[mapserver-commits] [MapServer/MapServer] 390d8f: [Backport branch-8-0] No longer output MS version ...
github-actions[bot] noreply at github.com
Thu Jan 26 18:05:11 PST 2023
  Branch: refs/heads/branch-8-0
  Home:   https://github.com/MapServer/MapServer
  Commit: 390d8fd9df15f6c1be4c9a6507c85b827bfe7325
      https://github.com/MapServer/MapServer/commit/390d8fd9df15f6c1be4c9a6507c85b827bfe7325
  Author: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
  Date:   2023-01-26 (Thu, 26 Jan 2023)
  Changed paths:
    M maperror.c
    M mapogcsos.c
    M mapservutil.c
    M mapwfs.cpp
    M mapwms.cpp
    M msautotest/api/expected/ogcapi_invalid_api_signature1.txt
    M msautotest/api/expected/ogcapi_invalid_api_signature2.txt
    M msautotest/api/expected/ogcapi_invalid_mapfile.txt
    M msautotest/api/expected/ogcapi_missing_api_signature1.txt
    M msautotest/api/expected/ogcapi_missing_api_signature2.txt
    M msautotest/config/expected/empty1_conf.txt
    M msautotest/config/expected/empty2_conf.txt
    M msautotest/config/expected/invalid1_conf.txt
    M msautotest/config/expected/invalid2_conf.txt
    M msautotest/config/expected/missing_conf.txt
    M msautotest/config/expected/ms_map_no_path1_conf.txt
    M msautotest/config/expected/ms_map_no_path2_conf_failure1.txt
    M msautotest/config/expected/ms_map_no_path2_conf_failure2.txt
    M msautotest/config/expected/ms_map_pattern_conf.txt
    M msautotest/config/expected/ms_map_pattern_conf_bad_regex.txt
    M msautotest/config/expected/ms_no_post_conf_failure.txt
    R msautotest/config/expected/ms_no_version_conf.txt
    M msautotest/config/hello_world.map
    R msautotest/config/ms_no_version.conf
    M msautotest/misc/expected/centerline3_exception.txt
    M msautotest/misc/expected/centerline4_exception.txt
    M msautotest/misc/expected/centerline5_exception.txt
    M msautotest/misc/expected/flatgeobuf-wfs-cap.xml
    M msautotest/misc/expected/runtime_sub_test001.txt
    M msautotest/misc/expected/runtime_sub_test003.txt
    M msautotest/misc/expected/runtime_sub_test005.txt
    M msautotest/misc/expected/runtime_sub_test_caps.xml
    M msautotest/renderers/expected/font-fail-file.txt
    M msautotest/renderers/expected/font-fail-key.txt
    M msautotest/renderers/expected/legend_bad_imagetype.txt
    M msautotest/wxs/expected/ows_all_wms_capabilities.xml
    M msautotest/wxs/expected/ows_all_wms_capabilities_post.xml
    M msautotest/wxs/expected/ows_context_caps.xml
    M msautotest/wxs/expected/ows_metadata_wfs_capabilities100.xml
    M msautotest/wxs/expected/ows_metadata_wms_capabilities111.xml
    M msautotest/wxs/expected/ows_metadata_wms_capabilities130.xml
    M msautotest/wxs/expected/ows_wms_capabilities.xml
    M msautotest/wxs/expected/ows_wms_rootlayer_name_capabilities.xml
    M msautotest/wxs/expected/ows_wms_rootlayer_name_empty_capabilities.xml
    M msautotest/wxs/expected/sos_cap.xml
    M msautotest/wxs/expected/sos_cap0.xml
    M msautotest/wxs/expected/sos_cap1.xml
    M msautotest/wxs/expected/sos_caps_updatesequence.xml
    M msautotest/wxs/expected/wfs10_test_xml_escaping.xml
    M msautotest/wxs/expected/wfs_cap.xml
    M msautotest/wxs/expected/wfs_cap_ogr.xml
    M msautotest/wxs/expected/wfs_caps_updatesequence.xml
    M msautotest/wxs/expected/wfs_caps_updatesequence_ogr.xml
    M msautotest/wxs/expected/wfs_get_caps.xml
    M msautotest/wxs/expected/wfs_multiple_metadataurl_100_cap.xml
    M msautotest/wxs/expected/wfs_ogr_drv_nocreatedatasource_caps.xml
    M msautotest/wxs/expected/wfs_ogr_nonexistingdrv_caps.xml
    M msautotest/wxs/expected/wfsogr10_caps.xml
    M msautotest/wxs/expected/wms111_test_xml_escaping.xml
    M msautotest/wxs/expected/wms130_test_xml_escaping.xml
    M msautotest/wxs/expected/wms_cap.xml
    M msautotest/wxs/expected/wms_cap130.xml
    M msautotest/wxs/expected/wms_cap130_postgis.xml
    M msautotest/wxs/expected/wms_cap_latestversion.xml
    M msautotest/wxs/expected/wms_cap_latestversion_postgis.xml
    M msautotest/wxs/expected/wms_cap_postgis.xml
    M msautotest/wxs/expected/wms_caps_updatesequence.xml
    M msautotest/wxs/expected/wms_caps_updatesequence_postgis.xml
    M msautotest/wxs/expected/wms_dimension_cap.xml
    M msautotest/wxs/expected/wms_dimension_cap130.xml
    M msautotest/wxs/expected/wms_empty_cap100.xml
    M msautotest/wxs/expected/wms_empty_cap111.xml
    M msautotest/wxs/expected/wms_empty_cap130.xml
    M msautotest/wxs/expected/wms_empty_cap_latestversion.xml
    M msautotest/wxs/expected/wms_get_capabilities_tileindexmixedsrs.xml
    M msautotest/wxs/expected/wms_get_caps.xml
    M msautotest/wxs/expected/wms_inspire_cap.xml
    M msautotest/wxs/expected/wms_inspire_cap_111.xml
    M msautotest/wxs/expected/wms_inspire_cap_111_eng.xml
    M msautotest/wxs/expected/wms_inspire_cap_111_ger.xml
    M msautotest/wxs/expected/wms_inspire_cap_eng.xml
    M msautotest/wxs/expected/wms_inspire_cap_ger.xml
    M msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
    M msautotest/wxs/expected/wms_inspire_scenario1_cap130_eng.xml
    M msautotest/wxs/expected/wms_inspire_scenario1_cap130_ger.xml
    M msautotest/wxs/expected/wms_inspire_scenario2_cap111.xml
    M msautotest/wxs/expected/wms_inspire_scenario2_cap111_eng.xml
    M msautotest/wxs/expected/wms_inspire_scenario2_cap111_ger.xml
    M msautotest/wxs/expected/wms_inspire_scenario2_cap130.xml
    M msautotest/wxs/expected/wms_inspire_scenario2_cap130_eng.xml
    M msautotest/wxs/expected/wms_inspire_scenario2_cap130_ger.xml
    M msautotest/wxs/expected/wms_layer_groups_caps111.xml
    M msautotest/wxs/expected/wms_multiple_metadataurl_cap.xml
    M msautotest/wxs/expected/wms_north_polar_stereo_extent.xml
    M msautotest/wxs/expected/wms_nosld_cap.xml
    M msautotest/wxs/expected/wms_nosld_cap_postgis.xml
    M msautotest/wxs/expected/wms_rast_cap.xml
    M msautotest/wxs/expected/wms_time_cap.xml
    M msautotest/wxs/expected/wms_time_cap130.xml
    M msautotest/wxs/expected/wms_time_cap130_postgis_postgis.xml
    M msautotest/wxs/expected/wms_time_cap_postgis_postgis.xml
  Log Message:
  [Backport branch-8-0] No longer output MS version numbers in client responses (#6809)
* No longer output MS version numbers in client responses
* Update tests to match responses with no version
* Remove MS_NO_VERSION test
Co-authored-by: sethg <sethg at geographika.co.uk>
More information about the MapServer-commits mailing list
