[Mapserver-dev] PHP/.Mapscript problem with last nights build
Yewondwossen Assefa assefa at dmsolutions.ca
Mon Apr 21 09:27:07 EDT 2003
Hi There,
 There was an error intoduced on Wednedsay 16th when I added the outputformat object to the map object without adding a destructor in php. It was  fixed the on Thursay
17th revsion 1.154.
 If you have the same problem with the latest version, please let me know.
Later,
woodbri at swoodbridge.com wrote:
> Hi all,
> I ran into a problem with last nights nightly.tar.gz download. I get the following message appended to my output:
> <br />
> <b>Warning</b>:  Unknown list entry type in request shutdown (0) in <b>Unknown</b> on line <b>0</b><br />
> Since the output is supposed to be xml it messes up things. I know I can turn off warning messages, but someone probably needs to look into on the development team.
> Thanks,
>   -Steve Woodbridge
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
