[mapserver-commits] [MapServer/MapServer] cd291c: msCGILoadMap(): do not load file pointed by CONTEX...
Even Rouault noreply at github.com
Tue Jan 3 06:55:50 PST 2023
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: cd291c79b11c2945d1cff6f16710256a0dc2bd9c
      https://github.com/MapServer/MapServer/commit/cd291c79b11c2945d1cff6f16710256a0dc2bd9c
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2022-12-30 (Fri, 30 Dec 2022)
  Changed paths:
    M mapcontext.c
    M mapows.h
    M mapservutil.c
  Log Message:
  msCGILoadMap(): do not load file pointed by CONTEXT= unless it validates new MS_CONTEXT_PATTERN configuration option (and doesn't validate MS_CONTEXT_BAD_PATTERN) (fixes #6779)
  Commit: 287347cd1bd803a2c4cbf59ecdb253b5f7bba759
      https://github.com/MapServer/MapServer/commit/287347cd1bd803a2c4cbf59ecdb253b5f7bba759
  Changed paths:
    M msautotest/etc/mapserv.conf
    A msautotest/wxs/expected/ows_context_caps.xml
    A msautotest/wxs/ows_context.map
    A msautotest/wxs/ows_context.xml
  Log Message:
  msautotest: add a test for CONTEXT= loading (refs #6779)
  Commit: a4325bbf8f5676689395053acc764e43442fa9ab
      https://github.com/MapServer/MapServer/commit/a4325bbf8f5676689395053acc764e43442fa9ab
  Changed paths:
    M mapcontext.c
  Log Message:
  msGetMapContextFileText(): add sanity check on file size (refs #6779)
  Commit: 4d4ec60b4fb22874fadce7cae712ca841b6b2f53
      https://github.com/MapServer/MapServer/commit/4d4ec60b4fb22874fadce7cae712ca841b6b2f53
  Changed paths:
    M .github/workflows/start.sh
  Log Message:
  CI: check that we can't load a OWS context file if MS_CONTEXT_PATTERN is not defined (refs #6779)
  Commit: 91d073f35c0a287ed0797aa1570ab2d3ecfc6156
      https://github.com/MapServer/MapServer/commit/91d073f35c0a287ed0797aa1570ab2d3ecfc6156
  Changed paths:
    M mapcontext.c
  Log Message:
  msLoadMapContextGeneral(): fix memory leaks
  Commit: ec06a2effd61309bf49fa25a96a9ce142fcb992a
      https://github.com/MapServer/MapServer/commit/ec06a2effd61309bf49fa25a96a9ce142fcb992a
  Changed paths:
    M mapcontext.c
    M mapserver.h
  Log Message:
  msLoadMapContext(): add validation of filename against MS_CONTEXTFILE_PATTERN, which defaults to .xml extension
  Commit: 27d02c5b6c80b9671b59ba8b988b08a6708ec1c6
      https://github.com/MapServer/MapServer/commit/27d02c5b6c80b9671b59ba8b988b08a6708ec1c6
  Date:   2023-01-03 (Tue, 03 Jan 2023)
  Changed paths:
    M mapcontext.c
    M mapows.h
    M mapserver.h
    M mapservutil.c
  Log Message:
  Merge pull request #6780 from rouault/fix_6779
Fix information disclosure and denial of service related to CONTEXT= loading
Compare: https://github.com/MapServer/MapServer/compare/02eb9727f644...27d02c5b6c80
More information about the MapServer-commits mailing list
