[Mapserver-dev] Re: time support
Daniel Morissette morissette at dmsolutions.ca
Wed Dec 17 10:49:38 EST 2003
Steve Lime wrote:
> A timeindex would not be a shapefile, rather simply a temporal lookup
> table. An xbase file would do nicely.
You're right. I didn't realize that.
> That
> way date expressions could be used with any data source if a column
> contained ISO8601 formated date/time strings. In that case using a
> timeindex for anything but raster data may not be necessary. Raster data
> is certainly the task at hand for me.
Actually, some people might have one shapefile per time range (or time
value), so I can see why this TIMEINDEX would be useful to shapefiles as
  well. Imagine an organization with 100 years of daily weather data:
that's too much information to store in a single shapefile if you want
reasonable performance. I guess they would be better using a RDBMS than
shapefiles for this anyway, but that's an example where TIMEINDEX on
shapefiles could be used.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
