[Mapserver-dev] Can't run PHP/Mapscript as a CLI????
woodbri at swoodbridge.com woodbri at swoodbridge.com
Sun Jun 8 00:41:00 EDT 2003
HI all,
Not that most of you are about at the moment :) hope you are having
fun at the MUM ...
I was trying to debug a php/mapscript application using php as a cli
and got:
Fatal error: Due to thread-safety problems, php_mapscript cannot be
used as a 'cli' module.  You will have to reconfigure your PHP as a
CGI to run this version of MapScript.
See <a href="http://mapserver.gis.umn.edu/cgi-
bin/wiki.pl?PHPMapScriptCGI">http://mapserver.gis.umn.edu/cgi-
bin/wiki.pl?PHPMapScriptCGI</a>.
 in /var/www/html/cwc/htdocs/common/wrapper/map_session.php on line
214
Whoever is making this check needs to relax it so you can run as a
CLI for debugging purposes. There may be other ways, but my standard
way to debug server 500 errors and other problems is to run php like:
[root at woodbri htdocs]# export
QUERY_STRING='TEMPLATE=geobase_en.html&CONTEXT=geobase_regional_en.xml
&sessionid=123455677'
[root at woodbri htdocs]# export REQUEST_METHOD=GET
[root at woodbri htdocs]# export REDIRECT_STATUS=200
[root at woodbri htdocs]# php cwc2.php
or run it in the debugger to see where it dies. This used to work
fine.
-Steve W.
