[Mapserver-dev] Re: Unable to build CVS version...
Yewondwossen Assefa assefa at dmsolutions.ca
Mon Sep 22 18:11:38 EDT 2003
  I am adding right now ifdef USE_WFS_SVR to avoid this. Thses errors
were created by the dependency to the wms parsing code with the GDAL
library for parsing XML.
Later,
Steve Lime wrote:
> Getting ton's of errors in mapwfs.c (see below). Since I don't want WFS
> support I assume I'm missing a library and there are missing ifdef's to
> hide the code in question. Any idea how to get passed this?
> Steve
> mapwfs.c: In function `msWFSParseRequest':
> mapwfs.c:1190: `CPLXMLNode' undeclared (first use in this function)
> mapwfs.c:1190: (Each undeclared identifier is reported only once
> mapwfs.c:1190: for each function it appears in.)
> mapwfs.c:1190: `psRoot' undeclared (first use in this function)
> mapwfs.c:1190: `psQuery' undeclared (first use in this function)
> mapwfs.c:1190: `psFilter' undeclared (first use in this function)
> mapwfs.c:1190: `psTypeName' undeclared (first use in this function)
> mapwfs.c:1190: warning: left-hand operand of comma expression has no
> effect
> effect
> effect
> mapwfs.c:1191: `psGetFeature' undeclared (first use in this function)
> mapwfs.c:1191: `psGetCapabilities' undeclared (first use in this
> function)
> mapwfs.c:1191: `psDescribeFeature' undeclared (first use in this
> function)
> mapwfs.c:1191: warning: left-hand operand of comma expression has no
> effect
> effect
> mapwfs.c:1192: `psOperation' undeclared (first use in this function)
> mapwfs.c:1192: invalid lvalue in assignment
> mapwfs.c:1193: parse error before `char'
> mapwfs.c:1196: warning: implicit declaration of function
> `CPLParseXMLString'
> mapwfs.c:1201: warning: implicit declaration of function
> `CPLStripXMLNamespace'
> mapwfs.c:1206: `CXT_Element' undeclared (first use in this function)
> mapwfs.c:1254: `pszValue' undeclared (first use in this function)
> mapwfs.c:1254: warning: implicit declaration of function
> `CPLGetXMLValue'
> mapwfs.c:1270: warning: implicit declaration of function
> `CPLGetXMLNode'
> mapwfs.c:1286: `bMultiLayer' undeclared (first use in this function)
> mapwfs.c:1306: `pszTmp' undeclared (first use in this function)
> mapwfs.c:1325: warning: implicit declaration of function
> `CPLSerializeXMLTree'
> mapwfs.c:1325: warning: assignment makes pointer from integer without a
> cast
> mapwfs.c:1328: `pszSerializedFilter' undeclared (first use in this
> function)
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
