[Mapserver-dev] COLOR_MATCH_THRESHOLD
Daniel Morissette morissette at dmsolutions.ca
Fri Feb 28 16:17:59 EST 2003
Frank Warmerdam wrote:
> >>In fact, such a mechanism might be desirable for other color allocation such
> >>as that occuring due to colors loaded from vector files using the OGR "AUTO
> >>styling".   However, that is a bigger effort than I am interested in pursuing
> >>at this time.
> > I didn't look at the code, but perhaps it would be enough to call
> > msAddColorGD() in the OGR code?  If you think that would do the trick (I
> > can't see why not) then I'll have a look.
> Daniel,
> Well, we would need to get the color threshold value and pass it around too.
> The msAddColorGD() code does a few weird things, and it might needs some
> looking at before implementing.
You're right, it's quite possible that the OGR STYLEITEM AUTO code needs
some work, independently of this color thing.  I'll add this to my list.
Daniel
 DM Solutions Group              http://www.dmsolutions.ca/
