[Mapserver-dev] Re: 3.7 and native image rendering support
Steve Lime steve.lime at dnr.state.mn.us
Fri Feb 7 17:47:46 EST 2003
JPEG sucks as a spatial data format though, at least for random access. I'd rather not encourage its use...
>>> Sean Gillies <sgillies at frii.com> 02/07/03 04:34PM >>>
On Friday, February 7, 2003, at 03:01  PM, Frank Warmerdam wrote:
> Steve Lime wrote:
>> Frank: What would you think about loosing all native raster support
>> in favor
>> of OGR? The only obstacle I see is the EPPL7 support but perhaps that
>> could
>> be added to OGR. It's a pretty straight forward format I think. I'm
>> just
>> thinking that simplifying the configuration options, not to mention
>> the code
>> maintenance, is a good idea at this point.
> Steve,
> I think this makes sense from a maintenance point of view, but I am
> concerned
> that it makes it impossible to built a light version of mapserver with
> raster input support.
> I am thinking we should move the EPPL7 format into GDAL and then blow
> away
> all format support except for PNG and GIF done using GD (pseudocolored
> only),
> with world files.  Furthermore I think we should only use these
> drivers if
> GDAL is not enabled, and we would need to better clarify the
> limitations
> of the non-GDAL drivers.
> In particular, I would like to get rid of the existing TIFF driver
> which
> has some significant flaws, and often gets used instead of GDAL.
> I have cc:ed this to the developers list to see if anyone else has an
> opinion on the importance of a "light" option for MapServer.
> Best regards,
Frank,
I think that the "light" option should also support JPEG through GD
so that users have an option for serving a large volume of compressed
RGB imagery.  Am with you on the TIFF driver.
Sean
Sean Gillies
http://www.frii.com/~sgillies
