[mapserver-commits] [MapServer/MapServer] dcc774: msCGILoadMap(): do not load file pointed by CONTEX...
Even Rouault noreply at github.com
Tue Jan 3 12:09:59 PST 2023
  Branch: refs/heads/branch-8-0
  Home:   https://github.com/MapServer/MapServer
  Commit: dcc7749cd55b605b49365552620a98daaa0ca9bc
      https://github.com/MapServer/MapServer/commit/dcc7749cd55b605b49365552620a98daaa0ca9bc
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2023-01-03 (Tue, 03 Jan 2023)
  Changed paths:
    M mapcontext.c
    M mapows.h
    M mapservutil.c
  Log Message:
  msCGILoadMap(): do not load file pointed by CONTEXT= unless it validates new MS_CONTEXT_PATTERN configuration option (and doesn't validate MS_CONTEXT_BAD_PATTERN) (fixes #6779)
  Commit: a755ae811b9a26df042be247e9695c48462e07f7
      https://github.com/MapServer/MapServer/commit/a755ae811b9a26df042be247e9695c48462e07f7
  Changed paths:
    M msautotest/etc/mapserv.conf
    A msautotest/wxs/expected/ows_context_caps.xml
    A msautotest/wxs/ows_context.map
    A msautotest/wxs/ows_context.xml
  Log Message:
  msautotest: add a test for CONTEXT= loading (refs #6779)
  Commit: b65b1dbec4603e55877fa5aff8c243956903afa2
      https://github.com/MapServer/MapServer/commit/b65b1dbec4603e55877fa5aff8c243956903afa2
  Changed paths:
    M mapcontext.c
  Log Message:
  msGetMapContextFileText(): add sanity check on file size (refs #6779)
  Commit: 036e8dd7cd5f9eaeda1242358d682ab04a16498a
      https://github.com/MapServer/MapServer/commit/036e8dd7cd5f9eaeda1242358d682ab04a16498a
  Changed paths:
    M .github/workflows/start.sh
  Log Message:
  CI: check that we can't load a OWS context file if MS_CONTEXT_PATTERN is not defined (refs #6779)
  Commit: 98aa59e00a9008ced7089b5b5b9381fd6edcfb8b
      https://github.com/MapServer/MapServer/commit/98aa59e00a9008ced7089b5b5b9381fd6edcfb8b
  Changed paths:
    M mapcontext.c
  Log Message:
  msLoadMapContextGeneral(): fix memory leaks
  Commit: 9bac6407b5a83002a8cc4ca92bc7ee32e1fed90b
      https://github.com/MapServer/MapServer/commit/9bac6407b5a83002a8cc4ca92bc7ee32e1fed90b
  Changed paths:
    M mapcontext.c
    M mapserver.h
  Log Message:
  msLoadMapContext(): add validation of filename against MS_CONTEXTFILE_PATTERN, which defaults to .xml extension
  Commit: a9dabaf5249800eba01999a56a2c379d0dc03c87
      https://github.com/MapServer/MapServer/commit/a9dabaf5249800eba01999a56a2c379d0dc03c87
  Changed paths:
    M mapcontext.c
    M mapows.h
    M mapserver.h
    M mapservutil.c
  Log Message:
  Merge pull request #6782 from MapServer/backport-6780-to-branch-8-0
[Backport branch-8-0] Fix information disclosure and denial of service related to CONTEXT= loading
Compare: https://github.com/MapServer/MapServer/compare/38a41bd5b85f...a9dabaf52498
More information about the MapServer-commits mailing list
