[mapserver-commits] [MapServer/MapServer] 332805: Set Boolean subtype for OGR Output (#6803)
Seth G noreply at github.com
Thu Jan 26 07:23:58 PST 2023
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: 3328055a517e209b64c9b2757f8c172072342639
      https://github.com/MapServer/MapServer/commit/3328055a517e209b64c9b2757f8c172072342639
  Author: Seth G <sethg at geographika.co.uk>
  Date:   2023-01-26 (Thu, 26 Jan 2023)
  Changed paths:
    M mapogr.cpp
    M mapogroutput.cpp
    A msautotest/wxs/data/types.gpkg
    A msautotest/wxs/expected/wfs_autotypes10_geopackage.xml
    A msautotest/wxs/expected/wfs_autotypes11_geopackage.xml
    A msautotest/wxs/expected/wfs_autotypes20_geopackage.xml
    A msautotest/wxs/expected/wfs_getfeaturetypes10_geopackage.xml
    A msautotest/wxs/expected/wfs_getfeaturetypes11_geopackage.xml
    A msautotest/wxs/expected/wfs_getfeaturetypes20_booleans_postgis.json
    A msautotest/wxs/expected/wfs_getfeaturetypes20_geopackage.json
    A msautotest/wxs/expected/wfs_getfeaturetypes20_geopackage.xml
    A msautotest/wxs/wfs_autotypes_geopackage.map
    M msautotest/wxs/wfs_autotypes_postgis.map
  Log Message:
* Set Boolean subtype
* Convert true and false to 1 and 0 and add msautotest
* Update mapogroutput.cpp
Co-authored-by: Even Rouault <even.rouault at spatialys.com>
* Use new variable for comparison
* Use Boolean field types when reading OGR data sources
* Add geopackage tests
* Add test dataset
More information about the MapServer-commits mailing list
