[Mapserver-dev] jBox image dragging
Steve Lime steve.lime at dnr.state.mn.us
Wed Oct 29 13:31:04 EST 2003
I've don't have a distribution in place. I can add one quickly though.
The addition of
this feature is probably a good reason do to just that. I'd distribute
from the same
place the mapserver distribution is available and let Kari link to it
from the jbox howto
and the utilities pages. One question, I assume there is also a dragoff
method?
Also we need to figure out how to handle formal version #'s for this.
I'm fine with
calling this version 1 and moving on from there. I suppose a constant
should be set
in the code with that value.
Steve
>>> Richard Greenwood <Rich at GreenwoodMap.com> 10/27/2003 10:42:25 AM
Steve,
Thanks for your reply. I'll commit my modification to CVS.  (I had not
wanted to commit it because I wasn't sure if negative coordinates were
legal.) The way I have implemented dragging won't break any existing
jBox
or dBox stuff, it's just a new function call: dragon().
Are you distributing dBox, and if so, where would I find it?
Rich
At 10:03 AM 10/27/2003 -0600, Steve Lime wrote:
>Cool, nice modification, now of course I need to modify dbox. There
is
>no problem sending
>negative coordinates. That's how most panning is done anyways.
>Steve
> >>> Richard Greenwood <Rich at GreenwoodMap.com> 10/26/2003 9:03:36 PM
>I have added image dragging functionality to jBox. This allows the
user
>to
>drag the image within the applet area. A new imgxy is then passed to
>mapserver when the mouse is released. A working example is at
>http://www2.tetonwyo.org/mapserver/
>Depending on how far the user has dragged the image, the new values
for
>imgxy may be negative and/or greater than the current image size. In
my
>limited testing this has not generated any errors. Does anyone see a
>problem with this? i.e. Am I breaking any rules by sending negative
>imgxy
>values, or imgxy values greater than the current image size?
>Thanks,
>Rich
>Richard W. Greenwood, PLS
>Greenwood Mapping, Inc.
>Rich <at> GreenwoodMap <dot> com
>(307) 733-0203
>http://www.GreenwoodMap.com
>_______________________________________________
>Mapserver-dev mailing list
>Mapserver-dev at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
(307) 733-0203
