[mapserver-commits] [mapserver/mapserver] a84b67: Add sampling along diagonal for rectangle as polyg...
Steve Lime noreply at github.com
Thu May 16 14:30:22 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: a84b6763ef7c343e3e9fe17e2b8059bd55f614a0
      https://github.com/mapserver/mapserver/commit/a84b6763ef7c343e3e9fe17e2b8059bd55f614a0
  Author: Erik Ravhed <er at t-kartor.se>
  Date:   2019-04-10 (Wed, 10 Apr 2019)
  Changed paths:
    M mapproject.c
  Log Message:
  Add sampling along diagonal for rectangle as polygon reprojection
  Commit: b8139f21efbf6be27532438c026818e69b23af1c
      https://github.com/mapserver/mapserver/commit/b8139f21efbf6be27532438c026818e69b23af1c
  Date:   2019-04-12 (Fri, 12 Apr 2019)
  Changed paths:
    M mapogcfilter.c
    M mapogcfiltercommon.c
  Log Message:
  Feature names with dots are now supported for feature id filtering (fixes #5741)
  Commit: e7a42a6fb509a3bec8effce58559cfc27c126a02
      https://github.com/mapserver/mapserver/commit/e7a42a6fb509a3bec8effce58559cfc27c126a02
  Author: andy <jacodeguy at gmail.com>
  Date:   2019-04-14 (Sun, 14 Apr 2019)
  Changed paths:
    M .travis.yml
    M Makefile
    M mapscript/perl/CMakeLists.txt
    A mapscript/perl/tests/0-load.t
  Log Message:
  add perl to travis, run some tests
  Commit: a10dce2ffbc00d1f7446c0369fdc9291044d55c1
      https://github.com/mapserver/mapserver/commit/a10dce2ffbc00d1f7446c0369fdc9291044d55c1
  Changed paths:
    M Makefile
  Log Message:
  need a dash
  Commit: 380f5a20d9a1f9b835d607d24a89ab92806cfe77
      https://github.com/mapserver/mapserver/commit/380f5a20d9a1f9b835d607d24a89ab92806cfe77
  Author: sethg <sethg at geographika.co.uk>
  Changed paths:
    M .travis.yml
  Log Message:
  Update SWIG to 3.0.12
  Commit: 774bc1de457bdb654940910f3b4b7c19c7cc61ca
      https://github.com/mapserver/mapserver/commit/774bc1de457bdb654940910f3b4b7c19c7cc61ca
  Changed paths:
    M Makefile
  Log Message:
  set PERL5LIB, fix paths
  Commit: 37815bbf36fee339716f70247fbfbc68b86dfa5c
      https://github.com/mapserver/mapserver/commit/37815bbf36fee339716f70247fbfbc68b86dfa5c
  Changed paths:
    M mapscript/perl/examples/RFC24.pl
    M mapscript/perl/examples/shp_in_shp.pl
    M mapscript/perl/examples/thin.pl
  Log Message:
  fix perl examples
  Commit: b4b680d45b931be71a9b7e25c8be0604bb966344
      https://github.com/mapserver/mapserver/commit/b4b680d45b931be71a9b7e25c8be0604bb966344
  Author: Steve Lime <steve.lime at state.mn.us>
  Date:   2019-04-15 (Mon, 15 Apr 2019)
  Changed paths:
    M mapscript/php/php_proj.c
  Log Message:
  Another small workaround to all PHP/MapScript to compile against Proj 1.6.0.
  Commit: 8413c7902dc8633b5d14503cb1c1b061c7b1f412
      https://github.com/mapserver/mapserver/commit/8413c7902dc8633b5d14503cb1c1b061c7b1f412
  Author: Even Rouault <even.rouault at mines-paris.org>
  Changed paths:
    M mapogcfilter.c
  Log Message:
  Merge pull request #5786 from ravhed/filter-id-dot
  Commit: 1d0d0e069f98cbe4fcf15bc7219c6c9eb4442485
      https://github.com/mapserver/mapserver/commit/1d0d0e069f98cbe4fcf15bc7219c6c9eb4442485
  Author: Even Rouault <even.rouault at spatialys.com>
  Changed paths:
    R mapscript/php/php_proj.c
  Log Message:
  PHP bindings: remove unused php_proj.c which uses removed projects.h PROJ API
  Commit: 36dde3104ab9416eb64c93d9cc1d0dcc663fa001
      https://github.com/mapserver/mapserver/commit/36dde3104ab9416eb64c93d9cc1d0dcc663fa001
  Changed paths:
  Log Message:
  Merge pull request #5792 from rouault/remove_php_proj_c
Remove php_proj.c
  Commit: 3ef811adda60a54bbdc87d442ed61af9fa065e3a
      https://github.com/mapserver/mapserver/commit/3ef811adda60a54bbdc87d442ed61af9fa065e3a
  Changed paths:
    M mapproject.c
  Log Message:
  Removed redundant code
  Commit: bfcce38bc1dc1d505aa30170340cda33814eaa36
      https://github.com/mapserver/mapserver/commit/bfcce38bc1dc1d505aa30170340cda33814eaa36
  Date:   2019-04-16 (Tue, 16 Apr 2019)
  Changed paths:
    M mapscript/perl/tests/0-load.t
    A mapscript/perl/tests/maps.t
    M mapscript/swiginc/image.i
    M mapscript/swiginc/msio.i
  Log Message:
  image error checking, enable msIO_getAndStripStdoutBufferMimeHeaders, new tests
  Commit: 32ec2fadbf92694980846aaee1c5093dd03332ad
      https://github.com/mapserver/mapserver/commit/32ec2fadbf92694980846aaee1c5093dd03332ad
  Changed paths:
    M mapproject.c
  Log Message:
  Merge pull request #5785 from ravhed/reproj-diagonal-sample
  Commit: 423d4349650b764e7042f56a63803fa2f53197b3
      https://github.com/mapserver/mapserver/commit/423d4349650b764e7042f56a63803fa2f53197b3
  Author: Seth G <geographika at gmail.com>
  Changed paths:
    M .travis.yml
    M Makefile
  Log Message:
  Merge pull request #5778 from AndyColson/testperl
add perl to travis
  Commit: 8b431a881e89b632c291e8db1dc7a1435bdc8688
      https://github.com/mapserver/mapserver/commit/8b431a881e89b632c291e8db1dc7a1435bdc8688
  Date:   2019-04-17 (Wed, 17 Apr 2019)
  Changed paths:
    M maptemplate.c
  Log Message:
  Fix potential XSS issue with [layers] tag.
  Commit: f5d161bd27ecc8dcc44144d25fdcdfabbdf7180c
      https://github.com/mapserver/mapserver/commit/f5d161bd27ecc8dcc44144d25fdcdfabbdf7180c
  Changed paths:
    M CMakeLists.txt
    M HISTORY.TXT
  Log Message:
  update for 7.4.0-beta2 release
  Commit: 74e373a59e38178c639713fe945f0399263e2c45
      https://github.com/mapserver/mapserver/commit/74e373a59e38178c639713fe945f0399263e2c45
  Date:   2019-04-18 (Thu, 18 Apr 2019)
  Changed paths:
    M mapgml.c
    A msautotest/wxs/expected/wms_getfeatureinfo_encoding.xml
    A msautotest/wxs/wms_getfeatureinfo_encoding.map
  Log Message:
  GML:Name is now encoded in WMS GetFeatureInfo (fixes #5361)
  Commit: ce4e341c62e4f7cec1aed38bd8a821b51e2b139c
      https://github.com/mapserver/mapserver/commit/ce4e341c62e4f7cec1aed38bd8a821b51e2b139c
  Changed paths:
    M mapgml.c
  Log Message:
  Merge pull request #5793 from ravhed/wms-getfeatureinfo-encoding
  Commit: f627a7c946940e6b5a67ce0f661f1ba55b557d39
      https://github.com/mapserver/mapserver/commit/f627a7c946940e6b5a67ce0f661f1ba55b557d39
  Date:   2019-04-26 (Fri, 26 Apr 2019)
  Changed paths:
    M mapscript/phpng/CMakeLists.txt
  Log Message:
  Clean-up PHPNG MapScript build process
  Commit: 4f3ef6bdf4a40b701c166ec81e4020bb237c4564
      https://github.com/mapserver/mapserver/commit/4f3ef6bdf4a40b701c166ec81e4020bb237c4564
  Author: Seth G <sethg at geographika.co.uk>
  Date:   2019-04-29 (Mon, 29 Apr 2019)
  Changed paths:
  Log Message:
  Merge pull request #5797 from geographika/php-mapscriptng
Updates to PHP SWIG MapScript CMakeLists
  Commit: 17c77c72799dd05100e1dc5c3db73e186eec327f
      https://github.com/mapserver/mapserver/commit/17c77c72799dd05100e1dc5c3db73e186eec327f
  Date:   2019-05-01 (Wed, 01 May 2019)
  Changed paths:
    M CMakeLists.txt
    M HISTORY.TXT
  Log Message:
  update for 7.4.0-rc1 release
  Commit: bed25141ea915fe3c03cea57e9ace9c7c6688cf2
      https://github.com/mapserver/mapserver/commit/bed25141ea915fe3c03cea57e9ace9c7c6688cf2
  Author: Dan Baston <dbaston at isciences.com>
  Changed paths:
    M mapogcsld.c
  Log Message:
  Fix reference to TEMPPATH in SLD error message
  Commit: 04d0a73ba4ed7ae3a3bc274805ee68e6adfc350b
      https://github.com/mapserver/mapserver/commit/04d0a73ba4ed7ae3a3bc274805ee68e6adfc350b
  Date:   2019-05-06 (Mon, 06 May 2019)
  Changed paths:
    M msautotest/wxs/expected/wms_get_map_ext_sld_404.xml
    M msautotest/wxs/expected/wms_get_map_ext_sld_fileproto.xml
    M msautotest/wxs/expected/wms_get_map_ext_sld_proto.xml
    M msautotest/wxs/expected/wms_get_map_ext_sld_too_large.xml
  Log Message:
  Updates expected output from several tests
  Commit: ff5550eefc183c0d269e8d5bacbdb8a11da68852
      https://github.com/mapserver/mapserver/commit/ff5550eefc183c0d269e8d5bacbdb8a11da68852
  Date:   2019-05-10 (Fri, 10 May 2019)
  Changed paths:
  Log Message:
  Merge pull request #5800 from ravhed/build-fix
Fix build issue introduced by #5799
  Commit: 174d334d73137cbe1f5b85bfed3f58806699274f
      https://github.com/mapserver/mapserver/commit/174d334d73137cbe1f5b85bfed3f58806699274f
  Changed paths:
    M CMakeLists.txt
    M HISTORY.TXT
  Log Message:
  update for 7.4.0-rc2 release
  Commit: b5c26cc372dd95f80f01b741cf9f2ebbdb221733
      https://github.com/mapserver/mapserver/commit/b5c26cc372dd95f80f01b741cf9f2ebbdb221733
  Date:   2019-05-14 (Tue, 14 May 2019)
  Changed paths:
    M CMakeLists.txt
    M HISTORY.TXT
  Log Message:
  update for 7.4.0 release
  Commit: 391bd6cbd105f49f0b42fe78786827432b10970d
      https://github.com/mapserver/mapserver/commit/391bd6cbd105f49f0b42fe78786827432b10970d
  Author: greenwoodmap <richard.greenwood at gmail.com>
  Changed paths:
  Log Message:
  add SWIG test to PHPNG cmake
  Commit: ad4c8b8de5cdfc955dc2de9a59b6376516d2963f
      https://github.com/mapserver/mapserver/commit/ad4c8b8de5cdfc955dc2de9a59b6376516d2963f
  Date:   2019-05-15 (Wed, 15 May 2019)
  Changed paths:
  Log Message:
  Merge pull request #5802 from greenwoodmap/issue-5801
  Commit: 5e91b9e61835a1d341036241c61e7a20e7f9af4f
      https://github.com/mapserver/mapserver/commit/5e91b9e61835a1d341036241c61e7a20e7f9af4f
  Date:   2019-05-16 (Thu, 16 May 2019)
  Changed paths:
    M .travis.yml
    M scripts/vagrant/packages.sh
  Log Message:
  Fixing Vagrant and Travis-CI builds.
  Commit: 835ffd4c8acc5e3cc3ef72ad9de0779f8ee80f2e
      https://github.com/mapserver/mapserver/commit/835ffd4c8acc5e3cc3ef72ad9de0779f8ee80f2e
  Changed paths:
    M .travis.yml
  Log Message:
  Merge pull request #5805 from sdlime/branch-7-4
  Commit: 85e294e8c8ce3c9c455fea0137d4af1ee2feced0
      https://github.com/mapserver/mapserver/commit/85e294e8c8ce3c9c455fea0137d4af1ee2feced0
  Changed paths:
    M .travis.yml
    M HISTORY.TXT
    M Makefile
    M mapgml.c
    M mapogcfilter.c
    M mapproject.c
  Log Message:
  Merge recent 'branch-7-4' commits...
Compare: https://github.com/mapserver/mapserver/compare/359fb45316db...85e294e8c8ce
