[mapserver-commits] [mapserver/mapserver] 91d53b: Apply map rotation to symbols, similarly to the ru...
GitHub noreply at github.com
Mon Jun 11 04:08:06 PDT 2018
  Branch: refs/heads/branch-7-2
  Home:   https://github.com/mapserver/mapserver
  Commit: 91d53be63cf0061466ced1d99171039ef869e168
      https://github.com/mapserver/mapserver/commit/91d53be63cf0061466ced1d99171039ef869e168
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2018-06-11 (Mon, 11 Jun 2018)
  Changed paths:
    M mapdraw.c
    A msautotest/renderers/expected/symbolrot.png
    A msautotest/renderers/symbolrot.map
  Log Message:
  Apply map rotation to symbols, similarly to the rule of labels (fixes #5271)
If the symbol angle is unspecified or 0, then the map rotation is ignored.
Otherwise, the map rotation is applied.
  Commit: a14095b2516b8db9d7dbe78b23df6c4d2fe84371
      https://github.com/mapserver/mapserver/commit/a14095b2516b8db9d7dbe78b23df6c4d2fe84371
  Author: Even Rouault <even.rouault at mines-paris.org>
  Changed paths:
    M mapdraw.c
  Log Message:
  Merge pull request #5606 from rouault/fix_5271_branch72
Compare: https://github.com/mapserver/mapserver/compare/2f0678d38956...a14095b2516b
      **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
