[mapserver-commits] [MapServer/MapServer] 6611ca: Remove scripts/github_issue_no_activity_closer.py ...
Even Rouault noreply at github.com
Wed Oct 4 14:54:43 PDT 2023
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: 6611ca0c8c88d3fc8ef770ff634c704643fd1de6
      https://github.com/MapServer/MapServer/commit/6611ca0c8c88d3fc8ef770ff634c704643fd1de6
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2023-09-28 (Thu, 28 Sep 2023)
  Changed paths:
    R scripts/github_issue_no_activity_closer.py
  Log Message:
  Remove scripts/github_issue_no_activity_closer.py (should be replaced by stale-bot if needed)
  Commit: 26a8a266031b3cdf4e1d1a175679aaeb690809cf
      https://github.com/MapServer/MapServer/commit/26a8a266031b3cdf4e1d1a175679aaeb690809cf
  Changed paths:
    A .clang-format
    A .flake8
    A .pre-commit-config.yaml
  Log Message:
  Add .flake8, .pre-commit-config.yaml and .clang-format
  Commit: d3c6274e83eab857f122aacad925cf276e99212f
      https://github.com/MapServer/MapServer/commit/d3c6274e83eab857f122aacad925cf276e99212f
  Author: Even Rouault reformatting bot <not-a-valid-email at spatialys.com>
  Changed paths:
    M fuzzers/mapfuzzer.c
    M fuzzers/reproducer_main.cpp
    M fuzzers/shapefuzzer.c
    M msautotest/api/run_test.py
    M msautotest/config/run_test.py
    M msautotest/conftest.py
    M msautotest/gdal/run_test.py
    M msautotest/misc/run_test.py
    M msautotest/msoracle/run_test.py
    M msautotest/mspython/run_all_tests.py
    M msautotest/mspython/test_bug_check.py
    M msautotest/mspython/test_mapio.py
    M msautotest/mspython/test_ogr_query.py
    M msautotest/mspython/test_postgis.py
    M msautotest/mspython/test_rq.py
    M msautotest/mspython/test_wkt.py
    M msautotest/mspython/test_xmp.py
    M msautotest/mssql/run_test.py
    M msautotest/php/run_test.py
    M msautotest/pymod/msautotest_viewer.py
    M msautotest/pymod/mstestlib.py
    M msautotest/pymod/pmstestlib.py
    M msautotest/pymod/testlib.py
    M msautotest/pymod/xmlvalidate.py
    M msautotest/query/run_test.py
    M msautotest/renderers/run_test.py
    M msautotest/sld/run_test.py
    M msautotest/wxs/run_test.py
    M scripts/mapaxisorder/create_mapaxisorder_csv.py
    M src/apache/mod_mapserver.c
    M src/apps/coshp.c
    M src/apps/legend.c
    M src/apps/map2img.c
    M src/apps/mapserv.c
    M src/apps/mapserv.h
    M src/apps/msencrypt.c
    M src/apps/scalebar.c
    M src/apps/shptree.c
    M src/apps/shptreetst.c
    M src/apps/shptreevis.c
    M src/apps/sortshp.c
    M src/apps/testcopy.c
    M src/apps/testexpr.c
    M src/apps/tile4ms.c
    M src/cgiutil.c
    M src/cgiutil.h
    M src/classobject.c
    M src/dxfcolor.h
    M src/fontcache.c
    M src/fontcache.h
    M src/hittest.c
    M src/hittest.h
    M src/idw.c
    M src/interpolation.c
    M src/kerneldensity.c
    M src/layerobject.c
    M src/mapagg.cpp
    M src/mapagg.h
    M src/mapaxisorder.h
    M src/mapbits.c
    M src/mapcairo.c
    M src/mapchart.c
    M src/mapcluster.c
    M src/mapcompositingfilter.c
    M src/mapcontext.c
    M src/mapcontour.c
    M src/mapcopy.c
    M src/mapcopy.h
    M src/mapcpl.c
    M src/mapcrypto.c
    M src/mapdebug.c
    M src/mapdraw.c
    M src/mapdrawgdal.c
    M src/mapdummyrenderer.c
    M src/mapentities.h
    M src/maperror.c
    M src/maperror.h
    M src/mapfile.c
    M src/mapfile.h
    M src/mapflatgeobuf.c
    M src/mapgdal.cpp
    M src/mapgdal.h
    M src/mapgeomtransform.c
    M src/mapgeomutil.cpp
    M src/mapgeos.c
    M src/mapgml.c
    M src/mapgml.h
    M src/mapgraph.cpp
    M src/mapgraph.h
    M src/mapgraticule.c
    M src/maphash.c
    M src/maphash.h
    M src/maphttp.c
    M src/maphttp.h
    M src/mapiconv.c
    M src/mapiconv.h
    M src/mapimageio.c
    M src/mapimagemap.c
    M src/mapio.c
    M src/mapio.h
    M src/mapjoin.c
    M src/mapkml.cpp
    M src/mapkmlrenderer.cpp
    M src/mapkmlrenderer.h
    M src/maplabel.c
    M src/maplayer.c
    M src/maplegend.c
    M src/maplibxml2.c
    M src/maplibxml2.h
    M src/mapmetadata.c
    M src/mapmssql2008.c
    M src/mapmvt.c
    M src/mapobject.c
    M src/mapogcapi.cpp
    M src/mapogcapi.h
    M src/mapogcfilter.cpp
    M src/mapogcfilter.h
    M src/mapogcfiltercommon.cpp
    M src/mapogcsld.c
    M src/mapogcsld.h
    M src/mapogcsos.c
    M src/mapogl.cpp
    M src/mapoglcontext.cpp
    M src/mapoglcontext.h
    M src/mapoglrenderer.cpp
    M src/mapoglrenderer.h
    M src/mapogr.cpp
    M src/mapogroutput.cpp
    M src/maporaclespatial.c
    M src/mapoutput.c
    M src/mapows.c
    M src/mapows.h
    M src/mapowscommon.c
    M src/mapowscommon.h
    M src/mappluginlayer.c
    M src/mappool.c
    M src/mappostgis.cpp
    M src/mappostgis.h
    M src/mappostgresql.c
    M src/mapprimitive.c
    M src/mapprimitive.h
    M src/mapproject.c
    M src/mapproject.h
    M src/mapquantization.c
    M src/mapquery.c
    M src/mapraster.c
    M src/mapraster.h
    M src/maprasterquery.c
    M src/mapregex.c
    M src/mapregex.h
    M src/maprendering.c
    M src/mapresample.c
    M src/mapresample.h
    M src/mapscale.c
    M src/mapscript/python/examples/project_csv.py
    M src/mapscript/python/examples/shpdump.py
    M src/mapscript/python/examples/shpinfo.py
    M src/mapscript/python/examples/wxs.py
    M src/mapscript/python/mapscript/__init__.py
    M src/mapscript/python/tests/cases/class_test.py
    M src/mapscript/python/tests/cases/clone_test.py
    M src/mapscript/python/tests/cases/cluster_test.py
    M src/mapscript/python/tests/cases/color_test.py
    M src/mapscript/python/tests/cases/config_test.py
    M src/mapscript/python/tests/cases/font_test.py
    M src/mapscript/python/tests/cases/hash_test.py
    M src/mapscript/python/tests/cases/image_test.py
    M src/mapscript/python/tests/cases/label_test.py
    M src/mapscript/python/tests/cases/layer_test.py
    M src/mapscript/python/tests/cases/line_test.py
    M src/mapscript/python/tests/cases/map_test.py
    M src/mapscript/python/tests/cases/outputformat_test.py
    M src/mapscript/python/tests/cases/ows_test.py
    M src/mapscript/python/tests/cases/parentreference_test.py
    M src/mapscript/python/tests/cases/pgtest.py
    M src/mapscript/python/tests/cases/point_test.py
    M src/mapscript/python/tests/cases/rect_test.py
    M src/mapscript/python/tests/cases/refcount_test.py
    M src/mapscript/python/tests/cases/resultcache_test.py
    M src/mapscript/python/tests/cases/shape_test.py
    M src/mapscript/python/tests/cases/shapefile_test.py
    M src/mapscript/python/tests/cases/style_test.py
    M src/mapscript/python/tests/cases/symbol_test.py
    M src/mapscript/python/tests/cases/symbolset_test.py
    M src/mapscript/python/tests/cases/testing.py
    M src/mapscript/python/tests/cases/thread_test.py
    M src/mapscript/python/tests/cases/zoom_test.py
    M src/mapscript/python/tests/runalldoctests.py
    M src/mapscript/python/tests/runtests.py
    M src/mapscript/python/tests/timing/clonemaps.py
    M src/mapscript/python/tests/timing/drawshapes.py
    M src/mapscript/python/tests/timing/testing.py
    M src/mapscript/v8/line.cpp
    M src/mapscript/v8/line.hpp
    M src/mapscript/v8/point.cpp
    M src/mapscript/v8/point.hpp
    M src/mapscript/v8/shape.cpp
    M src/mapscript/v8/shape.hpp
    M src/mapscript/v8/v8_mapscript.cpp
    M src/mapscript/v8/v8_mapscript.h
    M src/mapscript/v8/v8_object_wrap.hpp
    M src/mapsearch.c
    M src/mapserv-config.cpp
    M src/mapserv-config.h
    M src/mapserver-api.c
    M src/mapserver-api.h
    M src/mapserver.h
    M src/mapservutil.c
    M src/mapshape.c
    M src/mapshape.h
    M src/mapsmoothing.c
    M src/mapstring.cpp
    M src/mapsymbol.c
    M src/mapsymbol.h
    M src/maptclutf.c
    M src/maptemplate.c
    M src/maptemplate.h
    M src/mapthread.c
    M src/mapthread.h
    M src/maptile.c
    M src/maptile.h
    M src/maptime.c
    M src/maptime.h
    M src/maptree.c
    M src/maptree.h
    M src/mapunion.cpp
    M src/maputfgrid.cpp
    M src/maputfgrid.h
    M src/maputil.c
    M src/mapuvraster.c
    M src/mapv8.cpp
    M src/mapwcs.cpp
    M src/mapwcs.h
    M src/mapwcs11.cpp
    M src/mapwcs20.cpp
    M src/mapwfs.cpp
    M src/mapwfs11.cpp
    M src/mapwfs20.c
    M src/mapwfslayer.c
    M src/mapwms.cpp
    M src/mapwmslayer.c
    M src/mapxbase.c
    M src/mapxml.c
    M src/mapxmp.c
    M src/strptime.c
    M src/textlayout.c
  Log Message:
  Run pre-commit to reformat .c, .h, .cpp and .py files
  Commit: e831b8bc33e0c03f28d8694b357d86cc0771cf50
      https://github.com/MapServer/MapServer/commit/e831b8bc33e0c03f28d8694b357d86cc0771cf50
  Changed paths:
    A .git-blame-ignore-revs
  Log Message:
  Add .git-blame-ignore-revs
  Commit: cd92d903bf2782fd2b44d418c4a7df4bc367a6cd
      https://github.com/MapServer/MapServer/commit/cd92d903bf2782fd2b44d418c4a7df4bc367a6cd
  Changed paths:
    A .github/workflows/code_checks.yml
  Log Message:
  Add .github/workflows/code_checks.yml
  Commit: 10ee9f515248dc62137c655df4e7e39cfae67b29
      https://github.com/MapServer/MapServer/commit/10ee9f515248dc62137c655df4e7e39cfae67b29
  Date:   2023-10-04 (Wed, 04 Oct 2023)
  Changed paths:
    A .clang-format
    A .flake8
    M src/apps/coshp.c
    M src/apps/legend.c
    M src/cgiutil.c
    M src/cgiutil.h
    M src/classobject.c
    M src/dxfcolor.h
    M src/fontcache.c
    M src/fontcache.h
    M src/hittest.c
    M src/hittest.h
    M src/idw.c
    M src/layerobject.c
    M src/mapagg.cpp
    M src/mapagg.h
    M src/mapbits.c
    M src/mapcairo.c
    M src/mapchart.c
    M src/mapcluster.c
    M src/mapcontext.c
    M src/mapcontour.c
    M src/mapcopy.c
    M src/mapcopy.h
    M src/mapcpl.c
    M src/mapcrypto.c
    M src/mapdebug.c
    M src/mapdraw.c
    M src/mapdrawgdal.c
    M src/mapentities.h
    M src/maperror.c
    M src/maperror.h
    M src/mapfile.c
    M src/mapfile.h
    M src/mapgdal.cpp
    M src/mapgdal.h
    M src/mapgeos.c
    M src/mapgml.c
    M src/mapgml.h
    M src/mapgraph.cpp
    M src/mapgraph.h
    M src/maphash.c
    M src/maphash.h
    M src/maphttp.c
    M src/maphttp.h
    M src/mapiconv.c
    M src/mapiconv.h
    M src/mapimageio.c
    M src/mapimagemap.c
    M src/mapio.c
    M src/mapio.h
    M src/mapjoin.c
    M src/mapkml.cpp
    M src/maplabel.c
    M src/maplayer.c
    M src/maplegend.c
    M src/maplibxml2.c
    M src/maplibxml2.h
    M src/mapmetadata.c
    M src/mapmvt.c
    M src/mapobject.c
    M src/mapogcapi.cpp
    M src/mapogcapi.h
    M src/mapogcsld.c
    M src/mapogcsld.h
    M src/mapogcsos.c
    M src/mapogl.cpp
    M src/mapogr.cpp
    M src/mapoutput.c
    M src/mapows.c
    M src/mapows.h
    M src/mappool.c
    M src/mappostgis.h
    M src/mapproject.c
    M src/mapproject.h
    M src/mapquery.c
    M src/mapraster.c
    M src/mapraster.h
    M src/mapregex.c
    M src/mapregex.h
    M src/mapresample.c
    M src/mapresample.h
    M src/mapscale.c
    M src/mapsearch.c
    M src/mapserver.h
    M src/mapservutil.c
    M src/mapshape.c
    M src/mapshape.h
    M src/mapstring.cpp
    M src/mapsymbol.c
    M src/mapsymbol.h
    M src/maptclutf.c
    M src/maptemplate.c
    M src/maptemplate.h
    M src/mapthread.c
    M src/mapthread.h
    M src/maptile.c
    M src/maptile.h
    M src/maptime.c
    M src/maptime.h
    M src/maptree.c
    M src/maptree.h
    M src/mapunion.cpp
    M src/maputfgrid.h
    M src/maputil.c
    M src/mapuvraster.c
    M src/mapv8.cpp
    M src/mapwcs.cpp
    M src/mapwcs.h
    M src/mapwcs11.cpp
    M src/mapwcs20.cpp
    M src/mapwfs.cpp
    M src/mapwfs11.cpp
    M src/mapwfs20.c
    M src/mapwfslayer.c
    M src/mapwms.cpp
    M src/mapwmslayer.c
    M src/mapxbase.c
    M src/mapxml.c
    M src/mapxmp.c
    M src/strptime.c
    M src/textlayout.c
  Log Message:
  Merge pull request #6937 from rouault/reformatting
Whole code base reformatting
Compare: https://github.com/MapServer/MapServer/compare/293e85247623...10ee9f515248
More information about the MapServer-commits mailing list
