[Mapserver-dev] Draw line with antialias
andrea.rogges at virgilio.it andrea.rogges at virgilio.it
Tue Jun 24 08:55:07 EDT 2003
OK,
I'm eager to try it ;-)
Regards,
Andrea Rogges.
>-- Messaggio originale --
>Date: Fri, 20 Jun 2003 07:39:26 +0200
>From: Tomas Krecmer <tomas.krecmer at tmapy.cz>
>To: Steve Lime <steve.lime at dnr.state.mn.us>
>CC:  assefa at dmsolutions.ca,  andrea.rogges at virgilio.it,
> mapserver-dev at lists.gis.umn.edu
>Subject: Re: [Mapserver-dev] Draw line with antialias
>I will look at it. I  believe we will see antialised CARTOLINE symbol soon.
>the author of that code :-)
>Tomas
>Steve Lime wrote:
>>Based on the GD docs you may only draw single width lines antialiased.
>>So if you want
>>fat lines you have 1 option at the moment:
>>  - draw a fat center with single pixel lines on the outside (styles
>>with offsets)
>>Ideally the CARTOLINE symbol type will be the way to go because is
>>creates a thick line
>>by creating a filled polygon and not a brush. So, in that case we could
>>add to that code
>>to draw an outline around the line polygon that could be antialiased.
I
>>don't believe the
>>author of that code has mucked with GD antialiasing yet. I will mention
>>it to him though.
>>Steve
>>>>><andrea.rogges at virgilio.it> 06/13/03 11:15AM >>>
>>OK, what is your suggest for obtain a line drawing with antialias?
>>>Date: Fri, 13 Jun 2003 11:10:18 -0500
>>>From: "Steve Lime" <steve.lime at dnr.state.mn.us>
>>>To: <assefa at dmsolutions.ca>,<andrea.rogges at virgilio.it>
>>>Cc: <mapserver-dev at lists.gis.umn.edu>
>>>Since you're using an ellipse (a brush) the output cannot be
>>antialiased
>>>with GD as it sits now.
>>>Steve
>>>>>><andrea.rogges at virgilio.it> 06/13/03 10:55AM >>>
>>>Here is my mapfile definition...
>>>>Date: Fri, 13 Jun 2003 10:50:42 -0500
>>>>Send your mapfile definition. You can tell if it's working by the
>>>time
>>>>it takes to generate a
>>>>map. Antialiasing is SLOOOOWWWW.
>>>>There are also some caveats to the GD support- these are GD issues,
>>>not
>>>>MapServer issues.
>>>>For example, styled symbols (i.e. dashes) cannot be antialiased, nor
>>>>can brushed lines. Overall
>>>>I was pretty disappointed with the support as it sits now. I'm sure
>>>it
>>>>will bet better over time.
>>>>Steve
>>>>>>><andrea.rogges at virgilio.it> 06/13/03 10:17AM >>>
>>>>It doesn't work :-(...I use a shapefile layer only with lines...the
>>>>problem
>>>>can be in SYMBOL definition?
>>>>>Date: Fri, 13 Jun 2003 11:10:01 -0400
>>>>>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>>>>>To: andrea.rogges at virgilio.it
>>>>>CC: mapserver-dev <mapserver-dev at lists.gis.umn.edu>
>>>>>From what I can see it the code you have to specify antilaias TRUE
>>>>in
>>>>>the Style object :
>>>>>CALSS
>>>>>    Style
>>>>>       ANTIALIAS TRUE
>>>>>     END
>>>>>andrea.rogges at virgilio.it wrote:
>>>>>>Sorry for my previous message, taking order of dll's now it works
>>>>>>But the question now is: how can I draw line with antialias ?
>>>>>>>Date: Fri, 13 Jun 2003 09:27:05 -0400
>>>>>>>CC: mapserver-dev at lists.gis.umn.edu
>>>>>>>New binaries are at :
>>>>>>>http://www2.dmsolutions.ca/mapserver/dl/mapserver-4.0-dev-win32-php4.3.2.zip
>>>>>>>>Thanks very much ;-)
>>>>>>>>Andrea.
>>>>>>>>PS: where can I find new files ?
>>>>>>>>>Date: Thu, 12 Jun 2003 11:45:37 -0400
>>>>>>>>>To: Daniel Morissette <morissette at dmsolutions.ca>
>>>>>>>>>CC: andrea.rogges at virgilio.it, mapserver-dev at lists.gis.umn.edu
>>>>>>>>>I will add that to the makefiles and It will be available in
>>the
>>>>next
>>>>>>>>>binaries sometime this afternoon.
>>>>>>>>>Later,
>>>>>>>>>>>The results is this message:
>>>>>>>>>>>"loadStyle(): GD library error: Antialiasing support is not
>>>>available.
>>>>>>>>>>>Get a newer version of GD!"
>>>>>>>>>>>What can I do? Do I need to recompile MapServer with GD
>>>v2.0.15
>>>>instead
>>>>>>>>>>>of v2.0.12?
>>>>>>>>>>I fixed this after the 4.0 beta for the Unix version.  For the
>>>>Windows
>>>>>>>>>>version, a -DUSE_GD_ANTIALIAS compile flag will have to be
>>>added
>>>>to
>>>>>>the
>>>>>>>>>>makefiles.
>>>>>>>>>Assefa Yewondwossen
>>>>>>>>>Software Analyst
>>>>>>>>>Email: assefa at dmsolutions.ca
>>>>>>>>>http://www.dmsolutions.ca/
>>>>>>>>>Phone: (613) 565-5056 (ext 14)
>>>>>>>>>Fax:   (613) 565-0925
>>>>>>>>_______________________________________________
>>>>>>>>Mapserver-dev mailing list
>>>>>>>>Mapserver-dev at lists.gis.umn.edu
>>>>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>>>>>>Assefa Yewondwossen
>>>>>>>Software Analyst
>>>>>>>Fax:   (613) 565-0925
>>>>>Assefa Yewondwossen
>>>>>Software Analyst
>>>>>Fax:   (613) 565-0925
>Tomas Krecmer, tomas.krecmer at tmapy.cz
>T-MAPY spol. s r.o., Nezvalova 850, 500 03 Hradec Kralove,
>Czech Republic, phone: + 420 49 5513335 , fax + 420 49 5513371
