[mapserver-commits] [mapserver/mapserver] bbb7ec: update for 7.2.0-beta1 release
GitHub noreply at github.com
Tue Jun 19 06:33:18 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: bbb7ec7dcaac5a3e29a66d088740567ab8c0fa02
      https://github.com/mapserver/mapserver/commit/bbb7ec7dcaac5a3e29a66d088740567ab8c0fa02
  Author: Steve Lime <steve.lime at state.mn.us>
  Date:   2018-05-09 (Wed, 09 May 2018)
  Changed paths:
    M CMakeLists.txt
    M HISTORY.TXT
  Log Message:
  Commit: 129a7169bf37fc5a49dc414819d83eb69ad533d6
      https://github.com/mapserver/mapserver/commit/129a7169bf37fc5a49dc414819d83eb69ad533d6
  Date:   2018-05-14 (Mon, 14 May 2018)
  Changed paths:
    M mappostgis.c
  Log Message:
  Backport small bug fix to quote the geo column name #5579/#5580.
  Commit: 0ba27aace586154219fc360777ece874cbec2b78
      https://github.com/mapserver/mapserver/commit/0ba27aace586154219fc360777ece874cbec2b78
  Author: Fabian Schindler <fabian.schindler.strauss at gmail.com>
  Date:   2018-05-30 (Wed, 30 May 2018)
  Changed paths:
    M mapwcs20.c
  Log Message:
  Fixing WCS 2.0 inspire download service schema location.
  Commit: c2d1458a2b8d22b4c6a5d975c907aa9a0e504dde
      https://github.com/mapserver/mapserver/commit/c2d1458a2b8d22b4c6a5d975c907aa9a0e504dde
  Changed paths:
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_default.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_multiple.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_secondary.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_unknown.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_default.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_multiple.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_secondary.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_unknown.xml
  Log Message:
  Fixing schema locations in expected test results.
  Commit: c0369c227b165b6e389d1f806f0e4e7b09ffd61a
      https://github.com/mapserver/mapserver/commit/c0369c227b165b6e389d1f806f0e4e7b09ffd61a
  Date:   2018-06-06 (Wed, 06 Jun 2018)
  Changed paths:
    M mapmvt.c
  Log Message:
  Small change for clarity - avoid reusing the mvt_buffer variable for extent.
  Commit: 706df49f899c70aacaea9502ed2474eca8be90ab
      https://github.com/mapserver/mapserver/commit/706df49f899c70aacaea9502ed2474eca8be90ab
  Author: Tamas Szekeres <szekerest at gmail.com>
  Changed paths:
    M mapmssql2008.c
  Log Message:
  Fix mssql filter string limitation (#5602)
  Commit: 2f0678d389562dc7054ffe36e6f08821cdbacf5e
      https://github.com/mapserver/mapserver/commit/2f0678d389562dc7054ffe36e6f08821cdbacf5e
  Changed paths:
    M mapwcs20.c
  Log Message:
  Merge pull request #5599 from constantinius/wcs-fix-inspire-schema-location
  Commit: 91d53be63cf0061466ced1d99171039ef869e168
      https://github.com/mapserver/mapserver/commit/91d53be63cf0061466ced1d99171039ef869e168
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2018-06-11 (Mon, 11 Jun 2018)
  Changed paths:
    M mapdraw.c
    A msautotest/renderers/expected/symbolrot.png
    A msautotest/renderers/symbolrot.map
  Log Message:
  Apply map rotation to symbols, similarly to the rule of labels (fixes #5271)
If the symbol angle is unspecified or 0, then the map rotation is ignored.
Otherwise, the map rotation is applied.
  Commit: 61e4981bd0db94c77b12277028c08a2edb51fe6b
      https://github.com/mapserver/mapserver/commit/61e4981bd0db94c77b12277028c08a2edb51fe6b
  Changed paths:
    M appveyor.yml
  Log Message:
  appveyor.yml: reflect change of name to freetype.lib in gisinternals SDK
See https://github.com/gisinternals/buildsystem/commit/252a46ed44bad761e4a7db6a24bde0fa6d84c1da
  Commit: a14095b2516b8db9d7dbe78b23df6c4d2fe84371
      https://github.com/mapserver/mapserver/commit/a14095b2516b8db9d7dbe78b23df6c4d2fe84371
  Author: Even Rouault <even.rouault at mines-paris.org>
  Changed paths:
    M mapdraw.c
  Log Message:
  Merge pull request #5606 from rouault/fix_5271_branch72
  Commit: 65d8606fb90e4d5672f7e196fbcb3dd5ace00a84
      https://github.com/mapserver/mapserver/commit/65d8606fb90e4d5672f7e196fbcb3dd5ace00a84
  Changed paths:
    M appveyor.yml
  Log Message:
  Merge pull request #5607 from rouault/fix_appveyor
  Commit: 3e502267ca0ef4c459b8a53c54f0a91e8ef39559
      https://github.com/mapserver/mapserver/commit/3e502267ca0ef4c459b8a53c54f0a91e8ef39559
  Date:   2018-06-13 (Wed, 13 Jun 2018)
  Changed paths:
    M CMakeLists.txt
    M HISTORY.TXT
  Log Message:
  update for 7.2-beta2 release
  Commit: af14610814835692a6ce9bc6a5149d8aaaa247af
      https://github.com/mapserver/mapserver/commit/af14610814835692a6ce9bc6a5149d8aaaa247af
  Author: Seth G <geographika at gmail.com>
  Date:   2018-06-15 (Fri, 15 Jun 2018)
  Changed paths:
    M mapstring.c
  Log Message:
  Use strcpy rather than strdup (#5610)
  Commit: 33a5a1209162b8d3e9addb975293a764703faeac
      https://github.com/mapserver/mapserver/commit/33a5a1209162b8d3e9addb975293a764703faeac
  Date:   2018-06-18 (Mon, 18 Jun 2018)
  Changed paths:
    M .travis.yml
    M Vagrantfile
    M msautotest/gdal/expected/gd_png_tr_256.png
    M msautotest/gdal/expected/gdal_png_tr_256.png
    M msautotest/gdal/expected/rawmode_multiband.png
    M msautotest/gdal/expected/rawmode_nodata.png
    M msautotest/misc/expected/geopdf-iso.pdf
    M msautotest/misc/expected/geopdf-ogc.pdf
    M msautotest/misc/expected/ogr_empty_geojson.json
    M msautotest/query/expected/rfc62_test001.txt
    M msautotest/query/expected/rfc62_test002.txt
    M msautotest/query/expected/rfc62_test003.txt
    M msautotest/renderers/expected/average_rgb.pdf
    M msautotest/renderers/expected/baseline_text.pdf
    M msautotest/renderers/expected/chartlayer_bar.pdf
    M msautotest/renderers/expected/chartlayer_pie.cairo.png
    M msautotest/renderers/expected/chartlayer_pie.pdf
    M msautotest/renderers/expected/chartlayer_pie2.cairo.png
    M msautotest/renderers/expected/chartlayer_pie2.pdf
    M msautotest/renderers/expected/chartlayer_pie_expressions.cairo.png
    M msautotest/renderers/expected/chartlayer_pie_expressions.pdf
    M msautotest/renderers/expected/chartlayer_vbar.pdf
    M msautotest/renderers/expected/circle_layer.pdf
    M msautotest/renderers/expected/compositing.pdf
    M msautotest/renderers/expected/compositing.svg
    M msautotest/renderers/expected/embed_legend.cairo.png
    M msautotest/renderers/expected/embed_legend_rgba.cairo.png
    M msautotest/renderers/expected/embed_legend_rgba_tr.cairo.png
    M msautotest/renderers/expected/embed_legend_tr.cairo.png
    M msautotest/renderers/expected/empty.pdf
    M msautotest/renderers/expected/entity_encoded_follow_text.cairo.png
    M msautotest/renderers/expected/entity_encoded_follow_text.pdf
    M msautotest/renderers/expected/geomtransform-vertex-layer.cairo.png
    M msautotest/renderers/expected/geomtransform-vertex-layer.pdf
    M msautotest/renderers/expected/geomtransform-vertex.cairo.png
    M msautotest/renderers/expected/geomtransform-vertex.pdf
    M msautotest/renderers/expected/grid.cairo.png
    M msautotest/renderers/expected/grid.pdf
    M msautotest/renderers/expected/label-multifont.cairo.png
    M msautotest/renderers/expected/label-multifont.pdf
    M msautotest/renderers/expected/label_noclip.cairo.png
    M msautotest/renderers/expected/label_noclip.pdf
    M msautotest/renderers/expected/labelcacheoff.cairo.png
    M msautotest/renderers/expected/labelcacheoff.pdf
    M msautotest/renderers/expected/labelpnt.cairo.png
    M msautotest/renderers/expected/labelpnt.pdf
    M msautotest/renderers/expected/labelrot.cairo.png
    M msautotest/renderers/expected/labelrot.pdf
    M msautotest/renderers/expected/labels-anno.pdf
    M msautotest/renderers/expected/labels-leader.cairo.png
    M msautotest/renderers/expected/labels-leader.pdf
    M msautotest/renderers/expected/labels-min-distance.cairo.png
    M msautotest/renderers/expected/labels-min-distance.pdf
    M msautotest/renderers/expected/labels.pdf
    M msautotest/renderers/expected/legend.cairo.png
    M msautotest/renderers/expected/legend.pdf
    M msautotest/renderers/expected/legend_label_offset.cairo.png
    M msautotest/renderers/expected/legend_label_offset.pdf
    M msautotest/renderers/expected/legend_sizeunits_meters.cairo.png
    M msautotest/renderers/expected/legend_sizeunits_meters.pdf
    M msautotest/renderers/expected/line_anchorpoint.cairo.png
    M msautotest/renderers/expected/line_label_auto.cairo.png
    M msautotest/renderers/expected/line_label_auto.pdf
    M msautotest/renderers/expected/line_label_auto2.cairo.png
    M msautotest/renderers/expected/line_label_auto2.pdf
    M msautotest/renderers/expected/line_label_follow.cairo.png
    M msautotest/renderers/expected/line_label_follow.pdf
    M msautotest/renderers/expected/line_label_follow_offsetted.cairo.png
    M msautotest/renderers/expected/line_label_follow_offsetted.pdf
    M msautotest/renderers/expected/line_label_follow_retry.cairo.png
    M msautotest/renderers/expected/line_label_follow_retry.pdf
    M msautotest/renderers/expected/line_marker_pixmap.cairo.png
    M msautotest/renderers/expected/line_marker_pixmap.pdf
    M msautotest/renderers/expected/line_marker_svg.cairo.png
    M msautotest/renderers/expected/line_marker_svg.pdf
    M msautotest/renderers/expected/line_marker_svg.png
    M msautotest/renderers/expected/line_marker_truetype.cairo.png
    M msautotest/renderers/expected/line_marker_truetype.pdf
    M msautotest/renderers/expected/line_marker_vector.cairo.png
    M msautotest/renderers/expected/line_marker_vector.pdf
    M msautotest/renderers/expected/line_offset.cairo.png
    M msautotest/renderers/expected/line_offset.pdf
    M msautotest/renderers/expected/line_pattern.cairo.png
    M msautotest/renderers/expected/line_pattern.pdf
    M msautotest/renderers/expected/line_pattern_offset.cairo.png
    M msautotest/renderers/expected/line_pattern_offset.pdf
    M msautotest/renderers/expected/line_short_gap.cairo.png
    M msautotest/renderers/expected/line_short_gap.pdf
    M msautotest/renderers/expected/line_simple.cairo.jpg
    M msautotest/renderers/expected/line_simple.cairo.png
    M msautotest/renderers/expected/line_simple.pdf
    M msautotest/renderers/expected/lots_of_text.cairo.png
    M msautotest/renderers/expected/marker_anchorpoint.cairo.png
    M msautotest/renderers/expected/marker_anchorpoint.pdf
    M msautotest/renderers/expected/marker_pixmap.pdf
    M msautotest/renderers/expected/mask.cairo.png
    M msautotest/renderers/expected/mask_opacity.cairo.png
    M msautotest/renderers/expected/multilabel-leader.cairo.png
    M msautotest/renderers/expected/multilabel-leader.pdf
    M msautotest/renderers/expected/multilabel.pdf
    M msautotest/renderers/expected/nodata_8bit.pdf
    M msautotest/renderers/expected/plb_embed_legend.cairo.png
    M msautotest/renderers/expected/plb_embed_legend_rgba.cairo.png
    M msautotest/renderers/expected/plb_embed_legend_rgba_tr.cairo.png
    M msautotest/renderers/expected/plb_embed_legend_tr.cairo.png
    M msautotest/renderers/expected/point-polaroffset.cairo.png
    M msautotest/renderers/expected/point-polaroffset.pdf
    M msautotest/renderers/expected/point_ellipse.pdf
    M msautotest/renderers/expected/point_pixmap.pdf
    M msautotest/renderers/expected/point_pixmap_gif.pdf
    M msautotest/renderers/expected/point_svg.cairo.png
    M msautotest/renderers/expected/point_svg.pdf
    M msautotest/renderers/expected/point_svg.png
    M msautotest/renderers/expected/point_truetype.cairo.png
    M msautotest/renderers/expected/point_truetype.pdf
    M msautotest/renderers/expected/point_vector.cairo.png
    M msautotest/renderers/expected/point_vector.pdf
    M msautotest/renderers/expected/poly-label-multiline-pos-auto.cairo.png
    M msautotest/renderers/expected/poly-label-multiline-pos-auto.pdf
    M msautotest/renderers/expected/poly-label-pos-auto.cairo.png
    M msautotest/renderers/expected/poly-label-pos-auto.pdf
    M msautotest/renderers/expected/poly_geomtransform_anchor.cairo.png
    M msautotest/renderers/expected/poly_geomtransform_anchor.pdf
    M msautotest/renderers/expected/polygon-as-line-offset.cairo.png
    M msautotest/renderers/expected/polygon-as-line-offset.pdf
    M msautotest/renderers/expected/polygon-as-line.cairo.png
    M msautotest/renderers/expected/polygon-as-line.pdf
    M msautotest/renderers/expected/polygon-as-line.svg
    M msautotest/renderers/expected/polygon-hatch-dashed.cairo.png
    M msautotest/renderers/expected/polygon-hatch-dashed.pdf
    M msautotest/renderers/expected/polygon-hatch.cairo.png
    M msautotest/renderers/expected/polygon-hatch.pdf
    M msautotest/renderers/expected/polygon-pixmap.cairo.png
    M msautotest/renderers/expected/polygon-pixmap.pdf
    M msautotest/renderers/expected/polygon-pixmap.svg
    M msautotest/renderers/expected/polygon-simple.pdf
    M msautotest/renderers/expected/polygon-ttf.pdf
    M msautotest/renderers/expected/polygon-ttf.svg
    M msautotest/renderers/expected/polygon-vector.cairo.png
    M msautotest/renderers/expected/polygon-vector.pdf
    M msautotest/renderers/expected/polygon-vector.svg
    M msautotest/renderers/expected/raster_simple.pdf
    M msautotest/renderers/expected/raster_simple_opacity.pdf
    M msautotest/renderers/expected/raster_simple_opacity.svg
    M msautotest/renderers/expected/reproj.pdf
    M msautotest/renderers/expected/rgb_overlay.pdf
    M msautotest/renderers/expected/rgb_overlay_res.pdf
    M msautotest/renderers/expected/rgb_overlay_res_to8bit.pdf
    M msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.pdf
    M msautotest/renderers/expected/rgba_overlay_res.pdf
    M msautotest/renderers/expected/text_shaping_1.pdf
    M msautotest/renderers/expected/transparent_layer.cairo.png
    M msautotest/renderers/expected/transparent_layer.pdf
    M msautotest/renderers/expected/transparent_layer.svg
    M msautotest/renderers/expected/uvraster.cairo.png
    M msautotest/renderers/expected/uvraster.pdf
    M msautotest/renderers/expected/uvraster_reproj.cairo.png
    M msautotest/renderers/expected/uvraster_reproj.pdf
    M msautotest/renderers/expected/wld_rotate.pdf
    M msautotest/renderers/expected/wld_upsidedown.pdf
    M msautotest/renderers/expected/wmsclient.pdf
    M msautotest/wxs/expected/wcs11_post_getcov_grd.dat
    M msautotest/wxs/expected/wcs11_post_getcov_grd_4326.dat
    M msautotest/wxs/expected/wcs11_post_getcov_grd_imagecrs.dat
    M msautotest/wxs/expected/wcs11_post_getcov_grd_wgs84.dat
    M msautotest/wxs/expected/wcs_10_getcov_bands_name_new.dat
    M msautotest/wxs/expected/wcs_16.grd
    M msautotest/wxs/expected/wcs_16_ds.grd
    M msautotest/wxs/expected/wcs_16_repro.grd
    M msautotest/wxs/expected/wcs_20_getcov_bands_index.tif
    M msautotest/wxs/expected/wcs_20_getcov_bands_index_new.tif
    M msautotest/wxs/expected/wcs_20_getcov_bands_interval.tif
    M msautotest/wxs/expected/wcs_20_getcov_bands_name.dat
    M msautotest/wxs/expected/wcs_20_getcov_bands_name.tif
    M msautotest/wxs/expected/wcs_20_getcov_bands_name_new.dat
    M msautotest/wxs/expected/wcs_20_getcov_bands_name_new.tif
    M msautotest/wxs/expected/wcs_20_getcov_bands_name_new_reproject.dat
    M msautotest/wxs/expected/wcs_20_getcov_gtiff_compress_jpeg.tif
    M msautotest/wxs/expected/wcs_20_post_bands_index.tif
    M msautotest/wxs/expected/wcs_20_post_bands_index_new.tif
    M msautotest/wxs/expected/wcs_20_post_bands_name.dat
    M msautotest/wxs/expected/wcs_20_post_bands_name.tif
    M msautotest/wxs/expected/wcs_20_post_bands_name_new.dat
    M msautotest/wxs/expected/wcs_20_post_bands_name_new.tif
    M msautotest/wxs/expected/wcs_getcov_grd_10.dat
    M msautotest/wxs/expected/wcs_getcov_grd_11.dat
    M msautotest/wxs/expected/wcs_getcov_grd_11_4326.dat
    M msautotest/wxs/expected/wcs_getcov_grd_11_imagecrs.dat
    M msautotest/wxs/expected/wcs_getcov_grd_11_wgs84.dat
    M msautotest/wxs/expected/wcs_mask_16.grd
    M msautotest/wxs/expected/wcs_mask_16_ds.grd
    M msautotest/wxs/expected/wcs_mask_16_repro.grd
    M msautotest/wxs/expected/wcs_mask_getcov_grd_10.dat
    M msautotest/wxs/expected/wcs_mask_getcov_grd_11.dat
    M msautotest/wxs/expected/wcs_mask_getcov_grd_11_4326.dat
    M msautotest/wxs/expected/wcs_mask_getcov_grd_11_imagecrs.dat
    M msautotest/wxs/expected/wcs_mask_getcov_grd_11_wgs84.dat
    M msautotest/wxs/expected/wfs_ogr_native_sql_36.xml
    M msautotest/wxs/expected/wfs_ogr_native_sql_37.xml
    M msautotest/wxs/expected/wfs_ogr_native_sql_40.xml
    M msautotest/wxs/expected/wfs_query_cache_2.xml
    M msautotest/wxs/expected/wfsogr10_geojson.json
    M msautotest/wxs/expected/wfsogr10_midmif.txt
    M msautotest/wxs/expected/wfsogr10_shapezip.zip
    M msautotest/wxs/expected/wfsogr10_twolayer.xml
    M msautotest/wxs/expected/wms_get_map_symbol_ext_svg_sld.png
    M msautotest/wxs/expected/wms_time_multi_ranges_reso_hour.png
    M msautotest/wxs/expected/wms_time_multi_ranges_reso_hour_postgis.png
    M msautotest/wxs/expected/wms_time_no_time_param.png
    M msautotest/wxs/expected/wms_time_no_time_param_postgis.png
    M msautotest/wxs/expected/wms_uvraster_lonwrap180_accross_hemisphere.png
    M msautotest/wxs/expected/wms_uvraster_lonwrap180_whole_world.png
    M msautotest/wxs/wfs_query_cache.map
    M scripts/vagrant/mapserver.sh
    M scripts/vagrant/packages.sh
    M scripts/vagrant/postgis.sh
  Log Message:
  .travis.yml: update to Trusty
  Commit: 3f7cb18e3b62213f0ea3db930c7bf138269856d4
      https://github.com/mapserver/mapserver/commit/3f7cb18e3b62213f0ea3db930c7bf138269856d4
  Date:   2018-06-19 (Tue, 19 Jun 2018)
  Changed paths:
    M .travis.yml
    M Vagrantfile
  Log Message:
  Merge pull request #5615 from rouault/update_travis_to_trusty
.travis.yml and Vagrant: update to Trusty
  Commit: 083fdb2b3288bd5112da71302d4f20ff5f81169d
      https://github.com/mapserver/mapserver/commit/083fdb2b3288bd5112da71302d4f20ff5f81169d
  Changed paths:
    M .travis.yml
    M HISTORY.TXT
    M Vagrantfile
    M appveyor.yml
    M mapdraw.c
    M mapmvt.c
    M mapstring.c
    M mapwcs20.c
  Log Message:
  Merge branch 'branch-7-2'
  Commit: 5b206a4b3841c1613e42624758fcece0d35a2980
      https://github.com/mapserver/mapserver/commit/5b206a4b3841c1613e42624758fcece0d35a2980
  Changed paths:
    M msautotest/wxs/wfs_ogr.map
  Log Message:
  msautotest/wxs/wfs_ogr.map: avoid time-dependant result for wfsogr10_shapezip.zip
  Commit: ffa889e731c891f543e5a86b098a5dee75df3c91
      https://github.com/mapserver/mapserver/commit/ffa889e731c891f543e5a86b098a5dee75df3c91
  Changed paths:
  Log Message:
Compare: https://github.com/mapserver/mapserver/compare/04d759a35516...ffa889e731c8
      **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
