[mapserver-commits] [MapServer/MapServer] b25d3b: Coverity Scan fixes (#6555)
Even Rouault noreply at github.com
Mon Jul 4 05:06:10 PDT 2022
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: b25d3bb4eeda9da5eddb9da2326e57ca64c2935c
      https://github.com/MapServer/MapServer/commit/b25d3bb4eeda9da5eddb9da2326e57ca64c2935c
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2022-07-04 (Mon, 04 Jul 2022)
  Changed paths:
    M mapcontext.c
    M mapgdal.cpp
    M maplabel.c
    M mapmetadata.c
    M mapogcfilter.cpp
    M mapogcsld.c
    M mapogcsos.c
    M mappostgis.cpp
    M maptemplate.c
    M maptree.c
    M maputil.c
    M mapwcs.cpp
    M mapwcs11.cpp
    M mapwcs20.cpp
    M mapwfs11.cpp
    M mapwms.cpp
  Log Message:
* mapwcs: fix false positive Coverity warnings about memory leaks (CID 1518800)
* mapmetadata: fix false positive Coverity warning about memory leaks (CID 1518799)
* mapogcsos: fix memory leak in error code path (CID 1518798)
* mapwcs20: fix false positive Coverity warning about memory leaks (CID 1518797)
* mapwms: fix memory leak (CID 1518794)
* mapwcs11: fix false positive Coverity warning about memory leaks (CID 1518791)
* mapwcs: fix memory leak (CID 1518789)
* mapcontext: fix memory leak (CID 1518788)
* mapmetadata: fix false positive Covery warning about memory leak (CID 1518787)
* mapogcsos: fix memory leaks in error code path (CID 1518785, 1518784)
* maputil: fix false positive Coverity warning about nullptr deref (CID 1503569)
* mapsos: avoid Coverity warning about nullptr deref (CID 1518790, 1518796)
* mappostgis: fix memory leak (CID 1503579)
* mapgdal: fix memory leaks in error code paths (CID 1503576)
* mapogcfilter: fix false positive Coverity warning about memory leaks (CID 1503572)
* mapwfs11: fix false positive Coverity warning about memory leaks (CID 1503571)
* maptree: fix memory leaks in error code paths (CID 1503570)
* mapogcsld: fix false positive Coverity warning about memory leaks (CID 1503568)
* maplabel: fix memory leaks (CID 1194599)
* maptemplate: fix memory leaks (CID 1175194)
More information about the MapServer-commits mailing list
