[Mapserver-dev] Enhancing mapserver line drawing
Steve Lime steve.lime at dnr.state.mn.us
Tue Oct 21 11:57:03 EDT 2003
I've been disappointed in the  GD antialiased output support. It's
really
slow and somewhat limited. For example (last I checked) you can only
draw single pixel lines antialiased. Styled lines (i.e. dashes) can not
be
drawn that way. GD has no provision for drawing thick lines other than
using brushes.
In MapServer you could use multiple styles and offset them
appropriately
to achieve think lines. Then you could antialias the outside ones.
I think the better approach is to capitalize on cartoline symbol type.
In
this case lines are converted to polygons and filled. An outline could
be
applied that is antialiased.
Steve
>>> <woodbri at swoodbridge.com> 10/21/2003 9:57:42 AM >>>
Hi all,
What if anything has been discussed about drawing thick antialiased
lines - I seem to remember a discussion that this was not possible
because we draw thick lines using a symbol. Also maybe the GD
antialiasing code was slow. What happens when a thick line gets draw
in Flash or Postscript, etc. It seems that what we should do is
define lines based on thickness and styles with one style-type being
a user defined symbol and then let the appropriate output handler
decide to implement it as appropriate. Is this happening now? Does
this make sense? For example, if someone wanted antialiased lines and
the performance hit was ok, they could then build an antialiasing GD
output module.
Any thoughts or opinions?
-Steve
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
