[mapserver-commits] [mapserver/mapserver] 3b7960: Identified difference between WMS and mode=tile so...
Even Rouault noreply at github.com
Wed Jan 30 07:33:49 PST 2019
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: 3b79601baa480ebe80418397bfe3f57dde19878a
      https://github.com/mapserver/mapserver/commit/3b79601baa480ebe80418397bfe3f57dde19878a
  Author: Steve Lime <steve.lime at state.mn.us>
  Date:   2019-01-14 (Mon, 14 Jan 2019)
  Changed paths:
    M mapmvt.c
  Log Message:
  Identified difference between WMS and mode=tile sourced MVT output. WMS doesn't set a cellsize so the half-pixel offset computation is off by a pixel (#5596).
  Commit: e5b059f41861e5cab5114da7c8bd12174c4cb75e
      https://github.com/mapserver/mapserver/commit/e5b059f41861e5cab5114da7c8bd12174c4cb75e
  Changed paths:
    M msautotest/wxs/expected/wms_mvt.mvt
  Log Message:
  Updated test...
  Commit: 09632a696085f8de784cf748f7762d86ab7f7453
      https://github.com/mapserver/mapserver/commit/09632a696085f8de784cf748f7762d86ab7f7453
  Changed paths:
    M mapmvt.c
  Log Message:
  Merge pull request #5729 from sdlime/issue-5596
Identified difference between WMS and mode=tile sourced MVT output. W…
  Commit: 11e0565243f8a8ecccd32d00a9a2c2dcb88dc47a
      https://github.com/mapserver/mapserver/commit/11e0565243f8a8ecccd32d00a9a2c2dcb88dc47a
  Date:   2019-01-21 (Mon, 21 Jan 2019)
  Changed paths:
    M mapmvt.c
  Log Message:
  Filter out triangular rings with height (opposite longest base) less than 1 (#5731).
  Commit: fa25cbcf4629734a7dc05faa70fa168844bd48da
      https://github.com/mapserver/mapserver/commit/fa25cbcf4629734a7dc05faa70fa168844bd48da
  Changed paths:
    M mapmvt.c
  Log Message:
  Merge pull request #5736 from sdlime/issue-5371
Filter out triangular rings with height (opposite longest base) less …
  Commit: 1cec5bf0a73fe11ea42205deaf54df0aa4b1ad9c
      https://github.com/mapserver/mapserver/commit/1cec5bf0a73fe11ea42205deaf54df0aa4b1ad9c
  Date:   2019-01-23 (Wed, 23 Jan 2019)
  Changed paths:
    M mapmvt.c
  Log Message:
  Make sure computed triangle height is always positive. (#5731)
  Commit: 281decd69599688025ec204dd9d869f7b39cd178
      https://github.com/mapserver/mapserver/commit/281decd69599688025ec204dd9d869f7b39cd178
  Changed paths:
    M mapmvt.c
  Log Message:
  Merge pull request #5737 from sdlime/issue-5731-2
  Commit: 4853fd623d1afc765712821c55d5e1aa54ff485b
      https://github.com/mapserver/mapserver/commit/4853fd623d1afc765712821c55d5e1aa54ff485b
  Changed paths:
    M mapfile.c
  Log Message:
  Updated writeDimension() to take doubles instead of ints (#5310) as input. Output pattern follows writeNumber().
  Commit: d4875f9be5e18c3c25055f9898d0caef590bf112
      https://github.com/mapserver/mapserver/commit/d4875f9be5e18c3c25055f9898d0caef590bf112
  Changed paths:
    M mapfile.c
  Log Message:
  Merge pull request #5738 from sdlime/issue-5310
Updated writeDimension() to take doubles instead of ints (#5310) as i…
  Commit: 90583b02b377e69ae8a493c677d027d4fb61baed
      https://github.com/mapserver/mapserver/commit/90583b02b377e69ae8a493c677d027d4fb61baed
  Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
  Date:   2019-01-24 (Thu, 24 Jan 2019)
  Changed paths:
    M README.rst
  Log Message:
  update copyright year
  Commit: 9e654b36c296d14e45f854d8ecea684c8b75e441
      https://github.com/mapserver/mapserver/commit/9e654b36c296d14e45f854d8ecea684c8b75e441
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2019-01-30 (Wed, 30 Jan 2019)
  Changed paths:
    M mapogcfiltercommon.c
    M msautotest/wxs/data/test_islike_escaping.csv
    M msautotest/wxs/data/test_islike_escaping.dbf
    M msautotest/wxs/expected/wfs_filter_islike_escaping.xml
    M msautotest/wxs/wfs_filter.map
  Log Message:
  SLD / Filter encoding: fix again escaping of REGEX special characters (fixes #5658)
  Commit: b5476b4fed3fb7078f65bffac1120dd90c3a0a27
      https://github.com/mapserver/mapserver/commit/b5476b4fed3fb7078f65bffac1120dd90c3a0a27
  Author: Even Rouault <even.rouault at mines-paris.org>
  Changed paths:
  Log Message:
  Merge pull request #5739 from rouault/fix_5658_again
  Commit: 2b4d47bf366c9d3eddc0dbe971e419dd6e284697
      https://github.com/mapserver/mapserver/commit/2b4d47bf366c9d3eddc0dbe971e419dd6e284697
  Changed paths:
    M README.rst
    M mapfile.c
    M mapmvt.c
  Log Message:
  Merge remote-tracking branch 'origin/branch-7-2'
Compare: https://github.com/mapserver/mapserver/compare/418e15cda510...2b4d47bf366c
