[mapserver-commits] [MapServer/MapServer] 641134: msautotest: remove outdated use of IMAGEMODE PC256...
Even Rouault noreply at github.com
Sat Sep 9 04:20:02 PDT 2023
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: 6411340d74709177c4a52391904f1a1213c3e122
      https://github.com/MapServer/MapServer/commit/6411340d74709177c4a52391904f1a1213c3e122
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2023-09-09 (Sat, 09 Sep 2023)
  Changed paths:
    M msautotest/gdal/256_overlay_res.map
    M msautotest/gdal/256color_overdose.map
    M msautotest/gdal/256color_overdose_cmt.map
    M msautotest/gdal/256color_overdose_res.map
    M msautotest/gdal/class16.map
    M msautotest/gdal/class16_classify_scaled.map
    M msautotest/gdal/class16_intoddscale.map
    M msautotest/gdal/class16_ndmap.map
    M msautotest/gdal/class16_oddscale.map
    M msautotest/gdal/class16_range.map
    M msautotest/gdal/class8_range.map
    M msautotest/gdal/classtest1.map
    M msautotest/gdal/classtest2.map
    M msautotest/gdal/gd_png_256_res.map
    M msautotest/gdal/gd_png_tr_256.map
    M msautotest/gdal/gd_png_tr_256_res.map
    M msautotest/gdal/gdal_png_256_res.map
    M msautotest/gdal/gdal_png_tr_256.map
    M msautotest/gdal/gdal_png_tr_256_res.map
    M msautotest/gdal/grayalpha_8bit.map
    M msautotest/gdal/lut_1_crv.map
    M msautotest/gdal/lut_float.map
    M msautotest/gdal/nodata_8bit.map
    M msautotest/gdal/nodata_scaled.map
    M msautotest/gdal/nonsquare.map
    M msautotest/gdal/offsite_8bitgrey.map
    M msautotest/gdal/offsite_pct_rgb.map
    M msautotest/gdal/processing_scale_auto.map
    M msautotest/gdal/reproj.map
    M msautotest/gdal/rgb_overlay_res_to8bit.map
    M msautotest/gdal/rgb_overlay_res_to8bit_dithered.map
    M msautotest/gdal/tileindex.map
    M msautotest/gdal/tileindex_mi.map
    M msautotest/gdal/trlay1.map
    M msautotest/gdal/trlay2.map
    M msautotest/gdal/trlay3.map
    M msautotest/gdal/wld_override.map
    M msautotest/gdal/wld_rotate.map
    M msautotest/gdal/wld_upsidedown.map
    M msautotest/gdal/wmsclient.map
    M msautotest/renderers/reproj.map
    M msautotest/renderers/rgb_overlay_res_to8bit.map
    M msautotest/renderers/rgb_overlay_res_to8bit_dithered.map
    M msautotest/wxs/expected/wcs11_cap.txt
    M msautotest/wxs/expected/wcs11_cap.xml
    M msautotest/wxs/expected/wcs11_caps_section1.xml
    M msautotest/wxs/expected/wcs11_caps_section3.xml
    M msautotest/wxs/expected/wcs11_caps_updatesequence.xml
    M msautotest/wxs/expected/wcs11_post_cap.xml
    M msautotest/wxs/expected/wcs11_post_caps_section1.xml
    M msautotest/wxs/expected/wcs11_post_caps_section3.xml
    M msautotest/wxs/expected/wcs11_post_caps_updatesequence.xml
    M msautotest/wxs/expected/wcs_20_cap.txt
    M msautotest/wxs/expected/wcs_20_cap.xml
    M msautotest/wxs/expected/wcs_20_cap_200.xml
    M msautotest/wxs/expected/wcs_20_cap_accept_versions.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_default.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_multiple.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_secondary.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_embed_acceptlanguage_unknown.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_default.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_multiple.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_secondary.xml
    M msautotest/wxs/expected/wcs_20_cap_inspire_url_acceptlanguage_unknown.xml
    M msautotest/wxs/expected/wcs_20_cap_sections_all.xml
    M msautotest/wxs/expected/wcs_20_cap_sections_all_specific.xml
    M msautotest/wxs/expected/wcs_20_cap_sections_service_metadata.xml
    M msautotest/wxs/expected/wcs_20_cap_updatesequence.xml
    M msautotest/wxs/expected/wcs_20_post_cap.xml
    M msautotest/wxs/expected/wcs_cap_highversion_x.y.xml
    M msautotest/wxs/expected/wcs_cap_highversion_x.y.z.xml
    M msautotest/wxs/expected/wcs_cap_noversion.xml
    M msautotest/wxs/expected/wcs_multiple_metadatalink_110_cap.xml
    M msautotest/wxs/expected/wcs_multiple_metadatalink_200_cap.xml
    M msautotest/wxs/ows_wcs.map
    M msautotest/wxs/tomk_workshop.map
    M msautotest/wxs/wcs_inspire_scenario1.map
    M msautotest/wxs/wcs_inspire_scenario2.map
    M msautotest/wxs/wcs_mask.map
    M msautotest/wxs/wcs_multiple_metadatalink.map
    M msautotest/wxs/wcs_post.map
    M msautotest/wxs/wcs_simple.map
    M msautotest/wxs/wfs_filter_projmeter.map
    M msautotest/wxs/wfs_misc.map
    M msautotest/wxs/wms_custom_projection.map
    M msautotest/wxs/wms_grid_reproj_to_3857.map
    M msautotest/wxs/wms_multiple_metadataurl.map
    M msautotest/wxs/wms_nosld.map
    M msautotest/wxs/wms_nosld_postgis.map
    M msautotest/wxs/wms_polar_stereo.map
    M msautotest/wxs/wms_postgis_boxtoken.map
    M msautotest/wxs/wms_raster.map
    M msautotest/wxs/wms_simple.map
    M msautotest/wxs/wms_simple_postgis.map
    M msautotest/wxs/wms_src_non_square_pixel_ticket5445.map
    M msautotest/wxs/wms_tiled.map
  Log Message:
  msautotest: remove outdated use of IMAGEMODE PC256 and GD/ (#6929)
More information about the MapServer-commits mailing list
