[Mapserver-dev] MS concurrency problem with vector symbols
woodbri at swoodbridge.com woodbri at swoodbridge.com
Wed Jun 4 18:28:12 EDT 2003
Mark,
Mapserver, and therefore Mapscript, are not yet thread-safe. The
developers have been making a lot of changes to the source to remedy
this, and I don't think it is totally fixed in ms-3.7/4.0, let along
3.6.5.
You can search the archives for "thread safe" to get more info. By
the way, this is also the same reason that PHP must be built as a CGI
in Apache and not as a module if you want to use PHP/mapscript.
-Steve W.
On 4 Jun 2003 at 15:41, Mark Cave-Ayland wrote:
> Hi everyone,
> Since submitting a patch to the mapserver-users mailing list (see
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0305/msg00581
> .h tml) that allows use of Perl Mapscript under mod_perl, I think I
> may have found some kind of concurrency problem in MS 3.6.5.
> What I am finding is that initially running Perl Mapscript under
> mod_perl to return an image containing several point layers to the
> browser works fine until the browser is refreshed several times in
> quick succession. Then what happens is that the layers that are being
> drawn using vector symbols disappear and don't come back until Apache
> is restarted. If these layers are changed so that they use a PNG
> symbol instead then the problem doesn't occur. Running the same script
> as CGI causes all layers to always render correctly.
> So what I'm thinking is that there is some sort of concurrency issue
> in libmap to do with drawing vector symbols. Has anyone had any
> experience of this already and is it a problem with Mapserver or could
> it be the GD library (I am currently using 1.8.4)? Or has this already
> been identified and fixed in the upcoming 3.7/4.0 release?
> Many thanks,
> Mark.
> Mark Cave-Ayland
> Webbased Ltd.
> Tamar Science Park
> Derriford
> Plymouth
> PL6 8BX
> England
> Tel: +44 (0)1752 764445
> Fax: +44 (0)1752 764446
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender. You
> should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
