[Mapserver-dev] Positioning of text fonts & symbols
Arnulf Christl arnulf.christl at ccgis.de
Thu Aug 5 07:53:10 EDT 2004
This is a multi-part message in MIME format.
--------------030509000907050509040702
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
seems like this list is still alive?! I suggest to kill it too, it was
so much fun reading all those tests...
Chew on this one:
Whenever a text (font) is positioned (center,center) as a label MS will
use the bbox of the letters contained in the string for the positioning.
Instead it should calculate and use the bbox of all letters in that font
set. If not the texts jump about the place depending on whether the
string contains letters with upper or lower 'extensions' (is the
technical term: under-stroke???). A simple "A"  is OK, but add a lower
case letter like in "Aj" or "Ag" then it will be positioned higher up.
If the text contains only lower case letters like "a,s,e" they will
center on them, if the letters contain "under-strokes" like in "j, g,
y,.." they will be rendered even higher up.
Have a look at the screenshots, the magenta rectangle has 20 pix, the
center point is labled with the texts. I claim that a text is supposed
to "stand" on the baseline. That would be the "Grundlinie" in the image
<positioning_text.png> of the text.
This develops to be a larger problem for cartographically exact maps. We
need to place roadnames in narrow polygons and whenever they contain a
"g" they will stick out at the top and not fit anymore.
Using PostGIS we could work around by sorting out all texts containg
"j,g,y,p,q,y" into separate views and create individual layers with
individual offsets... but - ouch, that hurts!
Cheers, Arnulf.
CCGIS Christl & Stamm GbR
http://www.ccgis.de
http://www.mapbender.org
Service: +49 (0)228 90826 0
Direct:  +49 (0)228 90826 23
Fax:     +49 (0)228 90826 11
Siemensstraße 8
53121 Bonn
GERMANY
Content-Type: image/png;
 name="position_font_small_p.png"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
 filename="position_font_small_p.png"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 name="position_font_line.png"
 filename="position_font_line.png"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 name="position_font_small.png"
 filename="position_font_small.png"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 name="position_font.png"
 filename="position_font.png"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 name="positioning_text.png"
 filename="positioning_text.png"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--------------030509000907050509040702--
