[Mapserver-dev] Draw line with antialias
andrea.rogges at virgilio.it andrea.rogges at virgilio.it
Fri Jun 13 11:55:55 EDT 2003
--========/3EC41D4E00022689/ims4c.cp.tin.it
Content-Type: text/plain; charset="ISO-8859-15"
Content-Transfer-Encoding: quoted-printable
Here is my mapfile definition...
>-- Messaggio originale --
>Date: Fri, 13 Jun 2003 10:50:42 -0500
>From: "Steve Lime" <steve.lime at dnr.state.mn.us>
>To: <assefa at dmsolutions.ca>,<andrea.rogges at virgilio.it>
>Cc: <mapserver-dev at lists.gis.umn.edu>
>Subject: Re: [Mapserver-dev] Draw line with antialias
>Send your mapfile definition. You can tell if it's working by the time
>it takes to generate a
>map. Antialiasing is SLOOOOWWWW.
>There are also some caveats to the GD support- these are GD issues, not
>MapServer issues.
>For example, styled symbols (i.e. dashes) cannot be antialiased, nor
>can brushed lines. Overall
>I was pretty disappointed with the support as it sits now. I'm sure it
>will bet better over time.
>Steve
>>>> <andrea.rogges at virgilio.it> 06/13/03 10:17AM >>>
>It doesn't work :-(...I use a shapefile layer only with lines...the
>problem
>can be in SYMBOL definition?
>>Date: Fri, 13 Jun 2003 11:10:01 -0400
>>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>>To: andrea.rogges at virgilio.it
>>CC: mapserver-dev <mapserver-dev at lists.gis.umn.edu>
>> From what I can see it the code you have to specify antilaias TRUE
>in
>>the Style object :
>> CALSS
>>     Style
>>        ANTIALIAS TRUE
>>      END
>>andrea.rogges at virgilio.it wrote:
>>>Sorry for my previous message, taking order of dll's now it works
>>>But the question now is: how can I draw line with antialias ?
>>>>Date: Fri, 13 Jun 2003 09:27:05 -0400
>>>>CC: mapserver-dev at lists.gis.umn.edu
>>>>New binaries are at :
>>>>http://www2.dmsolutions.ca/mapserver/dl/mapserver-4.0-dev-win32-php4.=
3.2.zip
>>>>>Thanks very much ;-)
>>>>>Andrea.
>>>>>PS: where can I find new files ?
>>>>>>Date: Thu, 12 Jun 2003 11:45:37 -0400
>>>>>>To: Daniel Morissette <morissette at dmsolutions.ca>
>>>>>>CC: andrea.rogges at virgilio.it, mapserver-dev at lists.gis.umn.edu
>>>>>>I will add that to the makefiles and It will be available in the
>next
>>>>>>binaries sometime this afternoon.
>>>>>>Later,
>>>>>>>>The results is this message:
>>>>>>>>"loadStyle(): GD library error: Antialiasing support is not
>available.
>>>>>>>>Get a newer version of GD!"
>>>>>>>>What can I do? Do I need to recompile MapServer with GD v2.0.15
>instead
>>>>>>>>of v2.0.12?
>>>>>>>I fixed this after the 4.0 beta for the Unix version.  For the
>Windows
>>>>>>>version, a -DUSE_GD_ANTIALIAS compile flag will have to be added
>to
>>>the
>>>>>>>makefiles.
>>>>>>Assefa Yewondwossen
>>>>>>Software Analyst
>>>>>>Email: assefa at dmsolutions.ca
>>>>>>http://www.dmsolutions.ca/
>>>>>>Phone: (613) 565-5056 (ext 14)
>>>>>>Fax:   (613) 565-0925
>>>>>_______________________________________________
>>>>>Mapserver-dev mailing list
>>>>>Mapserver-dev at lists.gis.umn.edu
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>>>Assefa Yewondwossen
>>>>Software Analyst
>>>>Fax:   (613) 565-0925
>>Assefa Yewondwossen
>>Software Analyst
>>Fax:   (613) 565-0925
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="demo.map"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--========/3EC41D4E00022689/ims4c.cp.tin.it--
