[mapserver-commits] [MapServer/MapServer] 3f6714: [PostGIS]: only trim trailing blanks from CHAR(n) ...
Even Rouault noreply at github.com
Wed Jun 9 11:59:25 PDT 2021
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: 3f67146f76ffcdf4be73733bbe49ff7e8b654881
      https://github.com/MapServer/MapServer/commit/3f67146f76ffcdf4be73733bbe49ff7e8b654881
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2021-06-09 (Wed, 09 Jun 2021)
  Changed paths:
    M mappostgis.cpp
    M msautotest/create_postgis_test_data.sh
    M msautotest/mspython/test_postgis.py
  Log Message:
  [PostGIS]: only trim trailing blanks from CHAR(n) fields (fixes #6292)
  Commit: ea5d1b4fb06b74cce685d0e92e6d59220d6ef2e3
      https://github.com/MapServer/MapServer/commit/ea5d1b4fb06b74cce685d0e92e6d59220d6ef2e3
  Changed paths:
    M mappostgis.cpp
  Log Message:
  Merge pull request #6349 from rouault/fix_6292
Compare: https://github.com/MapServer/MapServer/compare/2d73b379284a...ea5d1b4fb06b
