[mapserver-commits] [MapServer/MapServer] e25f5f: Appveyor SDK Update and Fixes (#6827)
Seth G noreply at github.com
Wed Feb 8 00:23:19 PST 2023
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: e25f5f5a92fe98358467bad28506a190f343a50f
      https://github.com/MapServer/MapServer/commit/e25f5f5a92fe98358467bad28506a190f343a50f
  Author: Seth G <sethg at geographika.co.uk>
  Date:   2023-02-08 (Wed, 08 Feb 2023)
  Changed paths:
    M .github/workflows/check-crlf.yml
    M appveyor.yml
    M msautotest/mssql/cluster_mssql.map
    M msautotest/mssql/create_mssql_db.bat
  Log Message:
* Add GDAL_DRIVER_PATH to ensure MSSQL GDAL plugin is available and use new connection string params
* Skip failing tests
* Add back GetMetadata test
* Set proj9.lib
* No need to set GDAL_DRIVER_PATH
* Update linefeed action to use latest ubuntu
More information about the MapServer-commits mailing list
