[Mapserver-dev] New msCloneLayerObj() function
Daniel Morissette morissette at dmsolutions.ca
Mon Feb 17 13:54:45 EST 2003
Steve,
We are thinking of adding a new function to mapfile.c (and MapScript) to
initialize a new layer by creating a clone of an existing layer.  This
would allow us to easily make copies of layers inside a single mapObj,
or to copy layers from one mapObj to another.
The C function prototype would be:
  int msCloneLayerObj(mapObj *target_map, layerObj *src_layer);
which would create a new layer inside target_map which is a copy of
src_layer.
In PHP MapScript, the function ms_newMapObj() would be extended to take
an optional second argument that would be the layer to clone:
 layerObj ms_newLayerObj(mapObj target_map [,layerObj layer_to_clone])
I don't think SWIG allows for optional arguments like we use in PHP, so
we would have to expose a separate function for msCloneLayerObj() in the
SWIG'd MapScript.
Is that OK with you?  Any suggestions, comments?
Daniel
 DM Solutions Group              http://www.dmsolutions.ca/
