[Mapserver-dev] Draw line with antialias
Daniel Morissette morissette at dmsolutions.ca
Fri Jun 13 11:43:38 EDT 2003
Steve Lime wrote:
> This is more for Dan/Assefa: Version 4.0 requires a minimum version of
> GD, 2.0.12. With that version antialiasing is available automatically so
> there's no need for a GD_USE_ANTIALIAS flag at all. Mapgd.c doesn't use
> it and configure won't finish if the GD antialiasing functions aren't
> present.
Sounds good.  There were still some #ifdef USE_GD_ANTIALIAS in
mapfile.c, that's why I thought there was a reason why you wanted to
keep this flag.
I have now removed USE_GD_ANTIALIAS from both mapfile.c and configure.
Assefa can do the same with the Windows Makefile.
Daniel
 DM Solutions Group              http://www.dmsolutions.ca/
