[Mapserver-dev] Adding projection object to the refernece map
Yewondwossen Assefa assefa at dmsolutions.ca
Wed Sep 17 08:09:31 EDT 2003
Hi trhere,
  The intention is to add a projection object to the reference map. This
need was raised by interactive applications where the user was able to
modify the map projection. The extents specified in the refernce map
were then not "valid"  to render properly the bbox. The intention is to
to be able to use the projection of the map object and the one in the
reference object to compute properly the bbox.
If the projection object is not set It will work as it is now.
Any comments ?
Note : this was added as a Bugzilla enhancement request Bug 432.
Later,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
