/average_rgb.svg
    M msautotest/renderers/expected/rgb_overlay_res.cairo.png
    M msautotest/renderers/expected/rgb_overlay_res.pdf
    M msautotest/renderers/expected/rgb_overlay_res.png
    M msautotest/renderers/expected/rgb_overlay_res.svg
    M msautotest/renderers/expected/rgb_overlay_res_to8bit.cairo.png
    M msautotest/renderers/expected/rgb_overlay_res_to8bit.pdf
    M msautotest/renderers/expected/rgb_overlay_res_to8bit.png
    M msautotest/renderers/expected/rgb_overlay_res_to8bit.svg
    M msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.cairo.png
    M msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.pdf
    M msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.png
    M msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.svg
    M msautotest/renderers/expected/rgba_overlay_res.cairo.png
    M msautotest/renderers/expected/rgba_overlay_res.pdf
    M msautotest/renderers/expected/rgba_overlay_res.png
    M msautotest/renderers/expected/rgba_overlay_res.svg
    M msautotest/renderers/expected/uvraster.cairo.png
    M msautotest/renderers/expected/uvraster.pdf
    M msautotest/renderers/expected/uvraster.png
    M msautotest/renderers/expected/uvraster.svg
    M msautotest/renderers/expected/uvraster_reproj.cairo.png
    M msautotest/renderers/expected/uvraster_reproj.pdf
    M msautotest/renderers/expected/uvraster_reproj.png
    M msautotest/renderers/expected/uvraster_reproj.svg
    M msautotest/wxs/expected/wcs11_post_getcov_gdpng8.dat
    M msautotest/wxs/expected/wcs11_post_getcov_grd_4326.dat
    M msautotest/wxs/expected/wcs11_post_getcov_grd_wgs84.dat
    M msautotest/wxs/expected/wcs_getcov_grd_11_4326.dat
    M msautotest/wxs/expected/wcs_getcov_grd_11_wgs84.dat
    M msautotest/wxs/expected/wcs_getcov_png8_11.dat
  Log Message:
  msResampleGDALToMap(): fix issue that cause line pattern in image mosaic (#1715)
  Commit: ba9e11aaddd4828dfb9d13e295d42d082deb8a28
      https://github.com/mapserver/mapserver/commit/ba9e11aaddd4828dfb9d13e295d42d082deb8a28
  Changed paths:
    M mapresample.c
  Log Message:
  Merge branch 'fix_1715' into branch-7-0
Compare: https://github.com/mapserver/mapserver/compare/bbe23e8c0b9c...ba9e11aaddd4
