[Mapserver-dev] Yanking GD 1 and Freetype 1 support fromCVS version...
Steve Lime steve.lime at dnr.state.mn.us
Fri Apr 25 14:54:41 EDT 2003
I used the former, works fine. I still need to tweak the configure
script a bit. There
are a few funky things in the GD section like a do loop to process /usr
and /usr/local.
That doesn't seem necessary but I'm no configure expert.  I'm not sure
the script
is right when a user sets an lib directory either, need to read up on
AC_CHECK_LIB()
in those cases. It works ok though in most circumstances. Commited on
Wed.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Daniel Morissette <morissette at dmsolutions.ca> 04/23/03 01:55PM >>>
Perhaps gdImageCreateTrueColor()?  gdImageSetAntiAliased() could be a
good candidate too since it's the reason behind this whole change, but
I
think it's present only in version 2.0.12.
Daniel
Steve Lime wrote:
> I'll do that. I'm just about done mucking with the configure.in
script.
> Just need a
> way to differentiate GD2 from GD1. There must be a function so I
need
> to read
> the docs at boutell.com. I should commit changes tonite.
> Steve
> >>> Daniel Morissette <morissette at dmsolutions.ca> 04/21/03 05:19PM
> Steve Lime wrote:
> > Just as a warning, I'm planning to spend part of this evening
making
> the
> > distribution dependent only
> > on GD/Freetype 2. Given the new features in MapServer AND the new
> > functionality in those libs it
> > simplifies maintenance a great deal. Lemme know if anyone see's
> > problems with this...
> ... and perhaps when you commit those changes it would be a good
time
> to
> change the version information to 4.0-dev.  I don't think there were
> objections from anyone against switching the version to 4.0 for this
> upcoming release.
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
