[Mapserver-dev] Label rotation...
Steve Lime steve.lime at dnr.state.mn.us
Wed Aug 4 10:43:36 EDT 2004
Thanks for the quick replies, sounds like it should be left alone (but
documented). GD
does CCW rotation. No biggie for me, we'll just add a second column to
the data in
questions that stores a rotation value and another for a true bearing.
Ultimately Steve's idea about setting CW or CCW as a second argument to
the ANGLE
parameter is a good one, but nothing I want to tangle with at the
moment. I'll file a
feature request in bugzilla.
Steve
>>> Daniel Morissette <dmorissette at dmsolutions.ca> 8/4/2004 9:35:51 AM
Paul Ramsey wrote:
> Yes, I always considered the label behavior correct, because here in
BC
> our toponymy comes with CCW label angles, so applying them directly
gave
> me the "correct" looking results. If you invert the behavior then I
have
> to negate all my input values before drawing :)
I've always seen angles specified CCW everywhere (that's not specific
to
GIS or compass, that's the way it is everywhere in trigonometry,
engineering, physics, etc) so I think we should go with that. I never
checked what MapServer used, but I always assumed it was CCW. If GD
uses
CW then it is the exception.
> Unfortunately there is no standard here, people will definately have
> angles of both sorts. (And different start points for measurement
too...
> start at north, or start at the positive X axis?)
If you are just rotating an object, as long as you know what the anchor
point for the rotation is, you don't need an absolute reference for the
angle: rotating a symbol 45 degrees CCW is the same whether your start
at the North or the positive X axis.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
