[mapserver-commits] [mapserver/mapserver] c4f37d: Update API for testGetShape test and change assert...
GitHub noreply at github.com
Sat Oct 13 14:39:11 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: c4f37d2f48c63e560f4021e1697e8b260bf535db
      https://github.com/mapserver/mapserver/commit/c4f37d2f48c63e560f4021e1697e8b260bf535db
  Author: geographika <sethg at geographika.co.uk>
  Date:   2018-10-08 (Mon, 08 Oct 2018)
  Changed paths:
    M mapscript/python/tests/cases/shape_test.py
  Log Message:
  Update API for testGetShape test and change assert_ to assertTrue
  Commit: 45e5c9a57add30827e495d8ade1ff7f089f18e4d
      https://github.com/mapserver/mapserver/commit/45e5c9a57add30827e495d8ade1ff7f089f18e4d
  Changed paths:
    M mapscript/python/setup.py.in
  Log Message:
  Add version revision number to package version
  Commit: 3ca427c5a89dc6dbe79c9ec068c69cff7ebe0b09
      https://github.com/mapserver/mapserver/commit/3ca427c5a89dc6dbe79c9ec068c69cff7ebe0b09
  Changed paths:
    M mapscript/python/pyextend.i
  Log Message:
  Move hashTableObj extension to pyextend, fix image writing for py3, and fix regex deprecation warnings
  Commit: 693ac0f092650e8db6323db2eed8b3821e82d7de
      https://github.com/mapserver/mapserver/commit/693ac0f092650e8db6323db2eed8b3821e82d7de
  Changed paths:
    M mapscript/python/pymodule.i
  Log Message:
  hashTableObj extensions moved to pyextend
  Commit: ce97bc8607cab6f2d2fbf9ca005f839ad8d81d89
      https://github.com/mapserver/mapserver/commit/ce97bc8607cab6f2d2fbf9ca005f839ad8d81d89
  Date:   2018-10-10 (Wed, 10 Oct 2018)
  Changed paths:
    M mapscript/python/tests/cases/style_test.py
  Log Message:
  Use new query API for style test
  Commit: f3edb872a7aa5de943b24c0b1cdff87dc98146f8
      https://github.com/mapserver/mapserver/commit/f3edb872a7aa5de943b24c0b1cdff87dc98146f8
  Changed paths:
    M mapscript/python/tests/cases/symbol_test.py
    M mapscript/swiginc/symbol.i
  Log Message:
  Fix broken symbol tests, remove GD as default renderer
  Commit: 275b91f6cdfa2e0646f4f95ee9aef2e657011542
      https://github.com/mapserver/mapserver/commit/275b91f6cdfa2e0646f4f95ee9aef2e657011542
  Changed paths:
    M mapscript/python/tests/cases/image_test.py
    M mapscript/swiginc/image.i
  Log Message:
  Remove broken custom Python imageObj constructor code
  Commit: a64ef130379b8a2aa4d724182082d6d9f88c754a
      https://github.com/mapserver/mapserver/commit/a64ef130379b8a2aa4d724182082d6d9f88c754a
  Changed paths:
  Log Message:
  Linting fix
  Commit: d7990027a1ac3ab7de7bf3aa291f6569f994eaff
      https://github.com/mapserver/mapserver/commit/d7990027a1ac3ab7de7bf3aa291f6569f994eaff
  Date:   2018-10-11 (Thu, 11 Oct 2018)
  Changed paths:
    M mapscript/python/tests/cases/zoom_test.py
  Log Message:
  Update zoom tests to reflect new rect extents
  Commit: 52bd312942f216cab9efdebddb67872014a9bd76
      https://github.com/mapserver/mapserver/commit/52bd312942f216cab9efdebddb67872014a9bd76
  Changed paths:
    M mapscript/python/tests/cases/line_test.py
  Log Message:
  Update assertRaises syntax to fix test
  Commit: b63599704e5f018cf80297353b0e1d199cd65a63
      https://github.com/mapserver/mapserver/commit/b63599704e5f018cf80297353b0e1d199cd65a63
  Changed paths:
    M mapscript/python/tests/cases/resultcache_test.py
  Log Message:
  Update query API to fix tests
  Commit: 53e5d1c3a1f51b3a910a841960bbc0742871a91c
      https://github.com/mapserver/mapserver/commit/53e5d1c3a1f51b3a910a841960bbc0742871a91c
  Changed paths:
  Log Message:
  Lint fixes
  Commit: e7fc3cab3f05cece84f2424b16c7b66edb1e966a
      https://github.com/mapserver/mapserver/commit/e7fc3cab3f05cece84f2424b16c7b66edb1e966a
  Changed paths:
    M mapscript/swiginc/layer.i
  Log Message:
  Replace tabs with spaces causing compiler warnings
  Commit: 9622306c9d9a149dbbd6a0786a194fc6a5a5e097
      https://github.com/mapserver/mapserver/commit/9622306c9d9a149dbbd6a0786a194fc6a5a5e097
  Changed paths:
  Log Message:
  Add a py2/py3 check and use the appropriate argument for writing to binary files
  Commit: 2f380a7fcbe4df55e0e73ec00dd3d4cef9d2b5fe
      https://github.com/mapserver/mapserver/commit/2f380a7fcbe4df55e0e73ec00dd3d4cef9d2b5fe
  Changed paths:
    A mapscript/python/tests/cases/color_test.py
    A mapscript/python/tests/cases/parentreference_test.py
    A mapscript/python/tests/cases/refcount_test.py
    A mapscript/python/tests/cases/thread_test.py
  Log Message:
  Re-add outstanding tests with linting
  Commit: bec21e6dfaf7e6237c3a256d8db1e5340fa3b336
      https://github.com/mapserver/mapserver/commit/bec21e6dfaf7e6237c3a256d8db1e5340fa3b336
  Changed paths:
    M mapscript/python/tests/cases/thread_test.py
  Log Message:
  Turn off print statements
  Commit: 8dec121dd4cabe2472f8f3d3c8d6658210bb86d1
      https://github.com/mapserver/mapserver/commit/8dec121dd4cabe2472f8f3d3c8d6658210bb86d1
  Changed paths:
    M appveyor.yml
  Log Message:
  Run tests on Python3
  Commit: b400e284075eaa93b6d6e18f490e4547afb6b55d
      https://github.com/mapserver/mapserver/commit/b400e284075eaa93b6d6e18f490e4547afb6b55d
  Changed paths:
  Log Message:
  Change assertRaises logic as it fails on Appveyor
  Commit: f22129b8e4dea01aff238b037907b1ba0add0c9f
      https://github.com/mapserver/mapserver/commit/f22129b8e4dea01aff238b037907b1ba0add0c9f
  Changed paths:
    M appveyor.yml
  Log Message:
  Add fast fail for Appveyor
  Commit: 7f963ea520203b8c22d9b7a2bb04c8fad1563fb2
      https://github.com/mapserver/mapserver/commit/7f963ea520203b8c22d9b7a2bb04c8fad1563fb2
  Changed paths:
  Log Message:
  Disable numpoints test
  Commit: 47f7f189dd242d15c744aa227804a3ff0fa83325
      https://github.com/mapserver/mapserver/commit/47f7f189dd242d15c744aa227804a3ff0fa83325
  Changed paths:
    M appveyor.yml
  Log Message:
  Fix YAML
  Commit: 72e4423c3331933b5e88d885c00e10ccb559fa36
      https://github.com/mapserver/mapserver/commit/72e4423c3331933b5e88d885c00e10ccb559fa36
  Date:   2018-10-12 (Fri, 12 Oct 2018)
  Changed paths:
    M mapscript/python/README.rst
  Log Message:
  README.rst updates
  Commit: 6a38e27018481615074786cc273b2e0e3a06cc1b
      https://github.com/mapserver/mapserver/commit/6a38e27018481615074786cc273b2e0e3a06cc1b
  Changed paths:
  Log Message:
  Fix RST errors and add PROJ_LIB note
  Commit: 913d68e3804a4bea2b5f049ab1b5413f8a9b5dc5
      https://github.com/mapserver/mapserver/commit/913d68e3804a4bea2b5f049ab1b5413f8a9b5dc5
  Author: Seth G <geographika at gmail.com>
  Date:   2018-10-13 (Sat, 13 Oct 2018)
  Changed paths:
    M appveyor.yml
  Log Message:
  Merge pull request #5677 from geographika/py3-fixes
Update Python MapScript test suite for Python3
Compare: https://github.com/mapserver/mapserver/compare/20cb17459d1d...913d68e3804a
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
